Like Tree1Likes
Old 06-08-2012, 06:06 AM   #46
VexVegaz's Avatar
Thanks Steve!
I got the parts on my cart, but before I order, can you recommend a logical gearing for my gt2 with that torqy lrp .30? im thinking 17/20 (part numbers?) to smooth out the engines power.
Serpent Cobra GT > Serpent 748TQ Serpent S411 Serpent SRX2 Sanwa MT-4 Novarossi Hobbywing Epic D3 Savox > Sweep Tires > BrooklynHobbies.Com
For RC TShirts and Custom Sponsor Shirts & Hoodies, Please Visit www.veytrex.com
VexVegaz is offline   Reply With Quote
Old 06-08-2012, 12:56 PM   #47
SteveP's Avatar
Vex, it's hard to say, but if the engine has big low-end power, I'd suggest 16/20T with .95 clutch springs and a conservative setting on the two-speed.
SteveP is offline   Reply With Quote
Old 06-08-2012, 01:01 PM   #48
VexVegaz's Avatar
thanks steve, do you have the part number for that 16t 1st gear?
Thanks again!
EDIT! the old clutch bell is 20t, will it fit on the new 008 clutch bell?
Old 06-08-2012, 01:17 PM   #49
SteveP's Avatar
Vex, I'm sorry, the IG112-16 is not out yet. It's one of the prototype gears I tested. Perhaps I can send you some of the optional gears to test. I have small selection of prototypes that you can run and give feedback if you have time. The 20T second gear is IG113-20.
Old 06-08-2012, 01:28 PM   #50
VexVegaz's Avatar
ok order is placed, should have them in by the middle of next week. I would love to test them out for you, and I believe i'm articulate enough to be able to communicate my results.
Old 06-08-2012, 06:15 PM   #51
SteveP's Avatar
Vex, send me a message (I turned them on temporarily) with your information, and I'll send them out to you.
Old 06-08-2012, 06:23 PM   #52
VexVegaz's Avatar
sent Steve, thanks again!
Old 06-09-2012, 05:40 AM   #53
Talking
Originally Posted by SteveP View Post
I prefer the TRW105 shocks for the fact that the machined shock bodies and the all of the hardware are higher quality. The shocks are more durable and more consistent than the stock ones, so I would suggest adding them to any car. They're not going to result in much faster lap times, but they will make the performance more consistent, which may improve your overall result.
Vex, even though it's more money, I STRONGLY suggest you upgrade to the IF21/IF106 ring and pinion gears for the front and rear diffs. They are worth it if you have extra power in the car, or if you drive it really hard. They're made from high-carbon steel and are legendary for their durability.
Another thing you may consider for your car is new bulkheads. The molded parts on the GT2 are made by Kyosho using the same material, machines and staff that make the MP9, so they're good, but being sure you have the latest bulkhead is a cheap and safe insurance policy for your optional gears. The IF112D bulkhead was developed for the STRR Evo, and it's STRONG. The bulkhead was the reason we saw damaged gears in the previous trucks, and the strength of the IF112D is specifically increased to prolong gear life.
The stock gear sizes of the IGW008 are 15/18 and 43/46. Let me know if you have problems finding the shims. I'll be sure to get 'er done.
Thanks Steve...already picked them up...gonna test 'em out today I also second the the straight ring gear/pinion. It's an absolute must have especially if you race...the spiral ones will eventually break under heavy braking/acceleration...
V-one-RR Evo,V-one-RRR (WC hopped-up),2007 Evolva,
Spada 09,MR-02,MR-03
Inferno GT2. Serpent Cobra GT
KF01 - F1, Serpent Viper 977WC, Serpent Natrix 748
1FastVW is offline   Reply With Quote
Old 06-09-2012, 04:56 PM   #54
jeffrey863's Avatar
over revved my motor today and snapped the connecting rod today guys
would it be better to go in and replace it or just buy the spec race motor??
2007 GT500 <552 RWHP>
92 C1500 dumped and cam'd on 18's
74 Camaro NASA AIX build
Inferno GT2 box stock is how I rock
jeffrey863 is offline   Reply With Quote
Old 06-09-2012, 09:25 PM   #55
mosaics12's Avatar
IMO i would get an aftermarket motor. there's a lot more better motor for d same or little bit more $$$.
kyosho inferno GT2 pro.. kyosho ultima sc.. HPI savage X.. tamiya m-05 pr
mosaics12 is offline   Reply With Quote
Old 06-10-2012, 03:53 AM   #56
Winner's Circle's Avatar
I replaced my kit motor with a LRP .28 and I have been very satisfied with the performance of this engine. We have to run an engine that cost less than $200 and be no larger than a .28 in size. This engine meets both requirements and it is extremely fast with a lot of low end torque.
Lee
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 06-10-2012, 05:36 AM   #57
jeffrey863's Avatar
Now If i were to run in the GT class in some races, There wouldn't be a problem with running the aftermarket motor as far as rule violations correct??
Also do the aftermarket motors come with better clutches? I was in the process of breaking in the BRAND NEW 3 shoe with race springs from infernosOnly.com lol
Just my luck haha
Old 06-10-2012, 09:48 AM   #58
VexVegaz's Avatar
As what many have already mentioned, there's a ton of engines that can be picked up that would be a huge upgrade to the stock engines at a relatively cheap price.
However, I strongly suggest that if your new to nitro and/or new to the car, replace the broken connecting rod and use that to better familiarize yourself with the car and see how far you can take it. The hobby will let you know when your driving skills surpass the engine's potential and that's usually the best sign to upgrade into a more powerful/faster engine.
One thing about this hobby, you can always buy your way into something faster but if your driving doesn't match the engines power or speed, you can place yourself in issues and further expense.
jeff, motors rarely come with clutches and springs. they need to be purchased separately.
Old 06-10-2012, 11:00 AM   #59
Just my luck haha
It sounds like the clutch you are going break in is a good clutch. I am running a 3 shoe clutch on my car with carbon shoes and 1.0mm springs. I have tried lighter and stiffer springs and for me the 1.0mm works best. I get great shoe life with this set-up.
Regarding the engine - check with the club you plan to race with to see if they have special rules. Our club currently requires that the engine have a street price of under $200 and the LRP .28 I am running cost about $170. To the best of my knowledge the engine I am running is legal at National events.
Lee
Lee Muse
Old 06-10-2012, 11:08 AM   #60
C-Trickle's Avatar
The engine debate for the GT class is endless! Basically decided on a budget for an engine/pipe, what you want from an engine, and then we could better help find something that fits your needs.
But imho its not worth keeping the GXR-28 going, better off replacing it with a nicer engine. Plenty of fine engines can be had for <$200. Once you get in the $200-$300 range, I don't feel the speed goes up much more, but the engine build quality and tune-ability does.
C-Trickle is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
