Like Tree4Likes
Old 07-12-2014, 11:26 AM   #1246
scary_jerry's Avatar
Originally Posted by Rockin G View Post
So you are saying half a turn 5 times? Which equals 2.5 turns? It used to shift fine at 5.5 turns. The manual says 5 1/2 turns. Never heard of writing it the way you mentioned. Yours shifts at 2.5 turns?
'Jacko' researched that interpretation over a year ago.
Mine didn't attempt a shift until '6.......half turns' but I'm plagued with the 'one-way bearing' issue.
4 local hobby shops don't stock nor can I find a person that even recommends using 'one-way grease'. I'm going to try Marv's ' clean-it approach and get some of the Hudy stuff KR145 highlighted. (Hudy's explanation gives some credence to the Do or Don't question)
scary_jerry is offline   Reply With Quote
Old 07-12-2014, 07:29 PM   #1247
KR145's Avatar
The manual says start at 5 1/2 turns out. . Right now mine is set at around 6 3/4 turns out. I was getting frustrated doing small adjustments at first, then ended up that far out. Works good.
On the one way oil, only need a drop or 2.
Kevin Rogers
RoseCityScaleRacers
KR145 is offline   Reply With Quote
Old 07-13-2014, 07:13 AM   #1248
You are reading it correct. 5 full turns plus another half. I usually start at 6 full turns out from flush when I first install a new 2 speed.
Its good to take the 2 speed springs and exercise them with a pair of pliers a few times before installing them. The stock 2 speed springs seem to be pretty tough so this helps soften them up.
TerribleTy is offline   Reply With Quote
Old 07-13-2014, 06:43 PM   #1249
Questions?? 5.5 or 5x 1/2
Originally Posted by Victor Vector View Post
I misread instructions first time and did 5 1/2 turns. What it is for real is 5 x 1/2 turns.............so I prolly know what's bugging you here. Could be wrong as well !!
So what does Serpent say......????????
I had better results at '6......1/2 turns' to get a shift until the 'one-way' bearing didn't want to cooperate.
Old 07-14-2014, 07:54 AM   #1250
I believe its the shaft i took my trans apart and it seems to be a little worn out so i ordered a new one and will see if that fixes the problem. I will let you guys know once i replace it. Thanks for all of the input
Tshabalala is offline   Reply With Quote
Old 07-19-2014, 05:50 AM   #1251
Trader Rating: 306 (100%+)
Would like to add Aluminum rear uprights. On Desoto site there is 4 version. Anyone know the correct one to get.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 07-21-2014, 08:12 AM   #1252
Default cobra trany one way slip
hey there, i bought my cobra gt like 3 weeks ago, the last weekend i ran it for the first time and it was awesome but in like the 3 or 4 fuel tank the one way bearing starts to slip. took down the trany and cleaned the bearing then put it all together but nothing happened the same story. then a friend that has the same car told me that the problem itīs that the bearing canīt be without oil but it must be one way bearing oil only. next act was to clean the bearing with some solvent, dry it and put a drop or 2 of the hudy one way bearing oil. put it all together once again and it was like magic never again the bearing slipped. the car has a gallon through it and perfect.
with the gearbox issue, i set it as the manual says 5-1/2 turns and perfect but for my local track itīs a bit long, i must loosen the 2speed a bit.
anyone has installed the upgrade for the roll bars? the hard shaft roll bar set?
Armandolenzi is offline   Reply With Quote
Old 07-21-2014, 09:01 PM   #1253
mcsquish's Avatar
If this has been asked before, my apologies. I am looking for the part number for the rear drive shaft. I thought I had the correct number, got it from the manual, but it is not identical; it is the correct length, but the diameter is larger. Also, what are people using for grease on the CV joint? I used some old MIP cvd grease, but it failed and the pin wore a grove in the shaft.
Thanks.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 07-22-2014, 12:08 AM   #1254
theerm's Avatar
Thanks.
I have had unbelievable life from all my CV joints using Bell-Ray super clean m/cycle chain lube. its in a spray can. its really thin on application and dries tacky , will not throw off and up to the pressure. I think any good road bike chain lube would be up for the task
People will do anything to loose weight! ! Except eat less and exercise
theerm is offline   Reply With Quote
Old 07-23-2014, 11:40 AM   #1255
myndesye's Avatar
http://www.rc-mushroom.com/product_i...eg-alu-p-28867
myndesye is offline   Reply With Quote
Old 07-27-2014, 09:51 AM   #1256
Trader Rating: 32 (100%+)
Can anyone advise the part# for 0 deg steering block (composite material, not alu)??
Thanks.
hobbs is offline   Reply With Quote
Old 07-27-2014, 10:44 AM   #1257
Thanks.
It is my understanding that they are only made in aluminum.
Brett Adams
Mugen MGT7
o.s. savox futaba
66 Box Nova all motor LSX
1966ss is offline   Reply With Quote
Old 07-27-2014, 11:45 AM   #1258
FastPete's Avatar
Trader Rating: 44 (100%+)
Thanks.
Aluminum only part number right on Serpents home page.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 07-29-2014, 06:17 AM   #1259
myndesye's Avatar
there is no composite at this time
Old 07-29-2014, 12:51 PM   #1260
That link from Rc-mushroom It's out of stock.
Anyone has anothe store selling it??
i just need the C-Hub or should i buy the Steering Blocks also?
Larus is offline   Reply With Quote
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 782 12-04-2016 05:09 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
