Like Tree5Likes
Old 08-19-2014, 03:58 AM   #1141
hi guys would this stop my gears from stripping?
http://www.ebay.com/itm/Kyosho-Infer...item54087485e5
I ordered the one below thinking it was the one above so do i still need the shaft? im a bit confused....can you help me out?
This is what i ordered...
http://www.ebay.com/itm/331250339044...%3AMEBIDX%3AIT
Do i need this:
http://www.ebay.com/itm/Kyosho-Unive...item51c123f9ec
Or what do i need to sort out the stripping gears
Reaper1ct is offline   Reply With Quote
Old 08-19-2014, 12:40 PM   #1142
scary_jerry's Avatar
Default gears??
Do i need this:
Which 'chassis' are you using? That's a 'Long' universal shaft from the picture.
In July this year I used my first '2 shoe trans'......giving up my 40/46 tooth option and getting away from the 'sling-finger' GT1 trans clutch. That 'front dogbone' that comes with the '2 shoe' trans is 91mm......the clutch bell has a 'spacer' to handle a '5mm or so' length difference in the new trans length.
GT1 (short chassis) w/early trans requires 84mm front 'dogbone'.......new '2 shoe' requires that you shorten to a 78mm front dogbone. That front 'uni' drive doesn't have anything to do with 'gear munching' unless you do not set front diff. gear mesh properly and then your 'front end' .......disembowels itself. Give me a clue as to 1. your chassis, 2. your trans..........I ran the 'early' slingfinger for 5 years..........went to the '2 shoe' only because my motor can now provide the speed I got out of 'the 40/46 trans' alone.
It's a weeeee bit of a '3 hand operation' to get 'pinion gear mesh' at times but that's where I've seen most of the problems. If you are running where you pick up rocks in the gears, you can't prevent gear damage. Setting mesh a 'bit tight' always worked best for me. (15/19 pinion on 43/46.......15/20-21 pinion on 40/46)
(feel free to PM me for clarification)
scary_jerry is offline   Reply With Quote
Old 08-20-2014, 09:56 AM   #1143
Graham11's Avatar
Trader Rating: 21 (100%+)
Hey guys, I run the Ve but thought you guys would be interested too, absolute hobbyz has the gt2 for a discounted price all of a sudden, just figured I give a heads up in case someone's looking!
Graham11 is offline   Reply With Quote
Old 08-21-2014, 12:56 AM   #1144
lol i just got one for my friend this morning
Old 09-05-2014, 06:56 AM   #1145
Guys i came across something strange.....i decided to rip my Gt2 nitro racespec apart and use a e conversion from my kyosho buggy (mp777 sp1) including the single speed diff....but the front shaft was to short (90mm) tried the rear shaft to long (120mm)......need a shaft (dogbone) that doesnt seem to exist (110mm) only hpi and JQ make.....WTF? any ideas why?
Old 09-05-2014, 08:32 AM   #1146
Smile 110mm
Just checked Amazon. Under search for the JQ products 110mm dogbone.......they have 4 different colors and a note to order quick, only '1 of each left'.........
Old 09-06-2014, 05:02 PM   #1147
i bought the hpi bud. should be here monday.....i just wanted to know if anyone else had this issue
Old 09-06-2014, 05:50 PM   #1148
Is anyone using the rxshox two stage pistons in the plastic shock body and do you think it is worth changing to?
AlGio is offline   Reply With Quote
Old 09-11-2014, 03:13 AM   #1149
guys this one is for the brushless oaks....i have a hw 2250kv motor on 4s, it has lots at the bottom but the it tops out very quickly....any idea where i need to be gearing wise? i used 20/46.....
Old 09-11-2014, 04:27 AM   #1150
C@T's Avatar
With the gearing you use youŽll reach 90 km/h, or 50 mph.
The ratio between this speed and the one you are looking for will tell you how many teeth to go up from 20.
C@T is offline   Reply With Quote
Old 09-13-2014, 02:13 PM   #1151
ok i geared up to a 25 tooth (50 rollout) and still not happy...is there any 8 scale systems that boost? or should i just go 5/6s...
Old 09-13-2014, 02:28 PM   #1152
MantisWorx's Avatar
Trader Rating: 28 (97%+)
http://www.ebay.com/itm/261588297870...84.m1555.l2649
MantisWorx is offline   Reply With Quote
Old 09-14-2014, 06:46 AM   #1153
Have anyone used Team C's body on Kyosho GT2? Recently I bought a Team C's GTR R35 body but realize the width is too wide. Kyosho's width is 310mm while the Team C's R35 body is 310mm for the front and 320mm for the rear. Looks weird on Kyosho's chassis. Have any of you tried other Team C's body on Kyosho GT2 and find the fitting right?
Supa_Mario is offline   Reply With Quote
Old 09-14-2014, 12:29 PM   #1154
Default Protoform PF8 body
Doesn't fit too good. Line up the front wheels in the wheel openings
and the rear wheels are almost out the back. Isn't there a spec on
GT cars ? What bodies fit well ?
jfle98 is offline   Reply With Quote
Old 09-14-2014, 03:14 PM   #1155
Default Axle slop ?
How do tighten up the axles ? I see Kyosho makes 8x10 shims
There is quite a bit of slop in those axles, especially the fronts.
Will shims take care of that or are new cvd's the way to go ?
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
