Remove 14.5 bearing with new Hudy bearing puller.
Can you remove 14.5mm bearings with the Hudy Ultimate Engine Tool Kit (.21 Engine w/14mm Bearing) [HUD107051]?
... and you can reinstall a 14,5 mm bearing with the set Part number: # 107051?
If I need to remove a 13 mm bearing I'll need part number #107063. How do you install a 13 mm bearing? With the presser that is included in the .21 set?
