Like Tree46Likes
Old 06-06-2012, 06:19 PM   #106
bassman2's Avatar
Originally Posted by Skaidragon View Post
Anyone, can I put an on-road engine on this GT?
You can put any .21 to .28 engine in these GT cars. As long as your gearing and pipe/header/clutch selections are setup for the particular engine you are running (onroad or offroad engine).
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 06-06-2012, 06:20 PM   #107
Trader Rating: 58 (100%+)
Thumbs up GT
Thanks!!! Bassman2!!!
Skaidragon is offline   Reply With Quote
Old 06-06-2012, 06:58 PM   #108
Just got my Cobra GT from IGTHobbies today!!!! Two days to build and headed to Gulf Coast Raceway for some test and tune with my boy!
WWW.IGTHOBBIES.COM - Your #1 GT Source!!!
Serpent Cobra GT / OS Speed / Sweep Tires / KO Propo
chaderick is offline   Reply With Quote
Old 06-06-2012, 08:37 PM   #109
jasoncb's Avatar
Trader Rating: 52 (100%+)
Where is everyone getting tires? GT tires must be the hardest thing to get. Can not find Alpha softs anywhere. Everyone is out of stock!
Jason Beam
XB8e'17|XB8'17
Thanks to my sponsors:
RCAmerica, Xray, JConcepts, Hudy
jasoncb is offline   Reply With Quote
Old 06-06-2012, 08:51 PM   #110
djmorales's Avatar
Send a message via Skype™ to djmorales
Default tail lights
gonzo i guess new gt bro! still don't mean you going to pass me bro i'm getting all that practice time in b4 the byron race
djmorales is offline   Reply With Quote
Old 06-06-2012, 09:20 PM   #111
your right jose is he racing at portage also?
team durango desc410r with 5.5 550 novak for sale
team losi xxx-sct with a tekin 17.5 and tekin rs for sale
team losi eight-t with werks b6 pro
Team associated tc6.1 worlds 17.5 Speed passion 3.0 with tekin rs
blitz15 is offline   Reply With Quote
Old 06-07-2012, 06:17 AM   #112
flyboi33's Avatar
Thumbs up
Cobra GT is all together.. Going to track today for some test & tune!!! Also will have the 747 out there too (;
DEE ROSS
SPONSORS: Serpent America/ Desoto Racing/ Novarossi Engines
Dialed-RC Hobbies / Futaba/ USN
flyboi33 is offline   Reply With Quote
Old 06-07-2012, 06:36 AM   #113
I'm really curious to see one of these go myself. Just getting back into hobbies after a loonnnng hiatus and I always wanted a Serpent.
rebornr1 is offline   Reply With Quote
Old 06-07-2012, 08:49 PM   #114
flyboi33's Avatar
Thumbs up
I went to the track today with a friend with our Cobra GT cars.. I ran about six laps and then then rain started pouring but I was interested in the cornering of the car and I must say it corners like a 10 scale I will be going back out in the morning with my Cobra if it does not rain.. Hands down to Serpent for another great car...
DEE ROSS
Old 06-08-2012, 05:43 AM   #115
Default DIFF HELP!!!!!!!!!!
What is the trick to get the diff mesh right. I was hoping a high dollar kit like the Serpent there would be no need for diff shims. I have tried one and each side, two on the left none on the right, two on the right non on the left, one on the right none on the left, one on the left none on the right, none on the left none on the right. The diff mesh doesn't feel smooth to me. It seems to be at it's best when I put two shims on the side opposite the 44t gear but still not at my liking. Is this normal????
Old 06-08-2012, 05:48 AM   #116
Gonzo RR's Avatar
Same here. I went with no shims on either side, mesh was too tight. Once you put it on the chassis it fits nicely. I was going to ask if anybody dis the same. I'm taking my time with the kit 3.5 hrs so far and I only have the rear assembly done. I'm not having any problems except I might need a new 2.0 hex driver when I'm done with the build. Plastics are tight.
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 06-08-2012, 01:42 PM   #117
Speyederjedi's Avatar
Taking my time as well. Rear assembly is completed. I tried the shims several different ways on the diff and finally felt is was a bit better without them at all since the fit was so good. Once I have it all together and make some practice runs I may take the front and rear assemblies back off and double check the diffs just to be sure mesh is good with the ring and pinion.
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
Old 06-08-2012, 02:16 PM   #118
I had a similar issue, but mine, was one philips screw of the three- which holds the inner bearing inside the diff case causing an issue. It is directly in-line with the 44 tooth gear of the diff. I just rechecked them, and tightened up the phillips screws- and that fixed my issue. Now I'm using one shim on the opposite side of the 44 tooth gear.
Might be something to look at.
Awesomatix USA, AVID, Serpent USA / Desoto Racing, Team Scream, LRP, Psycho Cells Racing, Sweep Racing, Hurricane Motorsports, Core Creations, Hobbytown USA of K.C., 2mm Design and ProLevel
BSYDOR is offline   Reply With Quote
Old 06-08-2012, 03:16 PM   #119
Erchur's Avatar
Try Bruckner hobbies. They have Alpha white rims in super-soft, medium and hard shores (no soft shore available at the moment). Just ordered two sets myself. Nice price too, $29.99/pair!
Eduardo Romero
Serpent America-Desoto Racing, Novarossi, KO Propo, Byron's Fuel, Alpha Tires, Alpha Body
Erchur is offline   Reply With Quote
Old 06-08-2012, 03:36 PM   #120
Erchur's Avatar
Had same issue with diff gear mesh as others. I tried different combinations and could not tell any real difference. I ended up putting two shims opposite side of the 44t gear.
What's up with those plastic 3mm nuts? Those had to go and replaced with steel 3mm nylon lock nuts. Just picky minor stuff. I also had issues with the flanged 3mm screws, metal seem too soft and strip easily, specially if using a power driver.
All in all I'm extremely impressed with the car, it will certainly take the GT class to a much higher level, we will no longer be the bashers wannabe racers. It will not surprise me to see more GT than sedan entries at our local races
Well done Serpent! Made us wait a long time, but wait was well worth it.
I'm putting the final touches on the car and planning on heading down to Mike's tomorrow to burn some rubber
Eduardo Romero
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 05:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
