Like Tree5Likes
Old 11-22-2012, 09:43 AM   #301
JLock's Avatar
Originally Posted by Chris K View Post
From Scary Jerry on another thread:
All I could say was wow. The TeamC....(OFNA)....turns quicker than my Kyosho GT but I'm hoping Kyosho addresses the issue with new caster blocks...hint...hint...hint.
I wonder if Kyosho might already have some different caster blocks somewhere in their HUGE parts catalog???
Steve???
Someone????
Thanks!
Chris,
Maybe he has a bad setup on his Kyosho, we don't know. I know the Kyosho isn't the end-all-be-all, but I have had pretty good success with mine, making a lot of A-mains with my dated chassis. It is all at what you make of each car, good and bad point aside.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 11-28-2012, 06:28 AM   #302
@JLock
Am I right, that you are a member of Ipanema? Last week I have send a query to Ipanema and recieved no reply.
My questions were:
1. Are the GT slicks available with black BBS style rims? Imagine white rims on a Aston Martin DB9 R with vitaphone painting. Looks pretty silly.
2. I am here in Europe (Germany) and I asked for retailers - or direct purchase from Ipanema.
Could you help?
Many thanks,
Marco
Butzemann is offline   Reply With Quote
Old 11-28-2012, 06:49 AM   #303
Originally Posted by Butzemann View Post
@JLock
My questions were:
Could you help?
Many thanks,
Marco
I have seen the Black rims before. Most just use the white ones. But I know that if you want then in black Ipanema will get them for you.
jneg is offline   Reply With Quote
Old 11-28-2012, 11:12 AM   #304
JLock's Avatar
@JLock
My questions were:
Could you help?
Many thanks,
Marco
Yes, Ipanema slicks are also on black BBS rims. I have several pairs of 50 shores 41mm and 47mm on black BBS rims in my possession as of this post. The US distributors for Ipanema are Bruckner Hobbies and Winner's Circle, both have websites that you can order from them direct. If they don't have them in black, PM me here on RC Tech and we can work something out to get you some black BBS wheels.
Texas 5
Old 12-29-2012, 01:01 PM   #305
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
Just a little something I've been working on. Picked up a great deal on an original IGT from a hobby shop owner getting rid of all his extra RCs. Since I'm not racing it, I preferred the long look of the IGT2 wheelbase, so got to thank Chris K for helping out with making it a painless swap.
Really can't wait to get this OS .40 fired up to compare to its smaller brother, the OS .26 in the FW04.
Dan is offline   Reply With Quote
Old 12-29-2012, 01:10 PM   #306
Dan
Dan's Avatar
And for those wondering what is required for IGT/IGT2 conversion, the differences are not just chassis and center rear dogbone. The front center dogbone needs to be changed as well. In addition, the IGT2 uses a longer rear chassis brace. I have the original IGT rear brace on mines and it will line up with one of the holes, but it is hitting the motor mount plate. I will have to shave it or put in a longer tie rod to move up to the next hole.
I also imagine the steering link from rack to servo will need lengthening (seeing as how I needed a longer center front shaft going to the longer wheelbase) I haven't mounted up the radio tray yet though.
Old 12-30-2012, 01:00 PM   #307
Hi guys.
Just interesting about stock KS200 servo.
Is this servo durable? Or i should upgrade it to Savox, Futaba, ect ?
igoris is offline   Reply With Quote
Old 12-31-2012, 12:37 AM   #308
duh702GT's Avatar
Send a message via ICQ to duh702GT
Hey guys I just picked up a novarossi 21 for my IGT what clutch and flywheel should I get for this set up. It's going to be a bump start obviously.
duh702GT is offline   Reply With Quote
Old 12-31-2012, 04:14 AM   #309
KYOIFW110 flywheel,
KYOIFW53 springs,
KYOIFW339 aluminium pads.
Old 12-31-2012, 04:15 AM   #310
here is my GT2's:
1. Sirio S21RR STI, HD aluminium clutch pads, Efra2058, new type shoe trnsmission, HD air filter, Big fuel filter, front and rear swaybars, 10 spoke rims with slicks shore 45.
2. Sirio S24T, HD aluminium clutch pads, Efra2057, new type shoe trnsmission, HD air filter, Big fuel filter, front and rear swaybars, 10 spoke rims with slicks shore 45.
3. GT2 LE, Sirio S24T, Efra2013, new type shoe trnsmission, HD air filter, Big fuel filter, front and rear swaybars, 10 spoke rims with slicks shore 45, front UJ, oils: front- 100.000, rear- 20.000, shocks- 500.
full assembling process of LE:
http://kyosho-club.lt/forum/viewthread.php?thread_id=5
Old 12-31-2012, 05:22 AM   #311
Originally Posted by igoris View Post
Hi guys.
Stock servos make decent throttle servos but not steering servos. I run multiple GT cars so I stick with one servo the Savox 1268, to make them all react similar. My setup has been a 1268 for steering and a 0252 for throttle for a good while now. Can't go wrong with this setup for Kyosho, Team C or Serpents. The stock will work but no where near a Savox.
TerribleTy is offline   Reply With Quote
Old 12-31-2012, 05:29 AM   #312
I'm not 100% sure that the official rules dictate the following but our local club enforces it. We run the stock flywheel to the kit. The only thing you can change are springs and shoe compound. This was done to try and keep the cost low in the beginning but like I said I'm not 100% sure its still around. The Kyosho stock clutch set-up is money, even better is their 2 speed.
What 21 did you get? Im running a Novarossi 35 Plus Tuned and it is a flat out animal. During Timezone last year we had a $200 motor rule and we found the Novarossi N21-5T. The 5T is the best motor for GT you can get for the money flat out. That little purple monster screams!
Old 12-31-2012, 07:15 AM   #313
OMG then i should upgrade all KS200 in my collection: 6x in GT2's, 2x in RRR Evo.2, 1x in RB5 SP2, 1x in DRX VE (now installed stock KS201) so, 10 pcs
Old 12-31-2012, 10:19 AM   #314
Order me some too! If you like the stockers more power to you, I dont. Driving styles differ greatly and the stock servos dont respond to my inputs like the Savox does.
Old 12-31-2012, 10:49 AM   #315
duh702GT's Avatar
Actually Ty that's the motor I bought 35+21 tuned... lol good I want it to be a monster that's why I got it. I'm not racing at a track yet so I don't have rules to follow. I know about the under 200 and all that for gt class rules.
KYOSHO INFERNO GT1 + novarossi 35 plus 21
RC10GT + OS max 18 + shelf queen
HPI SAVAGE XL 4.6 + bashing toy
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
