Mugen MTX-4
#2762
For this, stick to the stock part ... its strong and lighter.
#2763
Originally Posted by Scott Fisher
I will either get the shooter part, or just go back to the stock part.
#2765
The reason why we use lock nuts is because they hold the screws without using thread lock which may cause striping of the screws or damage to the aluminum.
#2766
I have never seen thread lock damage aluminium or cause screws to strip. I have however seen operator error cause these problems. Lock nuts dont lock after time. A fresh dollop of threadlock always does the trick.
I would personally be sticking to the stock piece though. That said, there are a couple of the shiny bits I wouldnt mind trying out. Cant get them here in Oz though I believe.
#2767
Originally Posted by ogreasurada
Take a closer look, the skyline holder's battery plate screws holes are not threaded (at least they are too thin to be):
#2768
Please do not worry, there are 2 lock nuts included. We use lock nuts for a reason. Thanks
#2769
mtx-4 is in lack? In mushroom it does not have the one month more than... Somebody knows? I am the wait...
#2770
Ebay has a few of them on sale too.
#2772
I have a comment I just put on the radio plate mount. The two rear battery holder screws go into locknuts that are held on this part. If you need to change batteries in a hurry, there is nothing to hold the locknuts in place. If that part of the radio plate was thicker and just threaded, that wouldn't be an issue. Just think if you are running a bigger race and have to change your battery pack because you bump up and only have 5 mins to get ready for the next heat.
That was one of my complaints when installing the part and battery. The solution is to install the battery then drop som CA glue around the locknut to keep it in place for future disassembly and reassembly. So the only tedious part is the first time assembling everything.
#2773
The 25t pulley is aimed at people that run rubber tires. So has anybody run the car with the 25t pulley on rubber tires? I don't know if I will ever run nitro on rubbers, but it might be interesting.
Maybe i will try them..
#2774
How much did you pay for your MTX-4's everyone ? Just curious cause I want to see what the going price is. Thanks guys.
#2775
$450
