Old 06-20-2014, 02:33 PM   #1156
PinoyCali's Avatar
Originally Posted by Zakariah View Post
Manual says run 25% nitro.. I can only get 20.. Will 20% be ok? Or could it damage the engine?
Its ok.
PinoyCali is offline   Reply With Quote
Old 06-20-2014, 03:34 PM   #1157
O.P.
There is a GR8 sticky read at the top of this forum on engine break in . I am sure you have reviewed it ... right
brokenspirit is offline   Reply With Quote
Old 06-20-2014, 06:49 PM   #1158
Well... Got the car, got it running. Started break in, everything was perfect. On the 5th tank of fuel, i noticed i lost front brakes, which i sorta expected (not this soon) since the brakes need upgrading. But the real kicker..
THE FRONT DIFF IS ALREADY BURNED UP. Wtf?? I didnt run it hard at all.. Never even got to WOT...
Anyone else have front diff issues? Very disappointed to spend 600$ on a kit and have problems like this before i even finish break in..
Zakariah is offline   Reply With Quote
Old 06-20-2014, 07:40 PM   #1159
Aught-Six's Avatar
Define burned up? Sounds to me like you have a loose set screw on the front of your two speed. If you lost brakes and don't have power to the front drive check the set screw on the front drive cup of your two speed. loctite is your friend.
Aught-Six is offline   Reply With Quote
Old 06-20-2014, 07:47 PM   #1160
Thumbs up
Hey Zach I see you are having some trouble with the kit. Sounds like shes fresh and not even close to broken in. I am very curious about your differential issue as I havent seen anyone go through one yet. Not saying they are bullet proof but they are difficult to destroy.
Have you pulled everything apart up front to figure out what all is damaged? there are a few tricks that a lot of the Team guys figured out shortly after launch of this chassis that help keep the car great for a long time.
Can you pull the front end apart and maybe grab some pictures? Id like to help you out as this kit is awesome.
Any questions you may have please fire away! I havent been on here in a while but ill keep tabs on the thread to make sure we get your ride sorted out.
TerribleTy is offline   Reply With Quote
Old 06-20-2014, 07:51 PM   #1161
Cool
Yes you can use 20% your manual suggests 25% as it is the best content for racing at lower elevations for .21s. Running 20% will sacrifice some power but you will get good run time. There's a real fine balance here with a lot of factors that play in. If you can only get 20% that is fine, nothing to worry about. Just make sure you use good fuel.
Old 06-20-2014, 07:55 PM   #1162
considering the treaded 50 shore option for tires.. im gonna be on super hot parking lots, very rough surfaces around here for me. im gonna get them pre-mounted, should I get inserts for them? if so, which inserts would be best on short parking lot courses?
just wanna be sure before I spend 65$ on the wrong set of tires for what I need lol.
50s will work great, I started out one of our newer drivers out on 50s and he brought home second his first race. Go with 50 EXP with the White insert. Treads are fine.
Old 06-20-2014, 07:58 PM   #1163
Thumbs up
yeah they are turbo.
C8TGH's are what I need.. at 11$ a pop, I hope they last a while..
The C8TGH is a great plug that will have long life. You may also want to consider the C8TGT. The TGT is a little bit cooler of a plug thus has a thicker filament thus is a bit more durable. They are designed to last through the high stress environment of 1/8th on road racing so they will hold up very well in a GT.
Old 06-20-2014, 08:20 PM   #1164
Rockin G's Avatar
And if that set screw is tight, you should also check the set screw for the pinion in front too. I've found mine loose before, though never to the point that you described, so it is just a thought.
Rockin G is offline   Reply With Quote
Old 06-20-2014, 09:07 PM   #1165
you guys are awesome. making me feel alot better about this. i tried the set screw in front of the gearbox. it was tight. the front driveshaft turns like it should when i roll the rear wheels, but no driveshaft movement at all when i roll the front wheels. the brake looks like it will work fine with a properly functioning front diff. i can hear like a fine scratching when i twist the front wheels, sorta like gears not catching all the way. ive never torn down a car to the differential, but there is a first time for everything.. i'll post pics as i go. im assuming start with the bumper and steering rack cover? thank god for this manual.. lol
garage: Serpent cobra gt, losi 8-T 2.0, jato 3.3, losi mini 8ight
Old 06-20-2014, 09:17 PM   #1166
Aught-Six's Avatar
The set screw in the pic Rockin G posted is in the diff case. That is probably the one that is loose.
Old 06-20-2014, 09:21 PM   #1167
working on getting to the diff case. how much of the front end needs to come off to access it?
Old 06-20-2014, 09:23 PM   #1168
do i need to completely remove the diff?
i dont have any diff oil on-hand, so i hope i can fix this without spilling/needing any..
Old 06-20-2014, 09:55 PM   #1169
If it is the set screw for the pinion gear, which I think it might be you will need to clean the set screw and the coupling with some motor cleaner. then use red loctite not blue on the set screw. it won't come apart again until you want it to
rcmikel is offline   Reply With Quote
Old 06-20-2014, 10:03 PM   #1170
yes you need to remove the diff, behind that is 3 screws that hold the bearing and pinion in. check the screw that is on the ring gear side to see if the ring gear was rubbing on it. if it was do not put a screw in that spot when you reassemble it. you don't need to take the diff apart
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 782 12-04-2016 06:09 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 11:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 06:05 PM
Tags
serpent 977, serpent cobra
