Serpent Cobra GT
#1306
Can you give us the directions, i tryed and did not found. only found "Serpent Cobra"
#1307
In FB.... Search Serpent GT Onroad Gas
#1308
Looking for the Hole to Hole shock length for the shocks that come on the Serpent GT cars. I would like to try a different shock on my dirt oval car. Thanks!
#1309
tthrottle servo
I'm changing my throttle servo to hitec from the savox brand. Why won't the servo spline inserts for hitec work with the stock throttle servo horn linkage for the GT? Do I have to purchase a hitec specific horn made by Serpent that comes with its own inserts?
#1310
You could also and I recommend going with the 24 tooth aluminum servo arm.
http://www.serpentamerica.com/shop/p...3&cat=0&page=1
#1311
hmm
The Hitec servos take a 24 tooth spline where the Savox take a 25. Inside the kit you should fin a 23 24 and 25 insert for the stock arm, you will need to change this or you will run into problems with centering soon. Basically the servo will destroy the plastic gearing and you'll be left with an arm that travels because there is nothing to grab. Some of these inserts are very tight so you may have to use a little force.
#1312
23,24 and 25.
The kit also come with extra shock pistons too. So take a look againg just to make shure you dont have it.
If not then get this part #600294 wich is better than the stock and it will work with your servo.
#1313
I looked everywhere
Thats weird because the kit does come with extea splines.
23,24 and 25.
23,24 and 25.
#1315
Ah! That would be why it didn't come with the splines. What don't you like about the stock servos or why are you looking to upgrade? I can help you pick out some Savox if you want.
#1316
crazy
While doing some practice lap on the track the car suddenly went crazy and I lost throttle control. A few guys at the track and myself were able to catch up to the car and repair the track damage. After looking over the car we found that the stock dragon RC throttle servo froze with the throttle in wide open. The servo died and I could not move it manually back to neutral. I purchased a hitec servo to replace it and then found the splines do not fit. Before I drove the car, the steering servo was replaced with a Savox 1267 servo which fit the spline that was already there. I was thinking of getting the savox 1258 servo for the throttle.
#1318
Don't expect RTR servos in any kit to last long.
#1319
My go to setup for servos on the cobra GT is a Savox 2274 steering and a Savox 2271 throttle. The brushless servos work much better in the heavy 8th scale stuff. this setup is ran off of a Lipo and there is a big performance change by doing so.
The 1258 will work but it is not a HV servo. Depending on your setup radio wise i would suggest working towards a HV setup on Lipo as the performance over the NIMH is significant.
