Old 05-22-2013, 05:03 PM   #526
lagos's Avatar
seeing the bad lateral movement that center diff mounts and servo plate were doing when I use the brakes and the fact thats change gear mesh adjustment and affect the brake efficiency ...i have develop a simple reinforcement brace to stop this using kyosho brace parts ....
the positive points are a better brake action/power/adjustment , and a perfect and consistent gear mesh ..... small , simple and efficient ... reduces lateral movimente to almost ZERO
lets see ....
att
Guga
JQ - THE Car GT
Inferno GT RR
Thanks to ALPHA RC TEAM !!!
lagos is offline   Reply With Quote
Old 05-24-2013, 12:55 PM   #527
Default kyosho inferno gt 2 race spec
just bought the brand new inferno gt2 race spec with the ke25 engine.. im looking to upgrade my motor what Is the best and most powerful motor that is recommended for this car.
ant88man is offline   Reply With Quote
Old 05-24-2013, 01:42 PM   #528
scary_jerry's Avatar
Smile
I'm enjoying a chuckle from this one.......the Kyosho GT/GT2 is sold as an "entry level" car. You need to define your intended 'target'......racing....bashing.....don't know/care got money to play with.
There are motors that will end up shredding tires/doing nothing to help you do better 'on the track' but giving you the 'WOW' factor until you put it away or sell it because it served no specific performance goal.
The selection is almost endless for the GT power niche. Most people I race with have 'gravitated' to the 5 or 7port Nova Rossi. ($200-250) This is the choice for most of the racers I've run with. If you need 'total insane speed', I won't inject any stupidity here..........I've cured myself of that by trying to keep the car 'tractable and track worthy'. You can bump to the 9port Nova and if you can learn to compete and win with the 'big boy' features of that monster, feel free to keep us posted of your success.
GT cars are fun but you'll need to look over someone's shoulder to 'take notes'......don't forget tires to keep the thing on track. A 'killer motor' with those stock Kyosho tires is just horrible.........
Picco, LRP, Sirio, etc, etc. have very popular acceptance. I just see many more smiley faces with Nova lately on the GT scene. You can't replace the Sirio S24T I have from the 'red' PRO version of the Kyosho car for less than $200 but the little Nova 5t pulls past me on the straight.
scary_jerry is offline   Reply With Quote
Old 05-26-2013, 10:11 AM   #529
Yb2fast's Avatar
The Nova 5 port you cant beat for the $$$ but I must say the GT1 shorter chassis is better for track duty if that is your direction...I just installed an RB .21 R11 Rally in my GT1 !! and I have both GT1 and GT2 btw...
Yb2fast is offline   Reply With Quote
Old 05-26-2013, 10:13 AM   #530
Yb2fast's Avatar
lets see ....
att
Guga
Thanks for the tip !!! Im building a race ready GT1 so this will help : )
Old 05-28-2013, 12:33 PM   #531
Yb2fast's Avatar
Default GT1 Race Ready !
The GT1 build is done and runs awesome !! Here are a few pics and tricks ...
1. RB R11 Rally .21 motor.
2. Kyosho Race spec 3 shoe clutch assembly.
3. New upgraded tranny.
4. New Titanium center shaft
5. Dragon Racing lightened chassis from the MP777
6. Dragon Racing 2.5 deg. toe and caster blocks.
7. Upgraded Kyosho sport SP brake kit .
8. Airtronics and Futaba Steering and throttle servos.
9. Ofna fuel cooler.
10. Kyosher front and rear sway bar kit.
11. MP777 radio tray with upgraded aluminum supports.
12. Spektrum DSM2 RX TX.
11. Alpha rubber tires.
12. Ofna DP8 Mclaren body
13. Potek 6.6v LIFE Rx Batt.
14. Protek and Dynamite steering and throttle servo horns...
15. Uprgraded turnbuckles and upper A arms from Race spec.
16. Dragon racing 2 piece engine mount with heatsink.
17. Kyosho Aston Martin Front bumper
18. Novarossi Pipe and CARBURATOR from another .21 !
19. 150cc Fuel Tank.
Running the State Florida FORGASS series this fall against all Serpent Cobra GT's...wish me luck...lol...
Kyosho Inferno GT, GT2 Race Spec-resize2.jpg   Kyosho Inferno GT, GT2 Race Spec-resize1.jpg   Kyosho Inferno GT, GT2 Race Spec-resize3.jpg   Kyosho Inferno GT, GT2 Race Spec-resize4.jpg
Old 05-28-2013, 02:30 PM   #532
lagos's Avatar
go go go !!! show !!!
JQ - THE Car GT
Inferno GT RR
Old 05-28-2013, 05:43 PM   #533
Yb2fast's Avatar
LOL...IT REALLY GOES WITH THAT RB MOTOR !!! WE WILL SEE IN SEPTEMBER...Not giving up on the car that started the class !!! Teamkyosho....
Old 05-28-2013, 07:20 PM   #534
MantisWorx's Avatar
Trader Rating: 27 (97%+)
I will have my IGT for R+D this saturday!
Lagos how did the zero hubs work out?
MantisWorx is offline   Reply With Quote
Old 05-28-2013, 08:33 PM   #535
lagos's Avatar
the hubs works great on the theory... lot off tire stay on the ground on the total steering in a good angle .... proportionally when the weel is turning ..... caster angle is the chassis kickup only ....
I left the camber at 0 degrees and studied the movements of the wheels when turned ... I really liked it ... reactions will change dramatically
not tested on the track because I did not get a good service on the holes of the hubcarriers and have to redo from scratch ......
the bubs and bushs fit perfect , but i did small errors and it changed the front width ... i make a mistake with these first pieces, i wrote down everything I have to modify .... the next ones will be good for racing ok ...
hubs can be used fliped L/R to a better steering linkage position or in a normal position
i will sand you some photos ok ....
igt is coming to you and it was a gooooood notice !!!
Guga
JQ - THE Car GT
Inferno GT RR
Old 05-29-2013, 09:46 AM   #536
Default best motor for kyosho inferno gt2 race spec
I just bought the brand new inferno gt2 race spec nitro.. what is the best motor I can put in the car .... im looking to make it a good track car. I am going to buy the aluminum arms and the dragon chassis for it . im buying the alluminum arms cause I will have to weigh down the car when I put the more powerful motor in it plus I will be upgraded the servos to digital high tourque servos.
Old 05-29-2013, 11:45 AM   #537
lagos's Avatar
first 0 degree hub carriers ... the next will be stronger and dont will change the front width .... but the concept is it ok ...
JQ - THE Car GT
Inferno GT RR
Old 05-29-2013, 01:58 PM   #538
H0LESH0T's Avatar
Does anyone know if the Kyosho Subaru or Ferrari body is still made?
H0LESH0T is offline   Reply With Quote
Old 05-29-2013, 03:23 PM   #539
No to both. They have been discontinued, so unless you can find someone willing to part with one you are out of luck.
rfordrford is offline   Reply With Quote
Old 05-29-2013, 03:26 PM   #540
Great looking forward to getting some better options for this car as I don't want to give up on it just yet.
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 07:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 02:55 PM
Tags
igt, inferno gt2, kyosho
SEO by vBSEO 3.5.0
