Collari Xs12!
What is everyone feelings on the L.Collari XS12 compared to either a MT12, RS12, JP Black, Or a RB X12? Look forward to hearing from you shortly.
Cheers, H-O |
I just broke in my new XS12. After seeing that a lot of people had problems tuning them, I followed motorman's advise and put a Mugen MT12 carb on mine.
The engine seems to run great so far, has good torque, but I will know more after tomorrows race. |
Well I started our race season with one... and I FINALLY found the SCHWEET spot for the carb... the engine has a load of bottom end, but I found that if you ise with a Paris Ring pipe the engine lacks top end... I am now using an RDLogics pipe and that helped quite a bit.
Run time is awesome... just toying around I got over 10minutes to the tank... (I have a bit more fuel lin than the average joe) You do have to be VERY deliberate with the carb settings, my engine likes to be a hair over lean on the bottom, and the top I'm approx 4 turns out, anything other than that the motor runs like a cow. I am also running 30% nitro, so I ahd to also add another .3mm head shim & run a cold plug (MC9)..... My friends engine likes to run the factory settings on the carb and standard plug :eek: So as you can see be sure to take your time with it, you wont be disappointed! Rich |
What engine are these motors based on? Is it the Rb X12 or the Picco? Also i have heard that if they are based on the Picco's there may be some quality control issues?
I guess i really want to know how they compare to either a MT12 or a RS12???? |
they are essentially Picco motors...
Ok, I ran mine this weekend and it's absolutely ballistic.
Comparable to a RBx12 5 port (my XS 12 is standard 3 port) Love it, Mugen carb made it a breeze to get it tuned |
A 3-port TQ'd and won the A main at the MECA series at Mingara Aust. yesterday. Think he is running a standard Neo pipe on it. gives him mega revs.
Which version of the motor do you have and how does it compare to others?
personally I don't have a collari, but the one that won was an XS 12 standard 3 port. Not bad when there were no restrictions on what 12 motor you could run.
Hey guys, actually I TQD and won with a out of the box xs 12 5 port on the weekend. Youll find that probably the top 5 all had 5 ports, mine been the only Collari, and clearly one of the quickest engines. At $420 retail AUS, a bargain. Comparing it to my 3 port($350), it has some serious sting out of the corners, top end is also balistic. Both of my Collaris i run standard carbies and have no tuning problems. the tuning is quite sensative compared to novarossi carbs(especially the 5 port) so just a little at a time and no probs.
My pipe is an old PB pipe which I use to run in my BMT, but the NEO kit pipe works well. |
you can drill a small hole in the thickest part of the clutch shoe about 3/4 through and that will make the shoe lighter and take more rpm's. this is what i did a the nats on my tc3 along with the stiffer a.e. springs this will also work on the 3 shoe just make sure you do all the shoes the same. 2fast had a great run in the main i must say
I have a 5 port Turbo and I can not get it to run for crap. I have come close to getting it and it has some serious potential but I just cant get it there. Any suggestions. I am running the stock Collari Slide Carb.:cool:
as I said before (several times;) ) out a Nova Rossi carb on it
I was kinda hoping I wouldnt have to spend the money again for a new carb. I just got the engine.:(
The carb is fine... it just take more tweekin, than most. I had probs with the car flaming out, so I reset the carb to fact breakin... and leaned it out from there. Now it idles fine, runs at a nice 240, and so far (knock on wood) no flame outs....
I also wound up using a colder plug, and added another .3mm shim ( I run 30% Byron with 2oz of blenzol added to the gallon) Rich |
