Old 09-15-2014, 08:02 AM   #1156
Originally Posted by jfle98 View Post
How do tighten up the axles ? I see Kyosho makes 8x10 shims
There is quite a bit of slop in those axles, especially the fronts.
Will shims take care of that or are new cvd's the way to go ?
cut small pieces of fuel tube and slide it in
Reaper1ct is offline   Reply With Quote
Old 09-15-2014, 08:03 AM   #1157
Originally Posted by Reaper1ct View Post
ok i geared up to a 25 tooth (50 rollout) and still not happy...is there any 8 scale systems that boost? or should i just go 5/6s...
no one have any help here? no one ever replys in the electric forum.
Old 09-15-2014, 11:19 AM   #1158
Jspeed's Avatar
Originally Posted by koval View Post
The best gearing set up depends on the motor and esc .
Ex. You cannot gear up your stock gt2 to 1:1
You need powerful motor and hi-amp/hv esc so you can gear up to 1:1 or even more.
Try getting in touch with "Koval" he's been working on hi-speed electric Kyosho' IGTs for a while and might be able to help you more than anyone else. Good luck
Jspeed is offline   Reply With Quote
Old 09-16-2014, 01:42 PM   #1159
Hey guys me again, gonna convert my kyosho buggy 777 sp1 into a gt1 car. but I'm going to use the 2 speed from my gt2, and my .25 motor and all those things....but what else would I need to do, I'm going to use the towers from the gt2, and gt2 shocks.....what else do I need? or need to do
Old 09-16-2014, 07:11 PM   #1160
Yb2fast's Avatar
Just swap the chassis from your MP777 to the GT2 !! everything will will bolt on from the GT2 except you will have to drill 2 new holes for the GT2 2 speed to line up correct ! the shorter chassis is more nimble and turns quicker lap times ! read some of my older posts and you will see how developed my car is !! also toss the KE25 motor and put a descent .21 in the car !! you will thank me !
you will have to use a shorter rear dogbone/cvd !!......also I have a very fast GT1 E conversion running a mamba monster esc/motor on 4s with 23/46 gearing at its fast !!!!
GT1/MP777WC, GT2 BRUSHLESS 110 MPH ++, GT1-VE MAMBA PWR, MP777-EBUGGY TEKIN, XRAY NT1, HB D8 HARA, LOSI EIGHT2.0, LOSI EIGHT-T 2.0, Visit my Ebay store RC NITRO DEPOT !
Yb2fast is offline   Reply With Quote
Old 09-16-2014, 11:16 PM   #1161
Thanks bud, I appreciate the advice, but I'm not racing, I'm just having fun....The track we using, has a huge outside oval which you can get pretty mean speed out of....I also just want to spend as little as possible.....problem is I love the body of the gt2 audi r8.....I can't bare to part with that awesomeness
Old 09-20-2014, 11:58 PM   #1162
MeClown's Avatar
Default Engine recommendations
Hello
I just purchased a GT2 and want to start making it race ready. As I bought aluminum A arms, full bearing set and slicks. Is there a motor you guys recommend to use? I live in HK but can mail order anything. Any advise would be greatly appreciated.
Michal
MeClown is offline   Reply With Quote
Old 09-25-2014, 11:00 PM   #1163
MeClown's Avatar
Default New to the Forum
Hello.
I'm new to the forum and wanted to see if you guys could include me. I currently live in Hong Kong but am looking to relocate back home to Matlryland where my folks live.
I currently just purchased a GT2 RS Astin Martin body.
I would like to get involved into the racing scene as I ised to race HPI electric on road.
Thanks guys
Old 09-26-2014, 12:19 PM   #1164
afm
afm's Avatar
Default SERVOS
What´s the ideal Torque/speed for steering and acc/brk servos for these cars, considering their weight.
AFM
afm is offline   Reply With Quote
Old 09-27-2014, 12:06 PM   #1165
Yb2fast's Avatar
Originally Posted by MeClown View Post
Hello
Michal
Go get the ISON GT .21 Novarossi motor and call it a day ! www.desotoracing.com !
Old 09-27-2014, 12:12 PM   #1166
Yb2fast's Avatar
AFM
I would say anything over 200oz and speed anything under .10 sec speed...I use some JR servos rated at 200oz and .06 sec speed for both !! !!
Old 09-27-2014, 12:14 PM   #1167
Yb2fast's Avatar
So why dont you just run your gt2 ??
Old 10-03-2014, 09:47 AM   #1168
MeClown's Avatar
Default Ride height/camber & toe settings
Hello
Wondering if you guys have preferred sertings for
ride height?
Front / Rear toe?
Front / Rear camber?
I'll be running in a hot climate.
Old 11-10-2014, 11:02 AM   #1169
Has anyone ever noticed the amount of slop in the hubs for the wheel bearings? Ive got the GT2 and wow is there a lot of play. Ive tried new bearings and you can watch the bearing move inside the hub. Would upgrading to the alloy hub be the better option?
Ive got a friend that bought his GT2 new and he shared a video of his wheel slop and its just as bad as mine and I got mine used. There has to be a way to fix this...
LLkoolskillet is offline   Reply With Quote
Old 11-11-2014, 11:58 AM   #1170
Shim the axles . It's a must on that car. I have a 777 short GT car that I raced for a couple of years. It has the Evolva 2-speed with all the upgrades and goodies to make it a very race ready car ( finished 2nd at the RC Pro series nationals with it) It has a modded Sirio .24 in it with 400oz. steering and 200oz. throttle servos . I would sell it pretty cheap if someone is looking for something like that to race. I got sponsored by Serpent and haven't run the car for a while.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 07:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 02:55 PM
Tags
igt, inferno gt2, kyosho
SEO by vBSEO 3.5.0
