Like Tree23Likes
Old 06-21-2014, 10:57 PM   #1186
C@T
C@T's Avatar
Loosening of the grub screws especially in the drive drain seems to be common to almost all brands.
Part of the problem I found, is that the cub screws used often are of a cutting ring type at the low end. This does give only a very small contact surface on the shaft normally hardened. If there is only a tiny wear it will start to tumble and loosen.
The type of cub screw used for that application should have a flat end.
Grinding the end flat and using Loctide 290 (green) will cure the problem, but you need good tools like Hudy to get them out again.
C@T is offline   Reply With Quote
Old 06-22-2014, 11:13 AM   #1187
Erchur's Avatar
Originally Posted by Zakariah View Post
yep, that set screw was loose. and i wasnt 1000% sure to make note of how i removed the diff. im gonna double check the manual for that. gotta go see if wal mart carries loc tite. lol. i need this thing running by sunday morning..
Use "Red" Loctite on the grub screw and you'll never have to worry about the diff pinion coming lose on its own.
Eduardo Romero
Serpent America-Desoto Racing, Novarossi, KO Propo, Byron's Fuel, Alpha Tires, Alpha Body
Erchur is offline   Reply With Quote
Old 06-22-2014, 06:13 PM   #1188
vta4life's Avatar
Default motor mounts RTR
Hey guys I need some help with my cobra gt rtr . I tried install new motor mounts (#600588) the mounts dont line up with my chassis? Also tried a new motor rear cover (#13025) .has no support for crank shaft? Are these the wrong parts?or do I need more? Any help would be great!!! Would like to be able to use bump box.
vta4life is offline   Reply With Quote
Old 06-22-2014, 06:58 PM   #1189
Trader Rating: 308 (100%+)
What brand everyone using for 500,000 and 100,000 diff oil?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 06-22-2014, 07:42 PM   #1190
KR145's Avatar
I started with this set up and Terible Ty and a few others recommended 300k front and 40k rear. I shoulda started with his advise, car rotates alot better for me.
Kevin Rogers
RoseCityScaleRacers
KR145 is offline   Reply With Quote
Old 06-22-2014, 09:23 PM   #1191
Joseph16's Avatar
Jermaine i use xceed.
You can use any CST oil
Serpent America & Desoto Racing.
Picco - Arrowmax.
PT RC Racing Oils.
Neal Smith Mods.
Alpha Tires and Body.
Joseph16 is offline   Reply With Quote
Old 06-23-2014, 12:52 AM   #1192
Is that with the V2 gears?
Jermaine Mitchell
Mercenary Racer
Old 06-23-2014, 05:28 AM   #1193
Pit-racer's Avatar
I use Tamiya diff fluid.
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 06-23-2014, 03:36 PM   #1194
KR145's Avatar
Yes.
Kevin Rogers
RoseCityScaleRacers
Old 06-23-2014, 05:55 PM   #1195
Thumbs up
The car will turn in more with lower diff cst. I run very short tight tracks often for club racing and 300K is perfect with the V2 gears. It also works well on larger tracks like TZ and GLARC. I haven't used 300K at TZ but I have ran at the track and that's exactly where I would start. I ran 300K at GLARC at the Airtronics GP and the car felt really good.
The higher cst will give you more on power pull out of the corners, feels more point and shoot if you get what I mean. Car will follow the front tires with 500K. Best thing to do is try both and see whats best for you. if you are looking for a specific handling characteristic we can help you with that too.
If you have the V1 gears go with 100K front for lots of turn in with 30K rear.
TerribleTy is offline   Reply With Quote
Old 06-23-2014, 06:11 PM   #1196
Just ordered some Xceed, going to start with 200k and 40k. Just have get some 300k and 500k as 200k is the highest they make.
Jermaine Mitchell
Mercenary Racer
Old 06-24-2014, 05:29 PM   #1197
Team STPN's Avatar
Yes Red Loctite and it will never come off unless you heat it up!!
I know people who like to use their Nitro cars to mow the yard!!
When in doubt just Hammer them!!
Team STPN is offline   Reply With Quote
Old 06-24-2014, 08:16 PM   #1198
Quick Question....What engine is everyone running? I am new to the class and need to get a good engine.
willcarrera is offline   Reply With Quote
Old 06-24-2014, 09:04 PM   #1199
Grenade10's Avatar
Trader Rating: 37 (100%+)
[QUOTE=willcarrera;13359105]Quick Question....What engine is everyone running? I am new to the class and need to get a good engine.[/QUOTE
Talk to the racers locally, there are some places running Roar rules with 5 port engines and some running full open mod engines. The Is on Novarossi has been fast and Murnam does a great job in modifying it.
So my suggestion.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 06-25-2014, 10:28 AM   #1200
Grenade is correct ( I can't believe I just said that) the Ison modded is a great engine for any track. You can't go wrong with Nova Rossi.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 05:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
