Mugen MTX-4
#2568
Originally Posted by Scott Fisher
My car probably looks like every other MTX4 out there. The only upgrades on my car are a 4mm rear shock tower from "gonad", a Kawahara 2speed housing, a ti 2 speed shaft (mugen), aluminum wheel hexes,(mugen) front universals (mugen) and ti pillow balls (mugen). I would reccomend to everybody (especially spektrum users) to solder their battery packs together.
I could post some pics, but I think you will be disappointed. I have always thought the best looking car was the one standing highest on the podium.
Where can I get those shock towers?
#2569
Originally Posted by propain
"gonad"???
#2570
Post #1837 in this thread shows pictures of the shock tower. There is also a thread in the for sale forum called MTX4 4mm shock tower. His email address is: [email protected]
Thank you.
#2571
Originally Posted by josh_c
Thanks heaps for that information Rob. I think i will just stick with the one-way, it would probably make you a smoother driver leading to less mistakes. I really can't wait to hit the race track.
What percent of nitro due you all use, any castor oil??
I should also point out that you do need to check that conrod quite often. It seems to wear a little faster with 30 percent.
As for O'Donnell, I have no complaints except the price. It tends to be more expensive than other brands in my area but the quality is good. Lubrication is not an issue with O'Donnell. I used Tornado in the past but stopped when I kept getting rust on my crankshaft. I also didn't like the heavy ordour.
I hear RunnerTime is good but it's not sold in my area. Anyone else use it?
#2572
Stick with O'Donnell, it's good stuff.
Runner Time is also good, but if you can't get it.....
I had the same problem with Tornado, rust all over the place.
As for the nitro content, the more you run, the richer you can run your engine, that's why it's running cooler. It's also easier to tune. I would stick with 30%, everything above that is really putting a lot of stress on the mill.
#2573
stripping 2nd gear
Can any one help
Raced the mtx4 for the first time.. g8 car.
Probelm im not sure about is that im stripping 2nd gear after 10 -15 min of racing. i used the 2nd gear and 2nd gear hub of my old mtx 3 and it suffered the same fate.
using standard gear ratio 17-23 pinion and 53-59 spur gears. the usual problems like motor loose or alignments were checed and rechecked..
#2574
Originally Posted by prg
Can any one help
#2575
2nd gear stripping
Thanks for that It certianly felt tight but what you said makes sense..
#2576
Can any one help
If the engine mount touching the belt tensioner plate, it will stripping 2nd gear. Don't do anything, take out the 1st gear and check the clearance of 2nd gear. Or you can post some photo here, may help.
#2577
#2578
stripping 2nd gear
I have taken the 1st gear off and checked the clearance of 2nd gear. it certainly looks correct. i also wondered whether the 2nd gear hub/bearing may have a problem causing incorrect meshing at high speed but it destoyed my 2nd gear of the mtx 3 with a different hub..
#2579
Any photo...
#2580
I had 1 gear that stipped and I didn't know why as well. I took and looked at the 2speed clutch. 2 things I found......1st, I had a ring ground into it 2nd speed hub, it was from the clutch bell. and 2nd was that I hadn't spaced the 2 speed out far enough and the 2 speed hub was rubbing against the rear bulkhead.
