ENGINE/ CLUTCH PROBLEMS...ENGINE SCREAMING AT IDLE :S >
Old 04-30-2012, 11:11 AM
Default ENGINE/ CLUTCH PROBLEMS...ENGINE SCREAMING AT IDLE :S
im having trouble with my motonica clutch although it could be my novarossi engine....the clutchbell spins freely but wen i start the engine up it revs really high practically screaming at idle even though the wheels arent moving....which area is the problem and how do i solve it? thanks
ry_100 is offline
Old 04-30-2012, 11:28 AM
djiewie's Avatar
first, turn down the idle by unscrewing the idle screw/adjuster.
djiewie is offline
Old 04-30-2012, 12:31 PM
i checked at the time an its still fine now theres a small gap in the carb at idle position :S....could it be i need a new carb ?
ry_100 is offline
Old 04-30-2012, 12:59 PM
Sounds like you have a very lean engine.
1nsane is offline
