Kyosho Inferno GT, GT2 Race Spec
#1321
Never had a problem with the tranny one way bearing. I put some grease on it every time I open the tranny which is not quite often.
#1323
i have a problem with the one way bearing at the transmition ,after modiding an old nova that i had the bearing fails every two drag races ,kyosho upgrade the trunny to shoe type but the one way bearing is the same and its so fragile ,maybe there is something else from kyosho ,did anybody else had the same problem with stronge torqy engines-,-,..--.
#1325
Hi Nick, i've always used that one way and only ever had a problem when the shaft gets a little worn which takes a heap of use, have you tried changing the shaft ? I use the 2 shoe tranny in the race car I have just won the Australian nationals with so its always had great motors to deal with .
#1326
#1327
Happy Thanksgiving fellow drivers.
Quick question, just yesterday while doing some street bashing, my front dogbone broke, so I was driving 3wd, so I ordered front CVD's instead.
Also rear plastic shock towers broke so I ordered the aluminum one.
Also both 4 stock rtr tires are worn out, basically was driving with inside foams!!
Stock tires only lasted through the break in process??
Are there any harder tires that lasts long? I don't need soft grippy tires as I don't race on tracks. Harder tires would work better so I can break loose traction for little 4wd oversteer action!
Are there other parts that go out easily on these that I should order? THanks guys happy holidays!
#1328
#1329
#1331
