Like Tree51Likes
Old 04-24-2013, 09:05 AM   #496
team mugen's Avatar
Originally Posted by scary_jerry View Post
team mugen...............
Thanks for the race video. That first six minutes with 1 and 2 was intense. Showed some great driving AND sportsmanship. That sure looked like a great bunch of 'happy racers'.
I know that will get 'Bassman's' juices flowing !!!!!
I am also curious as to which Nova engines you guys are using........
Thanks bro. It was great first race of GT. I use the nova bonito tuned n others use the btt world champ. Its great.
SERPENT COBRA GT/ SERPENT 747/ Hongnor X3 Sabre/ COBRA BUGGY/COBRA TRUGGY/ NOVAROSSI BTTS/BONITO/SANWA
team mugen is offline   Reply With Quote
Old 04-24-2013, 09:13 AM   #497
team mugen's Avatar
Originally Posted by DRRC View Post
Good racing
How new is the track? I have been to GP raceway and race at CV when there but where is this track located
Might go this summer and try it out
If I remember edward you were at the TC Elec World championships at Thailand and heard you did well
congratulations
Drrc- track just officially open about a month ago n its near mindanao ave. . Thanks
Old 04-24-2013, 01:25 PM   #498
mcsquish's Avatar
I'm building the car and I have a question concerning the diffs, in the manual it shows a thin shim that goes between the O-ring and the pin that holds the outdrive/diff gear. I did not have that shim in my kit, I’m guessing that a shim actually does not go there. I have had other kits that show a shim in the manual, but there is not one in the kit.
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 04-24-2013, 01:28 PM   #499
d OG black flag's Avatar
does any one if you can change gear combination or not on the cobra and if so how? it seems i can place a 16/20 on my cobra. thanks.
d OG black flag is offline   Reply With Quote
Old 04-24-2013, 03:02 PM   #500
Originally Posted by mcsquish View Post
I'm building the car and I have a question concerning the diffs, in the manual it shows a thin shim that goes between the O-ring and the pin that holds the outdrive/diff gear. I did not have that shim in my kit, Iím guessing that a shim actually does not go there. I have had other kits that show a shim in the manual, but there is not one in the kit.
i believe it was mentioned pages back but the original kits took the shim bc it had different gears i believe was the reason. regardless you dont need the shims you can just put it together.
Brett Adams
Mugen MGT7
o.s. savox futaba
66 Box Nova all motor LSX
1966ss is offline   Reply With Quote
Old 04-24-2013, 03:04 PM   #501
my 2 speed seems to have a bit of play forward and back. enough that the outdrive clipped the corner of the radio tray. im running the plastic 2 speed holder. will the aluminum help this? anyway to shim the play out? thanks
Brett Adams
Mugen MGT7
o.s. savox futaba
Old 04-24-2013, 06:19 PM   #502
The v1 version diff gears used the washers. The v2 version of the diff gears do not use the washer. If your kit is newish it won't have/use the washers.
desotoracing is offline   Reply With Quote
Old 04-24-2013, 06:23 PM   #503
Use 600354 or 600356 shims to take the excess play out.
Old 04-25-2013, 07:12 AM   #504
mcsquish's Avatar
Thanks for the replies.
Old 04-29-2013, 07:41 AM   #505
Cobra GTs dominated Nova Challenge in Porter, TX taking the top 3 spots in Qualifying and the Main.
Old 04-29-2013, 07:49 AM   #506
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Desoto it's a guy in the "onroad recommendation thread". Looking to buy a cobra gt. might wanna make him a offer he can't refuse. His avatar is "dropabomb"
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 04-29-2013, 11:23 AM   #507
My Serpent was awesome this weekend at the Novarossi Challenge. We had over 25+ entries in GT8 and the majority were Serpents. Prior to the race I replaced my year old front control arms due to them warping from use. I got to the track and after Round 1 of qualifying I saw that Tony Luna w/ Lunatic Racing Products had a set of control arm braces that he invented on his Serpent. I bought a set from him and was amazed on the difference it made on my car. I was surprised how much my control arms straightened out. Even the new front arms had some signs of straightening. What I noticed before even putting the car on the track was that my setup changed due to the condition of the arms prior to installing the braces. I had to reevaluate my current ride height and droop before the next qualifier. What I found is that my setup values had changed and I made the necessary adjustments. Even though the track conditions slowed the qualifying times I noticed immediately that the car turned better in the corners and made it more precise under high speed turns. What I like about the braces is the better feel for the car, the fact that I won't have to replace arms due to them warping under loads, and my setup will be more accurate from here on. I will post a photo of the braces tonight. These braces will soon be available thru Lunatic Racing Products (LRP) and will be available at GT8sports.com soon!!
Thanks Tony!! See you at the Texas Biggie on Memorial Day at Rendon, TX!
WWW.IGTHOBBIES.COM - Your #1 GT Source!!!
Serpent Cobra GT / OS Speed / Sweep Tires / KO Propo
chaderick is offline   Reply With Quote
Old 04-29-2013, 09:39 PM   #508
Team STPN's Avatar
Why aren't you getting one??
I have 2 cobras, one for me that is hooked up and one for Scotty not hooked up so I can kick his butt!!
Probably the only time I can beat him though: sneaky:
Team STPN is offline   Reply With Quote
Old 04-30-2013, 05:02 AM   #509
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Originally Posted by chaderick View Post
My Serpent was awesome this weekend at the Novarossi Challenge. We had over 25+ entries in GT8 and the majority were Serpents. Prior to the race I replaced my year old front control arms due to them warping from use. I got to the track and after Round 1 of qualifying I saw that Tony Luna w/ Lunatic Racing Products had a set of control arm braces that he invented on his Serpent. I bought a set from him and was amazed on the difference it made on my car. I was surprised how much my control arms straightened out. Even the new front arms had some signs of straightening. What I noticed before even putting the car on the track was that my setup changed due to the condition of the arms prior to installing the braces. I had to reevaluate my current ride hide and droop before the next qualifier. What I found is that my setup values had changed and I made the necessary adjustments. Even though the track conditions slowed the qualifying times I noticed immediately that the car turned better in the corners and made it more precise under high speed turns. What I like about the braces is the better feel for the car, the fact that I won't have to replace arms due to them warping under loads, and my setup will be more accurate from here on. I will post a photo of the braces tonight. These braces will soon be available thru Lunatic Racing Products (LRP) and will be available at GT8sports.com soon!!
I am glad you liked the arms, I originally designed them for the TeamC car for the same reasons and then realized that the Serpent arms needed help too! The 2 stage pistons help even more with corner speed and really plant the car, most noticeable in transitioning. BTW i need my pipe back for this weekend in brownsville, think you can ship it to me ASAP?
MantisWorx is offline   Reply With Quote
Old 04-30-2013, 12:40 PM   #510
WildBillMassey's Avatar
Congrats to Team IGT Hobbies driver Chad Kiffe for a 2nd place podium finish!
Former owner of The Nitro Pit and IGT Hobbies
Now living in the Great White North.
You may think you know what you're talking about, but the only person you're fooling is yourself - Wild Bill Massey
WildBillMassey is offline   Reply With Quote
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11733 09-23-2017 04:13 AM
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 05:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
