Like Tree39Likes
Old 07-11-2013, 05:51 PM   #676
tobamiester's Avatar
Trader Rating: 275 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Originally Posted by Bhodi11 View Post
Where can I get a copy? I am having a terrible on power under steer issue on large high speed corners. Need to try something different. Thanks.
http://www.serpent.com/product/600040/setups/
tobamiester is offline   Reply With Quote
Old 07-11-2013, 10:27 PM   #677
Phil Trotta's Avatar
Thumbs up
Originally Posted by Joseph16 View Post
The 2.0 conversion from the buggy is wider, wich give you more stability.
I dont know if you guys have notice that the cobra is narrower in the rear,
So people are sacrificing corner speed for stability.
Corner speed is actually faster with stock set up ( narrower rear)
The version 2 rear with hubs and axles is way wider
With 1 mm hubs its almost 6 mm wider. My car was total 314 mm wide with conversion using sweeps
The cobra which like almost all electric rubber cars has a wider front width than the rear. This gives great corner speed
Stock arms hubs axles was 308. mm with sweeps In rear
If you need more rear stability you can narrow the front end (-1 hubs )
Also you can try +2 or + 3 mm rear hubs Also Desoto has lower roll center. Locks for rear which can plant rear without making wider.
The wider rear you can drive in harder but it doesn't exit as well IMO
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 07-12-2013, 06:45 PM   #678
Joseph16's Avatar
Thumbs up
+100
Serpent America & Desoto Racing.
Picco - Arrowmax.
PT RC Racing Oils.
Neal Smith Mods.
Alpha Tires and Body.
Joseph16 is offline   Reply With Quote
Old 07-12-2013, 09:44 PM   #679
+100
So joseph does it follow if you want more corner speed, +2 in front and -2 at the rear are better than the stock ones?
Salug is offline   Reply With Quote
Old 07-12-2013, 10:09 PM   #680
What ride height are you guys running? If I follow the setup sheet its more or less 15mm. Isn't that way too high? Heard some are running 9mm?
Old 07-13-2013, 04:56 AM   #681
Thumbs up
I was running 7 front 8 rear. But my home tracks are bumpy
AlsO I was running a soft setup with a lot Of roll....
Desoto jr runs a much harder setup less roll with car slammed at around 5 mm according to Desoto sr. That was the tq at Byron's and winner
PHIL TROTTA
Old 07-13-2013, 04:58 AM   #682
That might be extreme
PHIL TROTTA
Old 07-13-2013, 05:32 AM   #683
Thanks for the reply Phil. One more question regarding your setup. "Soft setup with a lot of roll" is it like 800 cst oil with 1.3 piston front and rear? Im using this setup with yellow springs in front and white in the rear. Is this considered soft? By the way our track here is really bumpy too.
Old 07-13-2013, 09:31 AM   #684
Joseph16's Avatar
That will be to much...
Im using 9mm front and 10mm rear.
Picco - Arrowmax.
PT RC Racing Oils.
Neal Smith Mods.
Old 07-13-2013, 05:18 PM   #685
I ran the stock pistons with 1000 cst front / rear. Ended up going to white fronts yellow rears
The harder you go with spring you'll take roll out and add response but it also depends on what your tires can handle and track temps
Roll centers also determine chassis roll
You seem to be on the soft side in dampening for the cars weight
Is it pushing?
PHIL TROTTA
Old 07-16-2013, 06:58 AM   #686
D.a.v.e's Avatar
On the setup sheets I see something listed as Other: 2 listed right above oil weight and just below spring selection. Does anyone know what that means?
D.a.v.e is offline   Reply With Quote
Old 07-16-2013, 08:03 AM   #687
Is it pushing?
Phil, pushing just a little bit in entry but very manageable. My problem is in the exit. It has a tendency to fishtail. Is it because of the front kickup? or the car's caster? It just has too much steering when exiting. Tried a harder front diff (300K ) but unfortunately its still there. Any suggestions would be greatly appreciated.
Old 07-16-2013, 08:22 AM   #688
bassman2's Avatar
Make sure your front wheels are pointing straight and lift up the rear end from the center then SLOWLY drop it down and see if both rear wheels are touching the setup board (must be a flat surface) simultaniously, if not make adjustments. Also you might want to add little more droop in the front to allow little more weight to transfer from the front to the rear.
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 07-16-2013, 09:00 AM   #689
Thanks bassman2 for the reply but my front droop is set all the way loose already. and my rear droop is 10. and yes both of the rear wheels go down simultaneously. This is really frustrating.
Old 07-16-2013, 10:41 AM   #690
British Menace's Avatar
Hey ....
I think you need to go the opposite. (Sorry to be contradictory ....)
You need to reduce the amount of droop at the front.
First make sure they are equal side-to-side then take the droop away in increments
You may not see a difference for a while but eventually you will. Keep reducing the droop.
You may also try putting a stronger ARB at the front but it sounds as though you maybe too soft also in damping or springing.
But try the droop first and nothing else.....
Good luck
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 05:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
