Like Tree57Likes
Old 06-20-2014, 10:17 PM   #1171
Rockin G's Avatar
Yes, the diff comes out, but no need to actually open the diff itself. Just pull the diff out, making note of which way the diff is when you take it out. Would be easy to put it in backwards and then you have to take it back out, usually after you get it all back together.
Anyways, one the diff is out, pull the 3 Phillips screws out and the whole assembly, drive shaft and all comes out the same way the diff came out. During this time, at someone the pinion will probably come off, especially if it was loose. Then do as rcmikel described.
Rockin G is offline   Reply With Quote
Old 06-20-2014, 10:56 PM   #1172
yep, that set screw was loose. and i wasnt 1000% sure to make note of how i removed the diff. im gonna double check the manual for that. gotta go see if wal mart carries loc tite. lol. i need this thing running by sunday morning..
garage: Serpent cobra gt, losi 8-T 2.0, jato 3.3, losi mini 8ight
Zakariah is offline   Reply With Quote
Old 06-20-2014, 11:08 PM   #1173
had no cleaner, so im soaking the screw and (what it screws into) in alcohol until i get back from wal mart..
Old 06-21-2014, 01:30 AM   #1174
3:30 a.m. problem solved, car fully reassembled. thank you everyone who helped! now i can sleep in peace tonight
cant wait to continue break-in. with all wheel drive again.. lets hope it doesnt rain all day tomorrrow.
Old 06-21-2014, 06:48 PM   #1175
Lol you got what we call the Rattle Snake Id go through and loctite all of your set screws on the center drive train or this will just keep happening.
TerribleTy is offline   Reply With Quote
Old 06-21-2014, 07:37 PM   #1176
Flyin Hawaiian1's Avatar
When you use red loctite make sure to let it set for 24 hrs for best result. Also when you need to remove the set screw just heat it up with hair dryer or heat gun then the set screw will unlock. Good luck and have fun!!!
Andy Liu "Flyin' Hawaiian"
Flyin Hawaiian1 is offline   Reply With Quote
Old 06-21-2014, 07:37 PM   #1177
scary_jerry's Avatar
Isn't that 'curious' the way that happened..........I put my Cobra GT on the shelf because of all the 'developmental problems'..........to include the 'mysterious' metal filings near front and rear diffs. caused by the 'dooooofffuss' screws to secure the bearings.
Serpent's self-appointed 'cheer-boy' should be ashamed................
scary_jerry is offline   Reply With Quote
Old 06-21-2014, 07:40 PM   #1178
And ANDY..............don't even bother..............you walked away from me as pitman at TZGP to help the 'pissant'...................your fate is sealed..............
Old 06-21-2014, 08:21 PM   #1179
Aught-Six's Avatar
Don't forget me Jerry, you left me out.
Aught-Six is offline   Reply With Quote
Old 06-21-2014, 08:33 PM   #1180
No............Marv 'target picture' includes you. It's the least I can do for the 'pair' who 'pushed out' the person that built the 'Utah track system' for Gus and then 'Trashed Jerry'.............
Old 06-21-2014, 08:39 PM   #1181
this car is a handling machine.. set up a road course in a big smooth parking lot today, i'm sure it wont be long till i rip through these stock tires. i'll loctite all the set screws on the next rainy day (looking like monday) thanks for the help.
also.. had a wheel come off today. recovered the nut luckily. no locknuts for the wheels?? all the bolts are loose from the factory so i just went over everything and made sure all is tight now. racing at the LHS tomorrow, cant wait to see how this thing ranks up with the other GT cars.
Old 06-21-2014, 08:55 PM   #1182
Yes, tighten the wheel retainer screws. I was a 'GOOD GUY' one day and did a 'McGyver' thing and 'fabricated' a replacement axle lock pin for 'TY JACOBS' in Utah at the 'Magna track' on his first outing with his new 'Serpent Cobra GT' and kept him from having to go home without getting to play with his new car.........................don't 'EVER' do a 'FAVOR' for him................he turned around and with the request from 'MantisWorx'...........slammmed me as a 'KNOW-NOTHING' in the GT world.....................time for 'full-disclosure'.............There ARE witnesses to the 'RCTech.....PM's'...........!!!!..........
Old 06-21-2014, 09:01 PM   #1183
"Z"............I'm not sponsored by any tire company..........if you want to do some 'tire-grinding' in a parking lot for 'tune-ups' etc. the GRP tires from Bruckner Hobbies will do just fine at a lower price than the 'Sweep' I DO Recommend for your race outings.........!
Old 06-21-2014, 09:14 PM   #1184
Aught-Six's Avatar
Sorry your posts have become part of Jerry's rant. He's a local racer that thinks he has been wronged by just about every racer in Utah. So he sits at home and about once a month comes out and tries to convince people we are evil GT guys in Utah. Glad you like the car. They are a blast to drive and there are alot of great guys in GT that know a lot about the car, and that includes Ty and Andy. Great guys with lots of passion for the GT.
Old 06-21-2014, 09:39 PM   #1185
Grenade10's Avatar
Trader Rating: 37 (100%+)
Loose drive line grub screws is not unique to Serpent, I've had issues with the OFNA DM1 and X3. Do what Andy said and you will be good. Tires for playing with when the kit tires are done, you might look at VP Pro tires, good grip and will last, plus cost is good. When you are ready to race, then look at Sweep.
Get the serated wheel nuts, loose wheels will not be an issue.
Glad your having fun with the GT car!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11733 09-23-2017 05:13 AM
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 06:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 06:05 PM
Tags
serpent 977, serpent cobra
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Cilal
