Old 12-13-2013, 09:26 PM   #826
Default somthing I just did to my old gt2 chassis
Hydrographic dipping. Hope you like it.
Kyosho Inferno GT, GT2 Race Spec-imag0141.jpg   Kyosho Inferno GT, GT2 Race Spec-imag0142.jpg   Kyosho Inferno GT, GT2 Race Spec-imag0143.jpg
mrod is offline   Reply With Quote
Old 12-17-2013, 08:11 AM   #827
helivaguy's Avatar
Trader Rating: 42 (100%+)
What is the difference between the inferno gt and gt2
The only thing that is "still like new" is the box it came in..
Only a half gallon through it my Ass!
helivaguy is offline   Reply With Quote
Old 12-17-2013, 09:18 AM   #828
Winner's Circle's Avatar
The GT, sometimes called the GT1, is a short wheelbase car with Kyosho's original crappy paw type transmission. These transmission are noted for stripping 2nd gear very frequently.
The GT2 is the newer car that is longer wheelbase and it has the shoe type of 2 speed. This transmission is very reliable.
I have had both cars and I personally like the handling of the GT2 better. The longer wheelbase made the transition from on to off and back on throttle easier for me due to less forward and backward weight transfer.
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 12-17-2013, 10:06 AM   #829
helivaguy's Avatar
Thankyou but looking at both side by side what would be a dead ringer for the gt2?
Old 12-17-2013, 02:54 PM   #830
tonylunatic's Avatar
Assuming here.... From looking above both cars side by side dead ringer would be the rear center drive shaft the Gt2 would be longer the GT1 and the noticeable linger chassis.
GT1 would be closer in size to a buggy and Gt2 closer to truggy length.
I am sure some of the Kyosho experts in here can give you the most accurate info on this. Either way the Kyosho is the God father of GT/GT8 racing it a solid car and can be very competitive. I know a few that are and wanting to convert the newest Kyosho buggy in a GT.
L.R.P. Will be coming out with some option parts for the Kyosho GTs this next year. So be on the look out.
Serpent/Desoto Racing USA~Murnan Modified Motors~PTRC Racing Fluids~Flo-Control ~IGTHobbies.com
tonylunatic is online now   Reply With Quote
Old 12-19-2013, 07:46 PM   #831
Yb2fast's Avatar
Tony what parts ?? hint hint, maybe a 10 deg caster block ???lol...My GT1 is ready to kill !! Full CVD's etc !!
GT1/MP777WC, GT2 BRUSHLESS 110 MPH ++, GT1-VE MAMBA PWR, MP777-EBUGGY TEKIN, XRAY NT1, HB D8 HARA, LOSI EIGHT2.0, LOSI EIGHT-T 2.0, Visit my Ebay store RC NITRO DEPOT !
Yb2fast is offline   Reply With Quote
Old 12-30-2013, 10:43 PM   #832
Yb2fast's Avatar
Default GT1 IS BACK !!
Dust off all your GT1 and GT2's guys...KYOSHO GT IS ALIVE AND WELL !
I would like to thank STEVE POND (SteveP) from Kyosho USA for creating this thread and sharing his vast knowledge of the inferno GT cars, setups, what to do and not to do...Also Trevor from www.infernosonly.com for some serious parts advice over the phone on many occasions...What started life as $275 RTR barely used GT car purchased last summer with a stock Subara Rally body, I have now converted into a serious contender for the new ROAR GT class..I never felt I needed to abandon the car for a Serpent GT or Teamc car at no point at all, but believed the car that created the class can be updated with the "RIGHT STUFF" and be competitive with Serpent GT...watching the car as it went from RTR state to its current version I must say is like night and day, as I tested each new upgrade on track as they were installed !
Here are a list of mods !
1. MP777 light weight chassis.
2. MP777 radio tray with aluminum posts.
3. MP777 steering ackerman WC edition and Servo saver assembly (ball bearing upgrade not in picture, but installed currently !)
4. Dragon racing aluminum tranny mount, vented motor mount and CNC front hubs.
5. OEM CVD center drive shafts upgraded
6. OEM Front and rear light weight CVD's from the MP777.
7. Kyosho OEM aluminum gunmetal rear hubs.
8. 4 gear diffs with 50k diff oil front, 3k rear ! (per Stevep)
