Like Tree1Likes
Old 09-11-2013, 03:10 PM   #766
bassman2's Avatar
I see, so based on your reasoning....... any offroad clutches is "adjustable" in this case because racers can adjust the tension on each individual spring of the clutch shoe by using different thickness of the spring (0.9mm, 1.0mm or 1.1mm, etc) and Buku clutch uses the same principle of spring tension adjustment by using set screws for the sake of convienence. I just want to clarify that any offroad clutches are consider "adjustable" as well (based on your reasoning). Unless, we want to be more specific by using words such as "adjustable on the fly".....etc.
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 09-11-2013, 03:26 PM   #767
J-milz's Avatar
Trader Rating: 37 (100%+)
Anybody selling a blackhawk 2 speed?
💫XRAY addict💫 sponsored by the secret stash.....tee-hee-hee.
J-milz is offline   Reply With Quote
Old 09-11-2013, 03:30 PM   #768
Jspeed's Avatar
No Andy, once again you're not listening and wanting to start an argument.
Any externally adjustable clutch has a tuning advantage on the race track over a conventional spring type offroad clutch; because of the speed that it can be dialed into track conditions is much faster than changing shoes or springs. Hence affording more time between heats to prepare or just relax.
A guy with an externally adjustable clutch can tighten or loosen engagement by just turning screw(s) on the fly. As opposed to a conventional offroad clutch that must be opened up to make changes.
There's also a much more fine tuning window with externally adjustable clutched over regular buggy/truggy spring units.
In any case, the Werks & Buku clutches were made legal because they work well, last long and the owners of both companies came to the table when they were asked to help support GT racing's growth.
Instead of arguments about it with me, just thank your sponsor Dave for making a great product and supporting GT racing too.
Take care.
Jspeed is offline   Reply With Quote
Old 09-11-2013, 03:37 PM   #769
Jspeed's Avatar
Stopped selling them a while ago, was an excellent rig.
You can build your own using Evolva parts and VS058 clutch bell.
Center shafts depends upon if your chassis is IGT1 or IGT2 length.
Check with Lee at Winner's Circle, he should be able to help you.
Good luck!
Old 09-11-2013, 09:20 PM   #770
bassman2's Avatar
Take care.
Arguing? Who was arguing? I thought we were just sharing and exchanging thoughts here on this great forum.
Old 09-12-2013, 01:45 AM   #771
Jspeed's Avatar
Really andy, all those underlined words in that rambling aren't argumentative in nature?
Dude, you know the adjustable clutches are better for track use.
You know it's easier to just turn a few screws in the flywheel to adjust the spring pressure on a Werks or Buku clutch, compared to having to take the engine out of the chassis, removing the clutch bell and changing the springs or shoes to make adjustments to a conventional off-road clutch.
Nobody is saying they're not legal at our events andy, just please stop trying to act like there's not a good reason you're using them in your car instead of using the stock buggy clutch unit that comes with your chassis from the factory. lol
Like I said before andy, thank Dave for making a really nice clutch set-up for racing and for helping to support GT racing's growth.
Old 09-12-2013, 04:53 AM   #772
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Just move on Andy, no point in putting coals on the fire.
MantisWorx is offline   Reply With Quote
Old 09-12-2013, 11:14 AM   #773
I was ready to drop in the engine, only to realise I need spacers. I ordered new motor mounts, 1mm and 2mm losi Alum. spacers(washer style). And ofna engine
mounts. do you think the engine will now fit with these spacers?!
Ps. I also got alum blue shoes, 1mm springs, blue flywheel, ofna clutch nut, bell shims...
I hope I am all set :s
Thanks for helping out a beginner.
Originally Posted by Modfriendly View Post
I just bought a LRP .28. However, I am not sure if the stock clutch bell would fit this engine? Does any one know which two speed bell can fit?
Should i swap clutch set up as well? What are your thoughts?
Modfriendly is offline   Reply With Quote
Old 09-12-2013, 11:23 AM   #774
J-milz's Avatar
Good luck!
Thx!
Old 09-12-2013, 12:10 PM   #775
Jspeed's Avatar
Thumbs up
Thx!
No problem, send me a pm with your email and I'll try to send you the original Blackhawk transmission instructions, so you can build the bullet proof unit for yourself, ok
Old 09-12-2013, 01:51 PM   #776
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
Post #369 of this thread, shows the 2 speed you're looking for.
Kyosho Inferno GT, GT2 Race Spec
FREELANCE_RCer is offline   Reply With Quote
Old 09-12-2013, 02:03 PM   #777
J-milz's Avatar
Thx
Old 09-13-2013, 12:47 PM   #778
MantisWorx's Avatar
It appears that there is a cure for internet cancer!! LOL
Old 09-13-2013, 02:24 PM   #779
Aught-Six's Avatar
Aught-Six is offline   Reply With Quote
Old 09-14-2013, 08:39 AM   #780
CMT
Default Spinout
CMT is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
