Like Tree4Likes
Old 06-09-2014, 10:21 AM   #1111
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Do you have the arm braces? i was able to stop this on numerous cars but really even without them it should not do that. how old are your arms? they do tend to warp over time up to 4mm!
MantisWorx is offline   Reply With Quote
Old 06-09-2014, 10:27 AM   #1112
Pit-racer's Avatar
Where do I find these arm braces? I've been asking for months.
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 06-09-2014, 10:30 AM   #1113
MantisWorx's Avatar
Cmon Pit!! RCShox.com thats where they have always been!!
Old 06-09-2014, 10:35 AM   #1114
PinoyCali's Avatar
Yes.. i got the braces from Mr Marcus .
Arms are 4 club races and 1 big race old.
Is it time to replace?
PinoyCali is offline   Reply With Quote
Old 06-09-2014, 12:04 PM   #1115
Arm braces and alloy rear hub carriers took away almost of the tire chatter that I was seeing.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - VP Racing Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 06-09-2014, 01:14 PM   #1116
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
Yes... Soft/ultra soft
Running different tire shores front and rear can do that. I am not saying that this is definitely your issue but it's worth trying a run with same tires all around and see if it disappears. If you have no other issue on the car the shaking out of the corners should disappear.
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 06-09-2014, 01:25 PM   #1117
PinoyCali's Avatar
Thanks guys
Old 06-09-2014, 02:04 PM   #1118
MantisWorx's Avatar
If you have the braces you will probably never need to replace them! They either warp or break and with the braces they are not going to warp. I am thinking you chatter has to do with the clutch in someway, a spring could be weak or broken, clutch bearing siezing up, grease in the bell from the bearing etc etc
Old 06-09-2014, 02:27 PM   #1119
PinoyCali's Avatar
I will check all this tonight.. Thank you very much.
Old 06-09-2014, 02:58 PM   #1120
pinoy69racer's Avatar
Trader Rating: 179 (99%+)
Did you get it all, ask wife first if you can work on the car tonight...
Bring it to the Serpent Service Center so we can check on it.
HENRY C
DESOTO RACING/SERPENT/VEYTREX DESIGN LAB/RC TARGET
pinoy69racer is offline   Reply With Quote
Old 06-09-2014, 03:02 PM   #1121
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by KR145 View Post
How far out can u go on the 2speed adjustment screws/springs before its out of spec. Stock is 5-1/2 turns out and yesterday, i finally got mine to shift pretty good at about 6- 3/4 turns out. Does this seem way to far out ? after our 3 hr enduro I took it all apart to inspect and then set it up back at stock setting and had to keep backing it off till i got it.
Also added a Buku clutch , maybe that made for having to adjust shifting some ? The thing Rips with that clutch
The adjustment is based on how close you have the shoes set to the housing to start. I normall keep my 2-speeds pretty close so there is some play when hot, but not large gaps. If you adjust this, you will need to re-set the shift points (less distance to lock up). I never set these to stock settings, but to where it needs to get my shift point right.
Clutch change can make a difference as well.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is online now   Reply With Quote
Old 06-09-2014, 03:13 PM   #1122
PinoyCali's Avatar
You need to talk to my wife she's mad at you...Bad influence!!!
Old 06-09-2014, 07:03 PM   #1123
PinoyCali's Avatar
I think i found the issue..
Part# 903362 Gearbox housing. Bearing is
Not good.. Ican feel the bearing is stocking up ..
Thanks to all..
Old 06-16-2014, 06:20 AM   #1124
Trader Rating: 306 (100%+)
if anyone looking for one
Serpent Cobra GT
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 06-16-2014, 06:55 AM   #1125
KR145's Avatar
Default Brake Bias
What kind of brake bias do you fast guys like ? heavier on the rear or more on the front ?
Kevin Rogers
RoseCityScaleRacers
KR145 is offline   Reply With Quote
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 782 12-04-2016 05:09 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