9. Front shock oil 1200, rear 1000 (per Stevep)
10. Upgraded to the new race spec Shoe type tranny ! (most needed upgrade !)
11. Evolva clutch bell with 16/20 pinions (vs stock 15/18) yes fits right on per Stevep..
12. Kyosho silver springs up front, and black springs in the rear..
13. OEM carbon clutch with light weight 34mm blue flywheel & 1mm springs..
14. SP sport brake pads with vented brake rotor ! (another must have upgrade..)
15. NOVA MAXY CINCO BT CERAMIC .21 5 PORT ROAR LEGAL MOTOR...
16. SWAY bars front and rear installed 3mm and 2.8mm
17. Replaced 90%of screws with metric hex heads.
18. JR Z9100S SERVOS for both throttle and steering....06 sec and 190 oz at 6v...
19. LIFE 6.6 v battery ...Protec RC perfect fit in batt tray !
20. SPEKTRUM DX4R PRO radio TX with DSMR at 5.5ms.... with the new SR410 DSMR RX...
21. OEM ASTON MARTIN BUMPER....hard to find
22. ALPHA SOFT shores for track days, MEDIUMS for practice..
23. Custom mounting of OEM braces for zero movement of the radio tray under breaking/acceleration..
24. 150cc GT2 fuel tank..
25. MP9 large fuel filter and large offroad gasline cooler.
26. 25% KOSMIC onroad fuel, product of Rino Lino in south FL !! yessir !
27. DRAGON racing rear aluminum toe bar at 2.5 deg.
28. OFNA DP1 Mclaren body.
29. EXCEED I.N.S. BOX
30. IFW334 LIGHTWEIGHT UNIVERSAL SWING SHAFT CVD 89.5 MM DESIGNED FOR MP777 ( 2 SETS NEEDED FOR F/R..)
31. IFW332 ALUMINUM KNUCKLE ARM INSTALLED WITH BUSHINGS.
32. IF312GM-01 GUNMETAL FRONT UPPER PLATE FOR 777/ST-RR EVO INSTALLED BUT NOT IN PIC (NOTE THIS WILL NOT FIT ON THE ORIGINAL MP7.5 GT1/GT2 CHASSIS)
33. FUEL SPLASH GUARD FROM MP777 PARTS TREE
34. SWEEP 50 SHORE MEDIUM OR ALPHA MEDIUMS WORK WELL FOR PRACTISE AND LONGEVITY.
READY FOR THE FORGASS STATE SERIES HERE IN FL, AND PAN AMERICAN GT AT HOMESTEAD RC SPEEDWAY...SERPENT GT WATCH YOUR BACK, CUZ BIG K IS BACK !
Kyosho Inferno GT, GT2 Race Spec-gt1-testing.jpg   Kyosho Inferno GT, GT2 Race Spec-gt1-layout.jpg
Old 01-02-2014, 05:05 AM   #833
helivaguy's Avatar
8. 4 gear diffs with 50k diff oil front, 3k rear.
9. Front shock oil 1200, rear 1000.
are these the typical or recommended settings for the igt?
Old 01-02-2014, 11:34 AM   #834
Hello guys, im a newbie from malaysia. Currently running on kyosho superten fw04. Im looking for parts to assemble the gt2. Do you guys have a store where they ship to malaysia with a reasonable price? Thanks!
faix is offline   Reply With Quote
Old 01-07-2014, 08:42 AM   #835
Yb2fast's Avatar
These seem to work the best...I think from the factory the front is 80k...I got 8 and 9 from Steve Ponds the threadstarter and Kyosho USA Director...cant ask for better advice from him...he knows Kyosho inside out : )
Car drove much better after doing 8 and 9 !
Old 01-07-2014, 08:44 AM   #836
Yb2fast's Avatar
GO TO www.infernosonly.com ...Trevor will take care of you !!
Old 01-07-2014, 11:42 AM   #837
Thanks bro! Looked at dollarhobbyz. Good price they have. Still lookin around. Ive got the chassis, servo tray and the turn buckle so far. Ehehe.
Old 01-08-2014, 10:51 AM   #838
djmorales's Avatar
Send a message via Skype™ to djmorales
Default chi-town kyosho GT2
good luck in homestead have a friend going to race they're getting out of this Chicago cold weather
Serpent GT cobra leisurehours Raceway local racer /slow is fast
djmorales is offline   Reply With Quote
Old 01-09-2014, 09:56 AM   #839
scary_jerry's Avatar
Good list of 'upgrades'..............to your list I would add a 'splash guard' to keep fuel off of your brakes. Kyosho has a couple available but I have also made my own. Fuel on your brake pads during a pit shop is not an enjoyable thing.
scary_jerry is offline   Reply With Quote
Old 01-11-2014, 06:39 PM   #840
Exclamation Need info
Someone could help on these?
I've been thinking to custom mod a 2 speed transmission and would like to seek your help for some measurement below:
1. length of the 2 speed shaft (part no. KYOIGW008-01)
2. diameter of the 2 speed shaft
3. outer length of shaft measure from drive cups end to end (measurement A of pix)
4. inner length of shaft measure from bearing to bearing (measurement B of pix)
5. Thickness of bearing
I appreciate very much if you could help me out on these measurement. TIA
ferrariGTR is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 07:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 02:55 PM
Tags
igt, inferno gt2, kyosho
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
SEO by vBSEO 3.5.0
