Mugen MTX-4
#2911
Originally Posted by Stew
Building a new MTX4 soon and was wondering what steering and throttle servos you are using.
Stew
Stew
I would suggest a KO digital though. I think my servo is developing centering problems.
Throttle is Airtronics 94737
I think this is the best servo out there for throttle. You don't need tremendous power or speed for a throttle servo. It's accurate and has a perfect balance of torque and speed. I have one that I bought 3 years ago when I started the hobby and I've used it in everyone of my cars including my current car.
#2912
I ran the MTX4 again yesterday. I tried different things and the car is getting better, and better. The biggest improvement I made was to take those stupid o rings out of the front outdrives, they were binding at full lock. Narrowed front end slightly. I also added more camber to the rear which helped a lot. Did some other minor things and the car is good. Thanks for all the tips.
#2913
If I get a specktrum, do I have to use digital servos ?
#2914
#2915
I love the car and how it handles but I kept on striping out the 2nd gear. I do not know what to do. I notice that the swaybar sort of touches the 2-speed housing. It happens about 2 minutes into a race. I'm not using the engine-brace so could it be flexing?
#2916
Ahhh! you should of told me that yesturday william hahaha yes that is the whole reason why your car is stripping the second gear.
Cody
Cody
#2917
Well after reading the past post, my problem might be the clutchbell touching the 2peed housing because theres a ring on it from something rubbing it. Also, I guess I could smooth out the shifting of first to second gear because rightnow it has a hard snap to it. I like that feeling but if its going to create a situation with the 2nd gear, I could do without it. I ran the car yesterday and I was amazed at how hard I could push it and how good the setting stayed after a race. With the TC3, everything would change after 20 min.
#2918
I know. I thought it was the sway-bar doing it. What happen to you? Did you end up breaking?
#2919
Thanks Jo
#2920
That little block that goes into the diff to make it a solid axle stripped out.
#2921
Originally Posted by Jo Gutierrez
no not necessarily. it will work with both analog and digital servos or combined.
#2922
Cody, next time, if you need one, just let me know. If I would have known yesterday, you could have been racing. Its just that plastic block right? Well next time.
#2923
How you stripped a solid plastic piece that goes solidly attached to the outdrives??? Maybe some gorilla tried to twist each wheel on the axle in different directions?
#2924
#2925
If you need to generate more grip, you can do it via other ways, never making the car flexes on that vital point. A flexible chassis makes the car easier to drive it but is not the way where you need to generate more grip.
