Like Tree21Likes
Old 04-05-2014, 07:51 PM   #976
Rockin G's Avatar
Guys, if you hear of a nice roller, shoot me a PM. The one above sold already. Just want to try something new. Will be selling current car soon as I get it cleaned up and transformed into roller config.
Rockin G is offline   Reply With Quote
Old 04-05-2014, 08:04 PM   #977
I'll keep an eye out but they don't last but a few hours if they become available, if the price is right anyways... Good time of the year to be watching though, good luck!
TerribleTy is offline   Reply With Quote
Old 04-06-2014, 05:21 AM   #978
Pit-racer's Avatar
Yes hurry and get one. I love mine!
www.igthobbies.com / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 04-13-2014, 06:23 AM   #979
Crawlin's Avatar
Trader Rating: 22 (100%+)
Did anyone have any issues with build quality?
I've put together and taken apart the diff cases multiple times. Used the shims to make sure the ring gear wasn't binding on the pinion gear. Each time, I get to buttoning the cases together and it binds up the whole diff. This is front AND rear. I know the bearings are sitting properly in the spaces. The two cap head screws at the bottom aren't tight and show a 2-3mm space in the case.
Have any of you used spacers to spread the diff case apart a bit for free rotation? Does it just "break in" after use?
Crawlin is offline   Reply With Quote
Old 04-13-2014, 08:34 AM   #980
Trader Rating: 307 (100%+)
I ordered 2speed shoes and they are black. Ones in my GT is beige. Which are the updated ones?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 04-14-2014, 09:49 AM   #981
Acting Bad's Avatar
The black ones should be the updated ones. The beige ones are the originals. I ordered a couple of the black ones but I have not tried them out yet. I heard they work better.
Novarossi engines, Radiopost, Serpent 811 Cobra, Serpent 977 Viper, IGT Hobbies
Acting Bad is offline   Reply With Quote
Old 04-14-2014, 09:51 AM   #982
Acting Bad's Avatar
I built my diffs with out the shims and they work fine. Its pretty tight w/o the shims.
Old 04-14-2014, 10:04 AM   #983
DRRC's Avatar
Trader Rating: 57 (98%+)
Removed one shim in shaft gear
backed up 1/16 or 1/8 of a turn when tightened
and yes it does need to be run in for the parts to be seated well
after running in you can tighten them again and see if it is better
happened to mine and had to open up the front diff 3 times
was not happy then
I think the reason was the plastics were getting worn out or the palstic spacer in the front was not thick enough
either way backing up 1/18 of a turn out should help
Team Wife
Mugen Seiki Racing
Mugenracing.com
DRRC is offline   Reply With Quote
Old 04-14-2014, 11:18 AM   #984
Julius's Avatar
One thing tha sometimes happens, is that the ring gear rubs against the screws holding the pinion bearing in the case. You have to look whinch of the three rubs an grind the head a bit.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 04-14-2014, 07:01 PM   #985
I have seen this with new kits a few times. What you need to do is loosen the screws that holds the diff case together about a full turn or until you have free travel. I do this on all my kits On and Off Road. Give it a try and let me know what your results are please.
Old 04-15-2014, 09:32 AM   #986
PinoyCali's Avatar
Default Servo horn
Hello All,
Anybody using aftermarket/ upgrade steering servo? Brand?
Mike
PinoyCali is offline   Reply With Quote
Old 04-15-2014, 09:34 PM   #987
Originally Posted by PinoyCali View Post
Hello All,
Mike
Alot of the Team guys running the KO Propo 30103 Power servo.
http://www.amain.com/product_info.ph...o-High-Voltage Extremely smooth and powerful servo, I like it alot in the GT.
Other options for 6v application would be Savox 1283
http://www.amain.com/product_info.ph...eel-Gear-Servo
A little more info on your electronics would help but either of these will work. I've gotten about a season worth of hard driving out of the 1283 which aligns with what others have seen. The KO runs and lasts way longer.
Old 04-16-2014, 10:42 AM   #988
It all comes down to what you want to pay for a servo.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 04-16-2014, 10:45 AM   #989
Pit-racer's Avatar
+1
Old 04-16-2014, 11:31 AM   #990
Crawlin's Avatar
I removed the one screw that was on the side of the ring gear and now she spins freely even with all the screws fully tightened. I'd have to say that was my issue, that the button head of the screw(silver/chrome screw) was hitting the ring gear.
Would have never though that could be the issue!
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 05:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
