Like Tree2Likes
Old 07-05-2012, 10:59 AM   #181
*1speedy's Avatar
Default Brakes
Sewerdog,
Cole is correct having brakes on the front and rear is for looks or balance only it does not effect front or rear braking alone it effects them equally.
The 2 speed is NOT A DIFF.
Think about it for a min u will get it.
🏁🏁🏁 🏆🏆🏆🏆 2013 XRAY XB9 GT8 🏆🏆🏆🏆 🏁🏁🏁
2013 & 2014 R.O.A.R. REGION 1 & NY State GT8 CHAMPION!!
....................... 🏆 SPONSORS 🏆 .....................
ABSOLUTE HOBBYZ / Engines Modded by The Nitro Shop
*1speedy is offline   Reply With Quote
Old 07-05-2012, 11:10 AM   #182
*1speedy's Avatar
Originally Posted by C-Trickle View Post
Do 10k in the rear diff. Then adjust the feel of the car by changing the front diff fluid around. 30k-60k is about the range. I've really liked the feel of 40k in the front with 10k in the rear.
Cole here is another suggestion
Run the front diff with a Very Thick front diff oil 120 or higher and adjust the steering from the rear with 30 or 40 weight. or whatever you want to try. Works great for us. Kinda like what a common TC with front and rear diffs would do
Give it a shot worst you can do is blast me if you dont like it I have tough skin
Options are Good
Old 07-05-2012, 11:18 AM   #183
C-Trickle's Avatar
Options are Good
Wha??? Like 30k-40k in the rear or literally 30wt-40wt? Blowing my mind right now haha.
I tried the thick fluids on my GT1 last year, didn't really do so well on our tight tracks. But I may try it with this GT2.
C-Trickle is offline   Reply With Quote
Old 07-05-2012, 11:32 AM   #184
russo, what r u not telling us...a new car???
raptor svt is offline   Reply With Quote
Old 07-05-2012, 12:09 PM   #185
sewerdog's Avatar
You're correct it does have front and rear brakes. But the shaft connecting the front and rear differentials is a solid shaft. There is no way for the front and rear differentials to spin at different speeds. So by adjusting the front and rear brakes differently all you are doing is heating up that side of the brakes more than the other brakes. If there was a center differential like a buggy/truggy then you could adjust brake bias, but the 2 speed shaft is a solid shaft, so no brake bias.
Thank you cole, that makes sense now,ill give what you say a try and let you know
CARD BOARD BOX RACING
sewerdog is offline   Reply With Quote
Old 07-05-2012, 12:12 PM   #186
sewerdog's Avatar
Memlar, just have your stuff ready lol
Old 07-05-2012, 12:19 PM   #187
sewerdog's Avatar
Options are Good
ill see how it goes will go 120 fr 40 rear to start
Old 07-05-2012, 12:21 PM   #188
spanking time...cya next saturday
Old 07-05-2012, 12:41 PM   #189
sewerdog's Avatar
yes, what do you have?
Old 07-05-2012, 01:12 PM   #190
3 gt's faster then urs...
Old 07-05-2012, 02:13 PM   #191
san.'s Avatar
Trader Rating: 60 (100%+)
Ouch!!!1!
Can't wait til next saturday!
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 07-05-2012, 02:48 PM   #192
Is this the diff cup people are saying is the hot set up?
http://www.amainhobbies.com/product_...ferential-Case
With these diff gears?
http://www.amainhobbies.com/product_...Conversion-Set
Brett Adams
Mugen MGT7
o.s. savox futaba
66 Box Nova all motor LSX
1966ss is offline   Reply With Quote
Old 07-05-2012, 02:56 PM   #193
C-Trickle's Avatar
Yes on the differential gears, no on the diff case. I've never had a problem with the new Kyosho differential cases. The old ones were all plastic and the right side bearing holder would bust off. But now they have been updated to partially metal construction, 10 times more reliable. You could probably use that metal case, but I don't think I would bother.
Old 07-05-2012, 04:51 PM   #194
^thank you much
Brett Adams
Mugen MGT7
o.s. savox futaba
Old 07-05-2012, 05:00 PM   #195
I'll have to add 2 diff cups to my order. I have a gt1 that I wanna make race ready. Currently it's stock gt1 with front swing shafts,20* c hubs and kyosho special turn buckles.
What chassis braces should I go with? I will be running the gt1 chassis so I think my only option is the kyosho round tub style. Dragon racing (eBay company) has aluminum ones but I'm unsure if they will fit
Brett Adams
Mugen MGT7
o.s. savox futaba
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Racing in Chaplin CT this weekend!!! AndrewNicholas Racing Forum 476 09-10-2009 06:41 PM
Forgass March 7th and 8th, 2009 - Kissimmee KRaceway R*R*R*Pinard Florida Racing 189 03-16-2009 01:55 PM
Tags
igt, inferno gt2, kyosho
