Like Tree1Likes
Old 06-16-2012, 02:48 PM   #106
SteveP's Avatar
You don't have to change your car for this purpose - just have fun and let me know what you think works best for your car. I would suggest removing the aluminum arms anyway just for performance reasons, but don't feel the need to take them off for this reason.
SteveP is offline   Reply With Quote
Old 06-16-2012, 03:55 PM   #107
C-Trickle's Avatar
+1,000,000
Unnecessary aluminum suspension parts = more weight and more breakage/bending/shearing off bolts.
Kyosho has great plastics. The only thing that would be considered an upgrade would be if we could get nylon parts. If it ain't broke don't fix it, and if it is broke replace it with stock.
C-Trickle is offline   Reply With Quote
Old 06-16-2012, 04:53 PM   #108
VexVegaz's Avatar
my main purpose in putting those aluminum a-arms was to tame down that lrp .30, but with the higher gearing, i no longer need to do that. Im not a fan of bling parts unless the car is a shelf queen.
Serpent Cobra GT > Serpent 748TQ Serpent S411 Serpent SRX2 Sanwa MT-4 Novarossi Hobbywing Epic D3 Savox > Sweep Tires > BrooklynHobbies.Com
For RC TShirts and Custom Sponsor Shirts & Hoodies, Please Visit www.veytrex.com
VexVegaz is offline   Reply With Quote
Old 06-16-2012, 06:06 PM   #109
SteveP's Avatar
Originally Posted by C-Trickle View Post
Ok. So I know that the upper/lower A and B blocks allow you to adjust your caster to some degree. But which block changes what? By how much? What would be the set up to run to end up with the least amount of caster?
The LOW/HIGH and A/B blocks are made to give us an option to adjust the angle of the front hinge pins to change the arm angle. This is referred to as anti-dive in correct terms. The best option for a road car is to reduce the arm angle by installing the high mount for the upper arms, and the "B" block below, you're essentially increasing anti-dive by two-degrees. This is more appropriate for a car racing on asphalt.
Old 06-16-2012, 06:18 PM   #110
jesus, that looks factory its so clean.
therealdede is offline   Reply With Quote
Old 06-16-2012, 07:33 PM   #111
C-Trickle's Avatar
Just what I needed to know.
So with the high mount block can you put the front upper hinge pin through the lower hole in the shock tower?
Old 06-16-2012, 08:05 PM   #112
SteveP's Avatar
Which front end are you using? 777 or 7.5?
Old 06-17-2012, 12:40 AM   #113
C-Trickle's Avatar
I havea GT1 on a Route 246 chassis. Shouldn't putting the upper hinge pin in the lower hole take some caster out?
Old 06-17-2012, 11:06 AM   #114
SteveP's Avatar
Not really. The front end is designed as a complete system. When you change the lower suspension mount to the "B" block from the "A" block, you reduce the angle of the arms, but you also reduce caster. If you were just wanting to change the arm angle without changing caster, you could install the optional C hubs and keep caster angle the same. Now, when you change the angle of the lower arms, you also have to change the angle of the upper arms, otherwise the upper and lower arms are pivoting on a different arc or plane than the lower arm. So, when you adjust the bottom, you adjust the top.
Old 06-17-2012, 08:33 PM   #115
Vision's Avatar
Trader Rating: 38 (98%+)
SteveP, for a high speed (70+mph) asphalt oval track with lots of bumps, which block would you suggest ?. Thanks.
6iX, GTP2e, XO-1, DM1-E, ST-R/MP777 GT2 Hybrid, GT2-VE, GT2-E Circuit, Hybrid Vorza, Rampage XB-E, Slash Platinum, tc5R
Vision is offline   Reply With Quote
Old 06-17-2012, 10:44 PM   #116
SteveP's Avatar
I would still run with the "B" and "H" blocks and 20-degree hubs - basically the least amount of caster possible.
Old 06-17-2012, 11:43 PM   #117
Vision's Avatar
Wouldn't the optional B blocks improve turn in, but at the cost of straight line stability ?.
Old 06-18-2012, 12:03 AM   #118
SteveP's Avatar
No. You can't use conventional set-up information that assumes you're within the proper range already. These cars use geometry that's optimized for an off-road buggy, so it's running excessive amounts of camber already, and the arm angle is much higher than normal.
Old 06-18-2012, 09:08 PM   #119
C-Trickle's Avatar
Ok, I'll bite. I'm curious to hear your basic set up.
Old 06-19-2012, 08:41 PM   #120
SteveP's Avatar
My car is in a million pieces, but I think I recall everything that I've done to it.
4 gear diffs front and rear, 3.0 front stabilizer, 2.8 rear, TRW105 shocks with the IGW silver springs in the front, black in the rear (not stock, but black IGW spring). The front shocks are running 1200 Kyosho oil, and the rear 1000. The front diff is at 50K and the rear at 3K. In the front I'm running the H/B blocks for minimum caster, and I'm in the process of fitting some MP9 hub carriers and knuckles to reduce caster even further. In the rear, I run the upper camber link in the lower hole on the shock tower. The roll center geometry works better for me with the camber link in the lowest hole. I hpoe I got most of it covered, but I'm always trying new things because that's what makes me tick.
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
