Like Tree5Likes
Old 09-26-2013, 05:18 AM   #781
aris's Avatar
Is anybody here using the upgrade shocks for GT/GT2?
How are they?
Are they bigger than the stock shocks that came with the car?
Thanx.
Aris
Inferno GT2. (Corvette C7.R)
Fg F1 Sportline (Vodafone Mclaren)
Exotek F1R3,Tamiya F104,
Sakura xi sport USGT
aris is offline   Reply With Quote
Old 09-26-2013, 06:18 AM   #782
JLock's Avatar
How are they?
Thanx.
Aris
Personally, I am still using the stock shocks with no issues. I have a friend that was using the Kyosho Big Bore shocks but he eventually went back to the stock shocks (he was having issues with the threaded shock collars moving during racing).
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 09-26-2013, 10:12 PM   #783
C-Trickle's Avatar
How are they?
Thanx.
Aris
I really like the Kyosho Shocks! They are super smooth and amazing build quality! I haven't heard of anybody else having that issue with collars on them? Any how, definitely more tunability. Switching your shock pistons on your stock shocks from the brass notched ones to plastic ones with holes will offer almost the same effect. If you have the cash, go for the upgrade! If not, just try changing out your shock piston's to plastic ones.
C-Trickle is offline   Reply With Quote
Old 09-28-2013, 06:01 AM   #784
JLock's Avatar
Just for note: I was referring to a buddy of mine that had some aluminum big bore shocks that the collars screwed themselves to the top of the shocks due to vibration. He later learned that the rubber O-ring in the collars were not thick enough to hold the collars in place on the set that he had. This is not an issue with the plastic shocks that come on the kits. He has since gone back to the stock plastic shocks and has not had the same issue.
Texas 5
Old 09-29-2013, 09:42 AM   #785
C-Trickle's Avatar
Hmmm. That's interesting. I actually have had to replace my O-rings on my plastic shocks. Of course, they were old as crap from a GT1!
Old 09-29-2013, 12:25 PM   #786
Yb2fast's Avatar
Best thing to do is upgrade the springs to IGW004-9002 front (silver) and 8022 (black) on the rears ! Stiffer than stock and car the drives better ! Here is a pic on my current GT1 track car...
GT1/MP777WC, GT2 BRUSHLESS 110 MPH ++, GT1-VE MAMBA PWR, MP777-EBUGGY TEKIN, XRAY NT1, HB D8 HARA, LOSI EIGHT2.0, LOSI EIGHT-T 2.0, Visit my Ebay store RC NITRO DEPOT !
Yb2fast is offline   Reply With Quote
Old 09-30-2013, 07:04 AM   #787
scary_jerry's Avatar
Smile GT/GT2 springs
Could the experts please respond.........
I was pursuing 'stiffer springs' and was told that both the 'black' and 'silver' springs were softer than the stock springs that have 'less coils'..........I had gone back to the stock springs on a few different tracks. No problems except the 'excessive caster angle' that comes free with Kyosho GT cars.
scary_jerry is offline   Reply With Quote
Old 09-30-2013, 07:28 AM   #788
aris's Avatar
What shocks fluid do you guys use?
I put 70w from losi. But car seem to shake on acceleration.
I find it too stiff.
Old 09-30-2013, 07:44 AM   #789
Smile
Check the wear on your 'diff cups' for a source for acceleration 'shake'.
I have always used 1000 wgt shock oil (temps usually > 80* F) Others go lighter but I don't see the need to.
CTrickle mentioned the use of different shock diaphragms over 'stock'. Keep oil weight 'constant' and work with 'mechanical' parameters.
Old 09-30-2013, 11:08 AM   #790
Yb2fast's Avatar
Originally Posted by SteveP View Post
My car is in a million pieces, but I think I recall everything that I've done to it.
4 gear diffs front and rear, 3.0 front stabilizer, 2.8 rear, TRW105 shocks with the IGW silver springs in the front, black in the rear (not stock, but black IGW spring). The front shocks are running 1200 Kyosho oil, and the rear 1000. The front diff is at 50K and the rear at 3K. In the front I'm running the H/B blocks for minimum caster, and I'm in the process of fitting some MP9 hub carriers and knuckles to reduce caster even further. In the rear, I run the upper camber link in the lower hole on the shock tower. The roll center geometry works better for me with the camber link in the lowest hole. I hpoe I got most of it covered, but I'm always trying new things because that's what makes me tick.
Scarry Jerry...Quoted from the "expert himself SteveP"...only thing I have not done was upgrade the shocks to TRW105....but the car is a lot stiffer now than with stock springs and has better traction on exit and turn in with my Alpha's....
Old 10-01-2013, 10:36 AM   #791
When I ran Kyosho I always used the stock shocks after trying several others. I ran stock springs until I changed to the black chrome rear spring , a step softer than stock. Like Jerry , I ran 1000wt diff oil in the four shocks.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 10-02-2013, 10:38 PM   #792
C-Trickle's Avatar
I changed to 6 hole Fioroni shock pistons on the stock shocks with 85 weight oil. I really liked the grip that gave me. Then ran stock front springs and the black chrome rears. Didn't like the silver springs at all!
Old 10-02-2013, 10:41 PM   #793
C-Trickle's Avatar
I'm digging the DIY upper chassis braces! What chassis is that on? I see that it's a 7.5 based chassis, just which particular one?
Old 10-03-2013, 04:57 AM   #794
Yb2fast's Avatar
Thanks..car handles like a dream with that current setup...That chassis is the Dragan racing Mp777....notice also I use the Mp777 radio tray which I like a lot better than stock with aluminum mounts...no more radio tray movement with brakes applied : )
Old 10-04-2013, 05:28 PM   #795
MugenJimbo's Avatar
Anyone running the hard shock towers? The front are not threaded for the upper pins ?
Suggestions ?
Kyosho mp9e Tki edition-speedpassion-tekin 1900-futaba
Kyosho GT2 Race-spec .25- savox
Futaba 4pks
Cars owned Frog, Turbo optima, rc10b2, b3, GTLX, MBX4XR Works, gtp, MBX5 pro-spec, MBX5t pro-spec, revo 3.3, MBX6 eco us spec
MugenJimbo is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
