Like Tree4Likes
Old 05-01-2013, 10:53 PM   #511
BardSmith's Avatar
Trader Rating: 59 (98%+)
I'm about to head out with my new GT for a race weekend, which spare parts or option parts should I stock up on? What's breaking out there? Ideas... thoughts...
"Bard"
On-Road Only!
BardSmith is offline   Reply With Quote
Old 05-02-2013, 05:43 AM   #512
Dortiz68's Avatar
In the short few months that I've had my GT8 I haven't broken a single part. The car has been very solid for me although I will admit that mine has a lot of the aluminum hop ups. The only things I have had to change due to break is a stripped gear and that was completely my fault.
I have seen the plastic servo saver wear a bit causing some slop and I know a lot of guys elect the stiffer spring for improved steering. Other than that, having spares for set up changes is what I see most at our local track of a dozen or so GT8 racers.
I'll let the more experienced guys respond on set up parts or other concerns, but in my experience the Serpent GT8 is pretty solid.
Good luck at the races!
Dortiz68 is offline   Reply With Quote
Old 05-02-2013, 06:08 AM   #513
Phil Trotta's Avatar
Thumbs up
I have not broken a part but you must make sure you lock tight certain places extra careful. Like the pinions in the front and rear differentials and the pins in the wheel hubs.
As far as hop ups aluminum clutch shoes. At least two matched with two carbon ( stock shoes ). Heavy clutch spring for the Aluminum shoes
If you need more turn in off power. 10 degree front caster blocks with zero degree knuckles
Also aluminum bulkhead for brakes with upgraded brakes. They don't fade ..
You can get everything from Desoto Racing ....
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 05-02-2013, 08:54 AM   #514
Dortiz68's Avatar
Originally Posted by chaderick View Post
My Serpent was awesome this weekend at the Novarossi Challenge. We had over 25+ entries in GT8 and the majority were Serpents. Prior to the race I replaced my year old front control arms due to them warping from use. I got to the track and after Round 1 of qualifying I saw that Tony Luna w/ Lunatic Racing Products had a set of control arm braces that he invented on his Serpent. I bought a set from him and was amazed on the difference it made on my car. I was surprised how much my control arms straightened out. Even the new front arms had some signs of straightening. What I noticed before even putting the car on the track was that my setup changed due to the condition of the arms prior to installing the braces. I had to reevaluate my current ride hide and droop before the next qualifier. What I found is that my setup values had changed and I made the necessary adjustments. Even though the track conditions slowed the qualifying times I noticed immediately that the car turned better in the corners and made it more precise under high speed turns. What I like about the braces is the better feel for the car, the fact that I won't have to replace arms due to them warping under loads, and my setup will be more accurate from here on. I will post a photo of the braces tonight. These braces will soon be available thru Lunatic Racing Products (LRP) and will be available at GT8sports.com soon!!
Thanks Tony!! See you at the Texas Biggie on Memorial Day at Rendon, TX!
+1 on the LRP arm braces. I've been running these on my car the last month and have realized improvements in the corners as Chad mentioned. I also have the RC Shox 2-stage pistons on my GT8. Last weekend was the 1st race with the Arm Braces & 2-stage pistons and they both performed great. My laptime have become more consistent since these additions. Now it's time to figure out a way to get faster.
Daniel
Old 05-02-2013, 03:38 PM   #515
Trader Rating: 306 (100%+)
Daniel
Where can you get the braces?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 05-02-2013, 04:56 PM   #516
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Contact Tony Luna @ GT8sports.com
MantisWorx is offline   Reply With Quote
Old 05-02-2013, 05:49 PM   #517
Who has the best price for the gt kit?
dropabomb is offline   Reply With Quote
Old 05-02-2013, 11:45 PM   #518
BardSmith's Avatar
Thanks for info JackH. Do you please have part numbers for the aluminum bulkhead for brakes with upgraded brakes? Do you mean the center diff holder?
"Bard"
On-Road Only!
Old 05-03-2013, 02:29 AM   #519
Jazza's Avatar
Trader Rating: 16 (100%+)
Default Changing Pinions
Hi guy's this may seem a dumb question so please forgive.
On the GT clutch bells to remove the first & second gear pinions.
What tool do you use to hold the actual clutch bell??
I tried using a pair of pliers, but that started to distort the clutch bell itself.
Cheers Darren
Capricorn Lab Co3....Black Edition Co2
Kickass Racing OS Racing Engines RB TXR Engines
Capricorn Racing Tyres....Highest Servo's....VP Racing Fuels
Supporter of Capricorn Australia....Walters Hobbies....JPM Racing
Jazza is offline   Reply With Quote
Old 05-03-2013, 06:22 AM   #520
tonylunatic's Avatar
Trader Rating: 44 (100%+)
Hi guys I have had several people contact me for LRP "LUNATIC Racing Products"
and just want to give everyone the same information.
I am the owner of LRP, Tony Luna. I am an avid racer and have been in the sport /hobby for over 15+yrs. With the help of manufacturer RCShox "MantisWorx" we have and are designing and making new hop up parts for the Serpent Cobra GT as well as other tools and accessories. List below of current and up coming products.
LRP Serpent GT Braces v1 original arms "Available now"
LRP Serpent GT Braces v2 wide track" Coming soon"
LRP Universal Setup Board "Available now"
LRP Rubber Tire Juice "In Production"
LRP Pit Caddy "Coming soon"
LRP Tire/Setup System Carry Case "Coming Soon"
MUCH MORE IN THE WORKS!!
The LRP Line of products will be sold and distributed to select dealers by WWW.GT8SPORTS.COM
Gt8sports.com is being built to be a Premium Racers online store for GT8 racers.
This site is up but currently being revised. Should be up and running in a few weeks.
Until them you can contact me here via pm or post for any information.
I also want to THANK my fellow racers and customers for the reviews on current products. Your feedback will help us to continue to improve and grow our products.
Tony LunaTic
Serpent/Desoto Racing USA~Murnan Modified Motors~PTRC Racing Fluids~Flo-Control ~IGTHobbies.com
tonylunatic is offline   Reply With Quote
Old 05-03-2013, 08:39 AM   #521
D.a.v.e's Avatar
I can vouch for being careful about the pins on the wheel hubs. Apparently they are a different size then Ofna & some of the other cars so when you loose one you may have a short day.
Mine has only seen about 30min of track time but so far no breakage (other then the lost pin). Hoping to log a fair amount of time in this weekend as well!
D.a.v.e is offline   Reply With Quote
Old 05-03-2013, 11:23 AM   #522
mcsquish's Avatar
Center diff holder alu: 600286 - $49.36
Brake set Pro for Cobra: 600345 - $46.16
Prices are from Desoto Racing
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 05-03-2013, 01:03 PM   #523
bassman2's Avatar
Daniel
The LRP arm braces do work well. Especially around the sweepers. Give it a try folks.
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 05-03-2013, 05:18 PM   #524
FastPete's Avatar
Tony LunaTic
Any pics of these braces?
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 05-03-2013, 09:03 PM   #525
MantisWorx's Avatar
TeamC version but Cobra's look the same.
http://www.rcshox.com/gt8-arm-braces/
Tony is working on his actual pix this weekend.
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 782 12-04-2016 05:09 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
