Like Tree1Likes
Old 06-20-2012, 03:14 AM   #121
I'm looking at running the TRW105 shocks and noticed the optional springs are recommended but was wondering if I could use the springs from my stock shocks on the GT2. It looks like the stock springs may be stiffer but I'm not sure.
Mliebs is offline   Reply With Quote
Old 06-20-2012, 05:45 AM   #122
SteveP's Avatar
Yes, you can used the stock springs on the TRW105 shocks.
SteveP is offline   Reply With Quote
Old 06-20-2012, 06:36 AM   #123
So what's the low-down on this new Race Spec? I have a DM-1, and like it, but I have blown a lot of 2-speed gears, and I hate the CB with the tiny front bearings. Also, part availability is NULL. Here in Germany, Kyosho is widely available, and affordable..
So what are the significant improvements with the Race Spec? I basically didn't get the GT2 because of all the issues I heard regarding the 2-speed..(then yeah, had issues with the DM-1...)
What issues does it have? How fast is it stock? Thanks..
-Team Associated RC8.2, RC8T CE, & SC8 with 1.) Argus A52/0801, 2.) RB Fire 11/2058 or 053, 3.) RB Blast V9/2045, 4.) Nosram RS.30RR/JP-4, & 5.) modded Nosram RS.21RR/086
-LST2 #1 with Losi 454 & LST2 #2 with Dynamite Big Red .28
-Ofna DM-1 with silver Mach 427/2047
-TT MT4 G3
Herrsavage is offline   Reply With Quote
Old 06-20-2012, 09:15 AM   #124
C-Trickle's Avatar
Get the Race Spec and never look back! Shoe type 2 speed, 3 shoe clutch, 2.4 radio system, metal gear servos, stronger chassis, better brakes, good pipe and header. The KE25 isn't a bad engine either. Just before you do anything with it take it apart and reseal it. The couple KE25's that have had problems had air leak issues, so reseal them and they run just fine.
C-Trickle is offline   Reply With Quote
Old 06-20-2012, 10:09 AM   #125
C-Trickle's Avatar
What about droop? I've ran full droop, no droop, and partial. What does everybody else have?
Old 06-20-2012, 02:43 PM   #126
Winner's Circle's Avatar
I am running about 1mm of droop for both front and rear. Like you I have tried full droop, no droop and partial and I like to have just a little bit of droop.
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 06-21-2012, 11:53 AM   #127
VexVegaz's Avatar
Hey Steve,
Received the pinions in the mail this morning..
So far, while the combo of 17/21 is fast and makes this lrp .30 much more drivable. I find that the combo of 16/20 to be the sweet spot for this car/engine. The acceleration is butter smooth with a bit of throttle control and tailors my driving style. BTW i'm using .95 clutch springs and tightened the 2 speed to 2 1/2 turns.
However, when installing the pinions chipped a bit on the first gear with minimal pressure. I am assuming that if these does end up in production, the material used will be the same as the stock pinions.
Thanks again Steve!
Serpent Cobra GT > Serpent 748TQ Serpent S411 Serpent SRX2 Sanwa MT-4 Novarossi Hobbywing Epic D3 Savox > Sweep Tires > BrooklynHobbies.Com
For RC TShirts and Custom Sponsor Shirts & Hoodies, Please Visit www.veytrex.com
VexVegaz is offline   Reply With Quote
Old 06-21-2012, 01:14 PM   #128
Raman's Avatar
Trader Rating: 54 (100%+)
New GT2 spec kit with DBR9 that has new race livery.
http://www.kyoshoamerica.com/Inferno...3_p_11004.html
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 06-21-2012, 03:13 PM   #129
C-Trickle's Avatar
Lee
Hmm. Haven't tried that kind of set up. I've heard that most guys like 3-5 in the front and 9-12 in the rear. I just need to buy my own droop blocks and gauge so I can play around with it for a day at the track.
Old 06-22-2012, 10:46 AM   #130
VexVegaz's Avatar
Quick question guys...
Is there any significant difference between the dual brake system versus the single stacked brake system on the gt2?
Old 06-22-2012, 11:52 AM   #131
C-Trickle's Avatar
I prefer a single disk with the option SP pads. It's much more simple, and still has PLENTY of braking power.
But in theory by not having the disks stacked they can dissipate heat better however, by just upgrading to good pads with a single disk you shouldn't have any problems.
Old 06-22-2012, 12:15 PM   #132
C-Trickle's Avatar
Can you buy the little spacer that goes between your first and second pinions on the clutch bell for the shoe type 2 speed? I would like to get 2 other clutch bells together so I can have gearing options. 14/18, 15/19, and 16/20.
Also, I'm looking at maybe getting the option shock pistons. But unsure of what size of holes to start with. I was thinking maybe the 1.6X1 or the 1.3X2 pistons.
Any experience? I would consider the aluminum shocks, but $100 is tough to swallow, considering the good luck I've had with the plastic ones.
Old 06-22-2012, 12:48 PM   #133
VexVegaz's Avatar
C
I also looked into that and unfortunately kyosho doesn't offer just the washer. the only way to get it is through IGW008-01, per Trevor from infernosonly.com
BTW thanks for the brake setup info. and the new shocks is also in my to-buy list buy like you said, $100 is hard to swallow.
Old 06-22-2012, 12:58 PM   #134
C-Trickle's Avatar
C
Thanks! That's not too bad I suppose. I can make the washers, I've done it before. But I'm just lazy.
I have ran the SP pads with the SP disk for a while. However I found that the SP disk is a tad smaller diameter so it doesn't wear the entire pad. So if you get KYOIF134, the disks are almost the same thickness as KYOIFW122, plus you get 2 disks for less than the SP disk. Then use KYOIFW330 SP pads. Bam, more brakes than you'll ever need, plus the entire pad gets worn, and you have a spare disk should that one eventually wear out.
Old 06-26-2012, 10:42 AM   #135
mosaics12's Avatar
need some advise i have a gt2 & runnin a .28 motor and stock 2-shoe 2speed... what gear to use for tight track?
kyosho inferno GT2 pro.. kyosho ultima sc.. HPI savage X.. tamiya m-05 pr
mosaics12 is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
