V-ONE S Thread
#1651
Re: Attention!
Originally posted by xGSiR
I haven't broken my suspension arms :/
Well for the front right side that is >.<
I was racing my V1S at my local netball court and it steered out of control and slammed into the pole! I would also need a new Pillow Ball. It slammed hard that it bent my manifold a little further out.
Anyone willing to donate a spare suspension arms?
left and right upper and lower arms caster adjusters and droop adjusters.Phone Stuart, part No is VZ003 .
gt
#1652
someone recommend me a good batt charger???? for reciver and radio and what not
#1653
ive had a couple of close calls at the netball courts with poles, the worst ive ever had was me smashing into my mates ts4n head on, but my car came out with one broken rim and his was completely screwed
v1s is just to strong
those elegi foams look awesome
#1654
i wish i could get the blue head for mine but since one of the bolts is stripped i cant get the one off i got now
#1655
squizzy wat did u call the 8 sided thing that i can use to get the stripped bolt off?
#1656
Yeah the V1S is tough and strong.
Though any car ain't that strong when it hits a pole head on >.<
If i had put on my body shell, i think it would of been prevented.
A lesson learnt.
Also thanks for that part # Squizzy, i hope it isn't too expensive.
A lesson learnt.
#1657
Engine Bearings
Racing tomorrow and no engine bearings !
#1658
Squizzy: on the last page, i was meaning the normal stock set up on the v-one s would loose around 80% of the down force, the new floating pod seems to be great. But b4 i upgrade my car im learning to drive better, dad said about 4 more meets and i can start upgrading if im driving alright by then.
Im racing today so 3 meets after that.
Sausage:
If its only the top of the screw that is stripped
undo the other 3 bolts, and then get a drill with a piece that is just as big as the screw heads, and very slowly and carefully take JUST the top off the stripped screw,
u can then lift the head off, and with pliers u should be able to slowly take the bolt out.
Had to do that on my old electric on the pinion/spur cover.
Works good.
Just dont drill the screw thread, only the head of the screw
Sausage:
Works good.
#1659
actaully ive hit a pole head on at almost top speed, no damage
just bounced back
just bounced back
#1660
Glow plug sizes
What is the size of the Glow plugs in the GS-15R. size 8?
I'm still breaking into my engine, but i messed my GP and the hobby shop said size 8.. But according to one of the racing lines magz it says size 5 for 1/10 cars.
Any ideas?
Any ideas?
#1661
size?
i dunno, i was told to use OS #8 plugs in the GS 15-r, they r meant to be the best plug for most conditions, in all 1/10 cars.
#1662
thats what i need.
thanks.
Lucky me got teh same make/model
thanks.
#1663
the plug sizes are all the same size i thinks accept for turbo plugs coz they have a taper on them, the os 8 will work the best and last the longest because it has a platnum coil
#1664
Sausage:
Works good.
Sausage:
Works good.
Very good v-one-s that will work i just tried it, you should have about 6mm to get a grip on.
gt
#1665
Re: Glow plug sizes
Any ideas?
Any ideas?
gt
