Receiver Battery
Receiver Battery
Hi all
I have 2 cars ( Serpent 960 and Mugen MRX4 )
I would like a good option for receiver power ? Lipo or li-fe ??
how to fit or where to buy from ??
Regards
Regards
LiPo will usually require a regulator to reduce voltage from 7.4 to 6V and it's just another thing to go wrong and more wiring. While I havent had problems, many have and it's not worth frying your electronics with too much voltage. In contrary, there are reports of drivers using a LiPo 7.4V without regulators, I personally wouldnt do it.
There are a lot LiPo/LiFe receiver batteries easy to find with the size of a 5 cell NiMh pack.
i run the IP Li-FE packs 1450 mah, can be found on ebay and some HK shops.
personally i wouldnt go back to NiMh after using Li-FE. the 960 is what year ? the 960 08 you can use the brass battery tray, its a snug fit for the LiFe pack, and i use the same packs for the 733 /747 .
Not familiar with the 960. Go for the LiFe @ 3.3V per cell (6.6V 2S) and try to get more than 1000mah, measure dimensions for the smaller unless they are completely different then it's two batteries.
All depends on what receiver and servos you use as to whether or not you need a regulator. If you run the latest high end receivers from KO, Sanwa, Futaba etc and high voltage servos designed for LiPo 7.4V then you don't need a regulator. I've run Lipo for over a year now in 1/8th IC off-road without a single failure. Maybe I've just been lucky.
