Mugen MTX-4
#4756
Originally Posted by jam rock
yes,,,,,sorry not diff oil but shock oil. I am also running a 2mm split. all these changes was done one at a time and they all improved to handling but the car still pushes.
#4757
try 1.3 piston.
#4758
Have you tried changing your steering EPA on your radio.
#4759
Originally Posted by jeff whiting
Not sure if this has been suggested yet or not but you can also run the front of the car at something like 196mm and the rear at 199 or 200. This will give more steering.
#4760
jamrock- What Jeff Whiting posted is a great thing to get more steering. That is what I run on my car when I am looking for steering. Run a thicker diff oil in the rear, 50k is good. Are you using a one way in the front?
#4761
Originally Posted by asw7576
What happen if I switch the front track 200mm and rear 197mm ?
it will feel atrocious down the straight and willnot steer very well. downt he straight the car will feel like it is on ice! this is what i experienced with a friends electric car (pro4) with too many shims up from anyway
#4762
if i'm not wrong.. front track width wider than the rear one that can give you more steering..n if the rear wider than front there will be less stering..
#4763
to get more steering used 37 up front 40 rear that what some guys set their cars up here
#4764
better not used different shore of the tyre first.. better tuning the car first .. use different shore of tyre for the final setting.. if you didn't find the best setting to get more steering
#4765
Thanks for the input guys. I'm being paranoid because tomorrow I have to race Futaba Cup 2006. It makes me nervous
#4766
your Q?Kenji told me play it same 200mm front and both.To get more stering,let the body roll not the chasis..
#4767
#4768
agree ! n try more setting of suspension.
#4769
SURGE POWER !
Can anyone tell me the part number for the
receiver pack 5 cells for the mtx4 ! can't find it on mugen site ...
Thx . . . .
Thx . . . .
