Kyosho Inferno GT, GT2 Race Spec
#1201
lol is it not fast enough already? Mine is pretty fast and its all stock. Any faster the car would be hard to control. I can barely see my car when I run it at the mall because it'd way too far to see by the time I blink. I use 25% to make it faster. Also good grip tires. I sometimes run it without the body and it is faster. What body do you have?
#1202
So where do you want to be fast ? is it just in a straight line or faster through corners or do you want to be able to drive faster ??
#1203
LPR 30
Hello, I just bought a GT2 Race Spec and was wondering what it would take to install the LPR ZR .30 into it, can i use the same clutch and pipe? Thank You
#1204
What clutches do you guys run on the car? Looking for after market ideas . Thanks
#1205
Im having issues with my GT2 VE electric. I know this is the nitro thread but my questions applies to both.
My issue is that when I run the car with the body, the front scrapes the ground when doing full throttle -as if the body lacks aerodynamics. The body flexes alot at high-speed. Im to a point where I run mainly without the body because of this problem. I rolled the car today because I ran over a blue marker on the road and the car flipped which caused my body posts to break. Any suggestions or comments as to why my body is acting the way it is? Anyone else have this problem? Im running a ceptor body. thanks
#1206
hello, will these swing shafts work on my GT2 race spec? KYOIFW333, are these only for the front or can i use them in the rear too? thank you
#1207
#1208
Go get a quality .21 motor that revs to 40k or more like the NOVA ISON GT or PICCO 5 port GT ...most cars in the GT class top out at 55-60 mph on the pro circuit so what is "FAST" for you exactly ?
#1209
Hey guys I have just ordered a kyosho inferno gt2 race spec. I am completely new to the rc car thing. but I was just wondering what the first things I should start to work on it?
#1210
thanks in advance
#1211
Get a receiver batt pack and run in the engine. Charge the glow plug igniter well before running in. Then, get better tires like sweep or grp if you plan to run on a track. A starter box is a big plus.
#1213
#1214
can anyone help on the part number or length for gt2 if I want to change the center front and center rear from dogbone to CVD. Thanks in advance
#1215
front - IFW45
rear - IFW160
You can get both of these pretty cheap on ebay ($15-16 or so each).
