Like Tree1Likes
Old 01-12-2014, 07:17 AM   #841
Yb2fast's Avatar
Originally Posted by scary_jerry View Post
Good list of 'upgrades'..............to your list I would add a 'splash guard' to keep fuel off of your brakes. Kyosho has a couple available but I have also made my own. Fuel on your brake pads during a pit shop is not an enjoyable thing.
Jerry...tks for the tip...so funny you added that cuz it just happened to me ..took 5 laps later to get brakes back ..eeeeekkkkkk !! lol ...will be ordering one next !
GT1/MP777WC, GT2 BRUSHLESS 110 MPH ++, GT1-VE MAMBA PWR, MP777-EBUGGY TEKIN, XRAY NT1, HB D8 HARA, LOSI EIGHT2.0, LOSI EIGHT-T 2.0, Visit my Ebay store RC NITRO DEPOT !
Yb2fast is offline   Reply With Quote
Old 01-12-2014, 07:27 AM   #842
Yb2fast's Avatar
Originally Posted by djmorales View Post
good luck in homestead have a friend going to race they're getting out of this Chicago cold weather
Thank you bro !! Here is a GT race at Homestead you will like that I shot last month ! >>http://youtu.be/hbYMcO6qXdU
Old 01-13-2014, 08:13 AM   #843
Yb2fast's Avatar
Originally Posted by ferrariGTR View Post
Someone could help on these?
I've been thinking to custom mod a 2 speed transmission and would like to seek your help for some measurement below:
1. length of the 2 speed shaft (part no. KYOIGW008-01)
2. diameter of the 2 speed shaft
3. outer length of shaft measure from drive cups end to end (measurement A of pix)
4. inner length of shaft measure from bearing to bearing (measurement B of pix)
5. Thickness of bearing
I appreciate very much if you could help me out on these measurement. TIA
MEASUREMENT A IS 76.65 MM AND B IS 31 MM AND BEARING SIZE IS 5X16MM !! GOOD LUCK WITH YOUR BUILD !
Old 01-13-2014, 07:02 PM   #844
Gosh, thank u so much!
I suspect measurement for B should be more than 31mm; correct me if I'm wrong. Do you happen to know the diameter of the 2 speed shaft?
ferrariGTR is offline   Reply With Quote
Old 01-14-2014, 12:06 AM   #845
modelcitizen's Avatar
Just picked up a GT2 Limited Edition kit on ebay. Build is going great except for one problem. The mounts for the rear suspension arms (IF113, IF124) for some reason seem to have the holes for inserting the hinge pins spaced different distances apart, making it impossible to attach the rear suspension arms. Please see attached images to understand what I'm talking about, am I missing something? Any help would be greatly appreciated.
Kyosho Inferno GT, GT2 Race Spec-img_0585.jpg   Kyosho Inferno GT, GT2 Race Spec-img_1211.jpg
modelcitizen is offline   Reply With Quote
Old 01-14-2014, 04:20 AM   #846
*1speedy's Avatar
They are supposed to be at an angle, kyosho sells different degree sp plates coded by color. Rear toe is a good thing
I believe the red one was 1 degree. You may want to get some upgraded hinge pins, the kyosho ones are Very soft and bend easily plus the C clip method is antiquated.
Personally I would screw the plate on to the diff first put pins with C clips on the plate side pins then slide arms on then put rear plastic holder on then rear C clips. Take your time you can do it
You may want to use some type of wax lubricant on the hinge pins in the future for maintenance.
Welcome to GT fun
🏁🏁🏁 🏆🏆🏆🏆 2013 XRAY XB9 GT8 🏆🏆🏆🏆 🏁🏁🏁
2013 & 2014 R.O.A.R. REGION 1 & NY State GT8 CHAMPION!!
....................... 🏆 SPONSORS 🏆 .....................
ABSOLUTE HOBBYZ / Engines Modded by The Nitro Shop
*1speedy is offline   Reply With Quote
Old 01-14-2014, 04:30 AM   #847
Thank you sir! I thought that might be the case but they just seemed to be binding rather badly and I didn't want to force anything and break it. I'll try the method you suggest and see how it goes.
Old 01-14-2014, 06:24 AM   #848
Please try and excuse the onslaught of noob questions, I've been out of the hobby for a few years. If I were to upgrade the hinge pins, what brand would you suggest and what is the alternative method of securing them (as opposed to c-clips)? Thanks!
Old 01-14-2014, 08:22 AM   #849
azeroth's Avatar
Trader Rating: 20 (100%+)
http://www.ebay.com/itm/360701819050...84.m1423.l2649
they get held in by set screw there also used to be a kit that was a long shouldered bolt
also
http://www.mcmaster.com/#standard-dowel-pins/=q8yflv
for pins its a option
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 01-14-2014, 10:53 AM   #850
jlopez's Avatar
Hi Guys,
I picture of my Gt1 taking it out of the garage.
Joan Lopez
Lopez Racing Team
HobbyLop Racing Track (Official Driver)
1/8 Kyosho GT #16
jlopez is offline   Reply With Quote
Old 01-14-2014, 06:02 PM   #851
*1speedy's Avatar
These are the only upgraded non C clips I know at the moment. I wouldnt be suprised if Lunsford had some thing too.
http://www.amainhobbies.com/product_...-Hinge-Pin-Set
Kyosho GT is just a 7.5 buggy with a 2 speed and bumper so most 7.0 7.5 and 777 kyosho buggy parts are a direct fit.
If I see anything else I will pm you I don't run that model any more but do remember alot of the upgrades
Have fun
Old 01-14-2014, 09:18 PM   #852
azeroth's Avatar
Have fun
those work very well we used to swap our cen stuff for the kysho mounts and use those in buggy no more lost e clips you may need to ream the arms though
Old 01-16-2014, 08:17 PM   #853
Yb2fast's Avatar
The main shaft running through the 2 speed ??
Old 01-23-2014, 02:21 PM   #854
Hi anyone know if they make a carbon fiber chassis for the gt2? Ive them out there but not sure whether or not it was custom made or a company actually sells them
Allshowandgo is offline   Reply With Quote
Old 01-23-2014, 03:51 PM   #855
koval's Avatar
Carbon chassis for gt2 was manufactured and sold by max velocity long time ago,but now it is discontinued .
I have in my plans to design and cut in my milling machine a 4mm carbon chassis for gt2 but i havent found since now a good carbon fiber suplier,anyone here ???
http://brushlessmaniac.blogspot.gr/
koval is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
