Old 08-07-2012, 05:21 PM   #1
Default Engine run time
Hi all
What is the best process to be followed for extending engine run time.
Change of pipe/header??? (1st?)
Does plug and head shim make a difference?
And yes I know leaning the motor helps but there is only so far you can go!
Had an engine at the last state titles that normally has no isses with run time but on that weekend struggled to get 5 minutes. Weather was no different from previous race meets. The only change was changing the gear ratios by going up one tooth on both pinions.
Any suggestions would be appreciated
Yeah Right! is offline   Reply With Quote
10min+ Run Time Engines? RCRACER2X Offroad Nitro Engine Forum 131 12-30-2010 08:12 PM
What engine if I want long run time and have $200 Klimpen717 Offroad Nitro Engine Forum 66 10-25-2010 09:58 AM
Engine Run Time advfuel Nitro On-Road 12 06-24-2008 06:24 PM
SEO by vBSEO 3.5.0
