Like Tree1Likes
Old 01-22-2013, 07:33 PM   #346
were did you get your bodys at??
Big-air420 is offline   Reply With Quote
Old 01-23-2013, 01:53 AM   #347
I got the R8 from Amain Hobbies and the Alpha R1 for maxvelocityracong.com.
rfordrford is offline   Reply With Quote
Old 01-23-2013, 09:15 AM   #348
Does anyone know If they make a 40/46 spur gear set for the 2 shoe transmission on the race spec? If they do what is the part number. I have all of the pinion gears from 14 to 22 and want the 40/46 spur to have more options.
Old 01-23-2013, 11:00 AM   #349
scary_jerry's Avatar
Smile
Sadly.....the answer is NOPE.......and don't hold your breath. The arrival date on those has something to do with the 'second experiation of the Mayan clock'.
scary_jerry is offline   Reply With Quote
Old 01-23-2013, 11:28 AM   #350
MikaR's Avatar
40/46 spurs fit only to the original 2-speed finger type, not to the shoe type 2-speed IGW008 that comes in the race spec. Of course you can run this original 2-speed also in race spec but it is not as durable and may strip gears occasionally.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 01-23-2013, 01:59 PM   #351
Thanks guys I guess I'll have to just do without. I will just have to go with the 17/21 setup and be happy, because I don't want to go backwards and be disappointed.
Old 01-23-2013, 02:47 PM   #352
Default Airtronics race in CA
GT guys,
March 22-24 is one of the big races in sunny CA. Check out the onroad Airtronics race thread.
Questions was asked if GT cars will be racing,
There is couple on the list already,
and here is the latet post on that.
alright!!!!!!
calling all GT/IGT drivers its going to be a fun race
HENRY C
This is parking lot track but it feels and seems more like a perminent track as the area used has been the same for years, the traction is awsome, the layout is huge with a nice back straight to let your motors sing down the back straight.
The Nationals will be held at this track in August so the competition is stacked as everyone is warming up for that.
Check it out.
mauimaxx is offline   Reply With Quote
Old 01-23-2013, 04:34 PM   #353
manny021803's Avatar
any pic or video for the track???????
Originally Posted by mauimaxx View Post
GT guys,
alright!!!!!!
HENRY C
Check it out.
NEW YORKERS RACERS TEAM(NYRT)
bruckner hobbies/sweep tire/desoto racing/bu-ku clutch
NYRT#4
NYRCC #124
manny021803 is offline   Reply With Quote
Old 01-23-2013, 07:43 PM   #354
Smile
If you ever have a 40/46 gear set in the car next to you as you enter the big straightaway and it grabs 2d gear...........you'll give it one more thought.
I've found that if you monitor your time/life/abuse factors and do 'preventitive maintenance' it's an okay setup. Yes you can strip some gears if you're beating it pretty hard but darn, that shift is fun. A torquey 'grunt monster' .28 will kill the 'finger clutch' quicker.
__________________________________________________ _____________________________
And THANKS to MauiMaxx for the 'heads up' on the addition of IGT at the Airtronics Race in LA. ...........I'm IN!!!!!
Old 01-23-2013, 08:50 PM   #355
nitrodude's Avatar
GLARCRC
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 01-23-2013, 09:35 PM   #356
*1speedy's Avatar
GT guys,
alright!!!!!!
HENRY C
Check it out.
Interesting............ Will look at the schedule, I mean ask the Boss
🏁🏁🏁 🏆🏆🏆🏆 2013 XRAY XB9 GT8 🏆🏆🏆🏆 🏁🏁🏁
2013 & 2014 R.O.A.R. REGION 1 & NY State GT8 CHAMPION!!
....................... 🏆 SPONSORS 🏆 .....................
ABSOLUTE HOBBYZ / Engines Modded by The Nitro Shop
*1speedy is offline   Reply With Quote
Old 01-23-2013, 11:22 PM   #357
MikaR's Avatar
Yes, that's indeed pretty cool.
Have you guys tried the Dragon Racing's metal gear set? Will it provide more durability with the finger type clutch?
Old 01-24-2013, 09:21 AM   #358
I've heard bad things about it. Unless they have revised it it will not give the results you are looking for. I've not had 1 good review.
Old 01-24-2013, 09:57 AM   #359
Winner's Circle's Avatar
The only transmission solution for the Kyosho cars is the 2 shoe type. I tried every option on the finger type transmission and I either stripped the plastic gear, broke the metal gear, tore the pin out of the gear, or broke the finger.
I am running a Blackhawk transmission in my GT2 (made from Evolva parts) and I never have a problem with it. This allows the use of 44 or 45 gears for 2nd gear and 47, 48 or 49T for 1st gear. Unfortunately the Blackhawk is no longer available but you can still build your own Evolva based GT transmission if you are unhappy with the new Kyosho shoe transmission.
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 01-24-2013, 12:04 PM   #360
Smile trans/metal gears
We've got a racer that did his own buggy conversion from a Hot Bodies buggy. It actually has a metal gear trans. He won't part with it even though he has constantly had 'mysterious' issues............flywheel comes loose, screws shake out of trans clutch, engine clutch 'gremlins', etc.
I stayed away from the metal gears for my understanding of the 'shock factor' they impose on the engine crank/bearings, the weight of the rotating mass etc. It's an ambitious venture for Dragon (bless them!) but not all ideas 'float'. That little 'finger' on the clutch mechanism can only handle ......so much.
I wish that Blackhawk tranny shaft was still available..........if anybody has the specs..........pm me.
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
