Like Tree4Likes
Old 06-03-2014, 10:29 AM   #1096
Well done Andy and Mike. Serpent and Sweep is a great combination.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 06-05-2014, 06:02 AM   #1097
racerx1920's Avatar
Trader Rating: 207 (100%+)
has anyone used the antiroll bar shaft with the antiroll wires?
http://www.igthobbies.com/SERPENT-SE...R-_p_3006.html
http://www.igthobbies.com/SERPENT-SE...2-_p_3012.html
Desoto Racing / Serpent America / ProOne RC
Serpent 748WC / Serpent s120LTR / Serpent Project 4x
Dunn Graphics
1/8th Scale Racers of Toledo
https://www.facebook.com/DunnGraphics1
racerx1920 is offline   Reply With Quote
Old 06-05-2014, 10:32 AM   #1098
I picked up one of the RTR cars and ran it out of the box at our weekly races last night. That car is pretty impressive out of the box. I ran it the first round in sportsman and won the heat, then ran in the open class main with it and finished second to my teamate Ty. Not bad .
Old 06-05-2014, 01:15 PM   #1099
I was really impressed with that RTR. Gus slammed the door shut on me for a few laps holding the inside line with ease. Right out of the box that car has a good setup and holds its own on the track very well. This isn't your typical RTR this is a Serpent!
TerribleTy is offline   Reply With Quote
Old 06-05-2014, 06:00 PM   #1100
Flyin Hawaiian1's Avatar
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
Flyin Hawaiian1 is offline   Reply With Quote
Old 06-05-2014, 07:22 PM   #1101
Folks just stating the facts .... NICE post and good news
brokenspirit is offline   Reply With Quote
Old 06-08-2014, 07:38 PM   #1102
PinoyCali's Avatar
Default Rear end vibration
Hello,
I have vibration issues on rear end
Exiting corners on throtle
I dont see any vibration if the car is on
Starterbox.
Any advice..
2 stage piston
1200 cts oil
Tried Yellow and purple springs
PinoyCali is offline   Reply With Quote
Old 06-08-2014, 08:30 PM   #1103
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by PinoyCali View Post
Hello,
Starterbox.
Any advice..
2 stage piston
1200 cts oil
Try adjusting the clutch, sounds weird but sometimes if it engages too loose or even too tight this can happen. Does it do it with all of your tire sets? also check your drive pins.
MantisWorx is offline   Reply With Quote
Old 06-08-2014, 09:02 PM   #1104
Joe Kimble's Avatar
Send a message via Skype™ to Joe Kimble
Hello,
Starterbox.
Any advice..
2 stage piston
1200 cts oil
Are you using different tire shores front and rear?
Serpent America
Sweep USA
RCShox
Joe Kimble is offline   Reply With Quote
Old 06-09-2014, 01:08 AM   #1105
PinoyCali's Avatar
Yes... Soft/ultra soft
Old 06-09-2014, 01:15 AM   #1106
PinoyCali's Avatar
Yes is tried 3 diff sets of tires.
Vibrations starts on #2 qual.
Old 06-09-2014, 04:28 AM   #1107
British Menace's Avatar
Check these things....
I have had the same problem.
Check clutch bearings
Check two speed bearings
Check the diff' outdrives for pin wear.
check wheel balance
Aswell as the points others have noted
Regards
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Old 06-09-2014, 05:31 AM   #1108
KR145's Avatar
Default 2 speed Adjustment
How far out can u go on the 2speed adjustment screws/springs before its out of spec. Stock is 5-1/2 turns out and yesterday, i finally got mine to shift pretty good at about 6- 3/4 turns out. Does this seem way to far out ? after our 3 hr enduro I took it all apart to inspect and then set it up back at stock setting and had to keep backing it off till i got it.
Also added a Buku clutch , maybe that made for having to adjust shifting some ? The thing Rips with that clutch
Kevin Rogers
RoseCityScaleRacers
KR145 is offline   Reply With Quote
Old 06-09-2014, 08:45 AM   #1109
Default Vibrations ??
Is there any chance what your mentioning as vibrations might be tire chatter??
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - VP Racing Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 06-09-2014, 09:53 AM   #1110
PinoyCali's Avatar
Every time i exit corners pull the throttle rear tire start bouncing/vibrate
Like 2-3 seconds and roll smooth again.
I tried my friend alpha tires and sweep (balanced) still doing it.
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 782 12-04-2016 05:09 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
