HPI nitro RS4 RTR evo3 VS Kyosho FW05-T RTR
#16
Originally posted by chappi
Hey! what happen to your car!? where is all the electronic stuff gone!?
#17
Originally posted by NiMo
This should help you with the FW05T
(hope you have broadband)
FW05T Exploded view
FW05T Exploded view
u got pm
#18
i know it is a bit stupid..
pls excurse for this stupid question... b'cos i am totally new to GP.
When refill the petrol for a GP car. Do i need to totally shut the engine off first? Or I can just open the fuel tank lib and put in the petrol while the engine is still running?
What are the most common parts that need to be replace for a GP car!?
Said I only play my GP car, 1 hour per week, in a car park. which parts is the most easy to get damge??
Hope I didnt sound to stupid...kekeke
cheers
cheers
#19
You don't need to shut it down to refuel. Just fill it up and keep going. Keep an eye on the engine temp though. It can creep up when you run multiple tanks.
As for extra parts, steering knuckles, front and rear lower arms are a good start.
#20
#21
Keep the temp under 250 degrees for longer engine life. Some people run 280 to 300 and claim decient engine life. The older nickle plated FE's would die pretty quickly if you ran them too hot. The newer crome plates sleeves should be much more resistant to premature wear when overheated.
#22
Something else to consider:
Nitro is a coolant so more Nitro in the fuel would in theory keep the motor cooler, but Nitro is also corrosive so more Nitro would destroy the motor quicker.
Here in the UK our 200mm Nitro classes are restricted to 16% (235mm and 1/8th run on 25%) and running on 16% it is recommended you do not run anything over 220F (some even believe that you should stay below 195).
#23
Super Moderator
#24
Originally posted by Marcos.J
why are they restricted?
Remember this is the colder climates, no sexy tanned babes seen in these parts.
