Mugen MTX-4
#4006
Did anyone at the airtronics race use the infamous Ninja Motor.
#4007
KIKIKEA
#4008
Originally Posted by Scott Fisher
I have not stripped a spur gear at all. Even when I blew the clutch bearings, I still did not strip a gear. If you are having problems with spur gears, a few things that would help in addition to any other advice:
Do not launch the car off the ground. Some tracks have "alligator teeth" or even small ramp like areas instead of using pipe. Revelation has these as well as the track in toledo. When your car lands, it causes more chassis flex and if you are on the gas it puts a lot of stress on the drivetrain.
The other thing to try for guys having that issue is to get one-piece engine mounts. Skyline makes them and the Kyosho V one RRR mounts fits as well.
You've said anything about one piece mount...
Is the 3racing Mtx4 one piece mount a good one ?
have u tried it ?
#4009
guys..
just guessing of buying a 3racing 4mm chassi..
Is it a good idea ?
Is it a good idea ?
#4011
Originally Posted by GrandeGixxer
I just got the 4mm off ebay for around 55 bucks shipped. everything lined up perfectly and it has a very nice finish. Nicer than the stock one. Anyone doubting the quality from 3racing, it is top shelf. It is somewhat similar to bolting some jewelery onto your car.
But tell us...
How the 4mm chassi change the car ?
Better setup ?
or just good looking ?
#4012
Originally Posted by ZELOKO
Thanks..
But tell us...
Better setup ?
But tell us...
Better setup ?
Pros:
-More stiff
-Less chance to tweak (bend) the chassis
-More weight in the part you need it most
-You now have a spare chassis (if you bought aftermarket one)
Cons:
-More weight means a tad bit slower
The difference between stock mtx-3 chassis and the 4mm prospec chassis was about 5-15g which is about nothing...
#4013
Scott,
have u tried it ?
have u tried it ?
#4014
I have the 3racing one. All I can say its awesome and I have not had any problem with stripping the screw holes.
On another note, for the middle shaft block and the upper deck support, go with the 3racing one. The skyline one uses nuts provided and you have to glue them...
#4015
Location: Time to put down the Golf clubs and poker chips and GO RACIN!
How can I set the toe front and rear? will I need a set up board?
#4016
#4020
Originally Posted by ogreasurada
Wouldn't it affect the setup since the whole suspension is lifted up by 1mm? Or just subtract 1mm when setting up ride height?
