Seized engine, Best way to loosen head bolts with out stripping them?
loosening head bolts
As a fitter and turner by trade, Get some heat into the block/case and see if you can tap the head of the bolt, thirdly use the correct fitting tool if its a flat blade or a 2.5mm. By a general rule you strip threads by over tightening not loosening.
hope this helps
hope this helps
