VoneSII Motor
I have a VoneSII and am having problems with the engine running rough at high revs. I have rebuilt the motor to ensure that there are no air leaks. It has a new glow plug.
When running at higher revs the motor surges and there is a lot of small air bubbles in the fuel line. Does any one have any suggestions for what is wrong ?? Many thanks to all. Nic. |
Check the fuel tank for leaks. Submerge the tank in a bucket of water. (sealing the pressure feed and outlet first) Try blowing into the tank through one piece of tubing and noting if there are any leaks could be a seam or the o-ring on the lid.
I had the same problem myself and a new fuel tank fixed it. |
