Old 03-15-2014, 09:31 PM   #916
DRRC's Avatar
Trader Rating: 57 (98%+)
40 plus GTs
Open GT podium
Team Wife
Mugen Seiki Racing
Mugenracing.com
DRRC is offline   Reply With Quote
Old 03-15-2014, 10:47 PM   #917
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by DRRC View Post
40 plus GTs
Open GT podium
Must be the race in Brownsville ...... Pictures and info please ......
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 03-15-2014, 11:56 PM   #918
DRRC's Avatar
Yes it was the Brownsville Spring Break Brawl GT race
I dont have videos was running too many classes
Here are some pics
Sportsman was won by Marcus Cole 8 yrs old schooling the old guys
He is fast
Pic of some of the racers after the race
It was fun
Serpent Cobra GT-1240542_594365633974130_1181338055_n.jpg   Serpent Cobra GT-1924400_594366017307425_1680738518_n.jpg
Team Wife
Mugen Seiki Racing
Mugenracing.com
Old 03-16-2014, 06:58 PM   #919
What clutch shoe spring set ups guys running? I'm running 2 aluminum with hard springs and 2 poly with med springs. Seems to lack snap thinking about going hard springs on the poly shoes then maybe trying 4 aluminum with hard springs. Thanks
Brett Adams
Mugen MGT7
o.s. savox futaba
66 Box Nova all motor LSX
1966ss is offline   Reply With Quote
Old 03-16-2014, 07:12 PM   #920
Clutch setup greatly depends on the amount of traction. High traction you can go up in stiffness. My normal setup is 2 carbon with Med and 2 Alu with X hard or Hard depending on traction. I would suggest checking out the Buku clutch as you can very easily tune it in to track conditions.
Clutches and amazing motors here!
http://www.murnanmodified.com/produc...roducts_id=841
TerribleTy is offline   Reply With Quote
Old 03-16-2014, 11:46 PM   #921
MantisWorx's Avatar
Trader Rating: 28 (97%+)
40 plus GTs
Open GT podium
DRRC's car was on point, ran well!
You missed a good one, you need to mark your calendar for next year. San Antonio, Austin and houston plan on getting the cup next year away from BV
MantisWorx is offline   Reply With Quote
Old 03-17-2014, 07:19 AM   #922
DRRC's Avatar
Good racing Marcus
You pros are silly fast it was fun racing with you
See you next month in Porter
Team Wife
Mugen Seiki Racing
Mugenracing.com
Old 03-17-2014, 09:28 AM   #923
emacrimes's Avatar
Does someone knows if there would be a problem putting in am S811 center diff on the GT?
We run in a small track, no 2nd gear needed.
Agama A215
Ko Propo | Highest RC | Team Orion | Sweep |
emacrimes is offline   Reply With Quote
Old 03-17-2014, 09:39 AM   #924
pinoy69racer's Avatar
Trader Rating: 179 (99%+)
Originally Posted by TerribleTy View Post
Super secret!!! Sweep Racing Tires were the ticket, they worked way better with the track. The more you ran them they tackier they got. A Murnan Modified ISON GT helps a ton too, his infield was where he made the magic.
You can bet we will be back out, that was just too much fun!!! Great track great people and warm sunshine, count me in!
What kind of sweep tires did you guys used last airtronics race, slick? Threaded? 45 or 50 ?
HENRY C
DESOTO RACING/SERPENT/VEYTREX DESIGN LAB/RC TARGET
pinoy69racer is offline   Reply With Quote
Old 03-17-2014, 10:53 AM   #925
Flyin Hawaiian1's Avatar
I used 45s EXP slicks with ROK rims(white insert) in the front and 40s EXP slicks with ROK rims (white insert) in the rear during qualifiers. For the 30 minute A-main I used 45s EXP slicks all around. At the end of the main, the tire wear was very consistent. Air temp was about 85 degrees and track temp was about 115 degrees prior to the start of the main. If the main is 1 hour then I would recommend 50s EXP in the front and 45s in the rear.......
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
Flyin Hawaiian1 is offline   Reply With Quote
Old 03-17-2014, 11:16 AM   #926
DRRC's Avatar
Only video of the race I could get my hands on
http://www.youtube.com/watch?v=JE4fQSiRUho
Thanks for the info Andy FLyin Hawaiian
I do agree sweeps are very good on a prepped track and easy on wear and do prefer using them
I used alpha this race and almost wore out a new set in the quals because of the hotter track
Team Wife
Mugen Seiki Racing
Mugenracing.com
Old 03-17-2014, 08:42 PM   #927
Pit-racer's Avatar
O.K. big question here .... install fuel filter? Or cooler? To carb or from exhaust?
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 03-17-2014, 10:00 PM   #928
There is a fuel filter inside the tank, that one should be more than adequate. As far as filters from the exhaust I personally don't run them but I have seen some people with them. I tried those inline fuel filters and they ultimately just give you one more area for a potential air leak making tuning lots of fun. Fresh tubing and the already installed filter should be solid. Look inside the tank you'll see the filter I am talking about I think its called a clunk filter.
Old 03-18-2014, 06:13 AM   #929
Pit-racer's Avatar
Yes I seen that one, it moves around inside the tank for when those boards jump out and smacks our cars and flips us.
Old 03-18-2014, 07:43 AM   #930
Pitracer, enough with all the questions.......The only question I AM GOING TO ASK is this: Have you taken your beautiful "shelf queen" out for a stroll yet? LOL!!!LOL!!! That Cobra machine is meant to be raced........GET HER ON THE TRACK PLEASE.....but make sure the surface is smooth enough for her to SHINE!!!
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 782 12-04-2016 06:09 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 11:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 06:05 PM
Tags
serpent 977, serpent cobra
