Like Tree1Likes
Old 04-26-2014, 06:32 PM   #991
FLoJo's Avatar
I just picked up a gt2 nitro I believe it's stock motor and 2 shoe clutch , thing is everytime I get it started just wants to go and if I lower throttle or hit brake cuts out .. I checked clutch seems alright . Since I'm assuming its ALLREADY been broken in as I bought it used can I just set all needles back to default and start from there otherwise I'm stuck and my arm hurting from all the pulling lol btw its the Audi Dtm gt2
KYoSHo iNFeRNo GT1-E RCMoNSTeR CaSTLe2200 <> KYoSHo iNFeRNo GT2Ve Tekin 2650
oFNa LM DO CaRBoNFiBeR CaSTLe2650 <> TC4 FT
ZDRaCiNG TRuGGy <> HPI NiTRo RS4 .21oS
PRoBoaT STiLeTTo <>TRaXXaS SPaRTaN
FLoJo is offline   Reply With Quote
Old 04-27-2014, 07:57 AM   #992
Markcuda's Avatar
Is this the front and rear drive shaft upgrade for the GT2?
KYOIFW142 IFW142 UNIVERSAL SWING SHAFT(90.7KYOIFW142 IFW142 UNIVERSAL SWING SHAFT(90.7
Team Associated Rival 1/8 Scale Monster Truck|Powerlab6|Junsi S1200
2 HPI Vorza's,One For Me,One For The Wife|FMA Parallel Board.
Losi XXL Nitro Monster Truck|1996 Thunder Tiger Mirage Pro.21|Kyosho Inferno GT2 VE Race Spec 1/8 scale Corvette C6-R ReadySet Electric.
Markcuda is offline   Reply With Quote
Old 04-27-2014, 03:11 PM   #993
scary_jerry's Avatar
Default axle goodness!
Dear GT guy......refer to my post #940 for axle help. Your choice is the 'better' position than 'dogbone' and 'drive cup' but not the 'LIGHTWEIGHT' version that will bring best performance. Those axles do provide better results on the one end of your drivetrain.
I have a car with those!!
scary_jerry is offline   Reply With Quote
Old 04-27-2014, 03:19 PM   #994
Markcuda's Avatar
Jerry, thanks a bunch.
I went ahead and ordered the light version.
Kyosho Light Weight Front Universal Swing Shaft (90.7mm) (KYOIFW333)
I was only going to upgrade the 4 corners, not at the differentials.
Old 04-27-2014, 03:38 PM   #995
Smile
Not a bad move....!!!!
Old 04-28-2014, 08:47 AM   #996
JLock's Avatar
Re-check the clutch shoe spring. If it was from an older RTR kit, it has two big clutch shoes with a spring down the middle. What happens sometimes is that the spring that holds the two shoes breaks at the clasp eyelets and will not hold the shoes together. Or, it could be that the spring is in a way that keeps the shoes engaged and as soon as the brakes are hit, it stalls the engine. I have had both of these issues happen to me before I changed it to the three-shoe offroad clutch from the Kyosho 777/MP7.5. You also might want to eventually want to invest in a starter box (cuts down on tired arm and finger blisters from excessive pull starting).
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 04-29-2014, 04:28 PM   #997
Need help with 2 speed settings. How many turns out is a good place to start. I can't tell if it isn't shifting or if it is already stuck in second. Lol. Hopefully it's not shifting because it looks way too slow for a novarossi in second.
BuddyBaja is offline   Reply With Quote
Old 04-29-2014, 06:46 PM   #998
got my new gt2 and ran the first break-in tank. it wanted to go the whole time while idling. is there something wrong with the clutch?
benbishop98 is offline   Reply With Quote
Old 04-30-2014, 09:31 AM   #999
What is the best weight oil to run on the option aluminum shocks??? Right now running 1000 rear 1200 front
Old 04-30-2014, 10:55 AM   #1000
JLock's Avatar
See my post #996. You also might want to check your idle, it could be too high. Your engine should purr like a cat, not rev like a lawnmower or chainsaw with the choke on (which would be high and fast enough to engage the clutch).
Texas 5
Old 05-01-2014, 07:44 AM   #1001
djmorales's Avatar
Send a message via Skype™ to djmorales
Thumbs up 2 speed
need to know if you have the new tranny or the old Trans. the old to speed is like a little hook that comes out. It can eat up the plastic inside the gear. so if you see a silver drum in between the spur gear it is a new clutch shoe transmission . Besure your engine is broken in for proper shifting in the trans. Good luck
Serpent GT cobra leisurehours Raceway local racer /slow is fast
djmorales is offline   Reply With Quote
Old 05-01-2014, 07:53 AM   #1002
djmorales's Avatar
Default shock oil
I use a different brand of shock oil. It's best used by the temperature that you're running iin warmer you want thicker colder you want lighter.
Old 05-01-2014, 08:42 AM   #1003
I have the new shoe style transmission. Are there supposed to be set screws in the clutch shoes to hold the little cams down?
Old 05-01-2014, 09:39 AM   #1004
*1speedy's Avatar
Yes you should use the set screws in the 2 speed clutch, just keep them equal. If you don't use them your shift will chatter.
🏁🏁🏁 🏆🏆🏆🏆 2013 XRAY XB9 GT8 🏆🏆🏆🏆 🏁🏁🏁
2013 & 2014 R.O.A.R. REGION 1 & NY State GT8 CHAMPION!!
....................... 🏆 SPONSORS 🏆 .....................
ABSOLUTE HOBBYZ / Engines Modded by The Nitro Shop
*1speedy is offline   Reply With Quote
Old 05-01-2014, 05:39 PM   #1005
Got the 2 speed all put together. All good now.
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
