Exhaust Header
Hi all, can anyone explain what problems/ symptoms I might encounter if the exhaust header is cracked.
Well, that is an easy one. You will experience loss of power at high r's. You will also notice a lot of oil all over your car. It will idle poorly. I dont think that I need to go on. The best thing I can tell you is to replace it.:cool:
Thanks Ballpy, motor is cutting out completley at idle & runing very erratically at mid/high end, have already ordered new header just wanted to check that Iv'e diagnosed the problem correctly. ;) :nod:
what about if your header has a small dint in it:confused:
sausage_link
If it's a small dent, it probably won't cause any problem. If it is large enough to restrict exhaust flow, the engine will run hotter due to the restriction. You should replace it or try to bend it back if it's restricting. |
