Like Tree5Likes
Old 02-25-2013, 02:22 PM   #421
D.a.v.e's Avatar
Originally Posted by desotoracing View Post
We normally run 200k in the front and around 60k in the rear
Does changing out the wheel hex's improve steering as well? Looks like the online setup are going with -1 in the front and +2 in the rear? Just wondering what this change makes?
D.a.v.e is offline   Reply With Quote
Old 02-25-2013, 02:49 PM   #422
C@T
C@T's Avatar
Less trackwith on the front does increase steering.
More on the rear will work same way, increasing the difference in trackwith between front and rear
C@T is offline   Reply With Quote
Old 02-27-2013, 05:07 PM   #423
Erchur's Avatar
Originally Posted by team mugen View Post
Can anyone suggest a good diff and shock setup for the Nitro serpent GT. I tried the box setup but its so much understeer. Pushing on and off power. The track we are playing is a fast asphalt track with couple of Uturns and long straight. Thanks guys . I tried different sweep tires depends on the temp of the track but i am still not satisfied with the way the car turns.
Check the tension on your servo saver spring. I am using the optional "hard" servo saver spring, which I set up pretty tight. My undeersteer issues went away after this change.
I use 200k in the front diff and 40k in the rear. As to the shocks I run 1000 cps fluid in front and rear and use the machined 8 hole 1.1mm shock disks front/rear. Springs are track/surface dependent.
Hope this helps!
Eduardo Romero
Serpent America-Desoto Racing, Novarossi, KO Propo, Byron's Fuel, Alpha Tires, Alpha Body
Erchur is offline   Reply With Quote
Old 02-28-2013, 06:33 AM   #424
team mugen's Avatar
Hope this helps!
Hey bro, thanks for the info. I changed my servo spring now with the hard one. Will test the car tomorrow. Thanks
SERPENT COBRA GT/ SERPENT 747/ Hongnor X3 Sabre/ COBRA BUGGY/COBRA TRUGGY/ NOVAROSSI BTTS/BONITO/SANWA
team mugen is offline   Reply With Quote
Old 03-04-2013, 10:07 AM   #425
Trader Rating: 15 (100%+)
Does anyone know if there are any anticipated changes for 2013? A new kit, upgraded parts, etc?
Arboleda is offline   Reply With Quote
Old 03-04-2013, 10:24 AM   #426
tonylunatic's Avatar
Trader Rating: 44 (100%+)
In speaking with Serpent America/Desoto Racing at the Grand Prix Race in Homestead, FL in January.
I was told that a major effort was made to just introduce the Cobra GT to the market. Furthermore that Serpent has no plans or upgrades in the works.
But I would like to announce that Lunatic Racing Products "LRP" & RCshox have been making and testing several upgrade products to improve the Serpent Cobra GT. These new upgrades will be announced very soon and be available for purchase at Gt8sports.com and Rcshox.com.
**Rcshox.com actually added The New 2Stage shock pistons for the Cobra GT a few days ago and are available Now!!
**Gt8sports.com is still in the process of adding all their inventory and products to site, and will be 100% very soon.
Serpent/Desoto Racing USA~Murnan Modified Motors~PTRC Racing Fluids~Flo-Control ~IGTHobbies.com
tonylunatic is offline   Reply With Quote
Old 03-04-2013, 11:56 AM   #427
Would someone mind explaining what 2 stage pistons are please?
CDS70 is offline   Reply With Quote
Old 03-04-2013, 12:23 PM   #428
C@T
C@T's Avatar
Have a look at www.rcshox.com
It is a piston made out of two parts, a fixed one attached to the rod as usual and a second one combined with it. The second one, having a slightly smaller diameter can slightly move up and down, driven by the movement of the piston.
Having different size of holes in both does lead to a change in the damping based on the direction the piston is moving.
Compressing the shock will show more damping than expanding it. Just like real car shocks should do.
Old 03-04-2013, 12:27 PM   #429
D.a.v.e's Avatar
I have not looked yet but was wondering if any of the new 2.0 parts would benefit this kit?
Old 03-04-2013, 12:32 PM   #430
MantisWorx's Avatar
Trader Rating: 28 (97%+)
C@T almost got it perfect but the OD of the pistons is the same on both, damping and rebound is controlled by hole sizes and oil viscosity.
2 stage pistons allow you to control compression or rebound via hole sizes.in normal configuration which gives faster rebound, the upper piston "floats". On compression the pistons come together and block off the vent hole giving you a stiffer compression rate. When the shock goes in to rebound the pistons seperate exposing the larger holes in the lower piston and the excess flow goes through the vent holes. In application this increase straight line traction as it is quick to shift weight to the rear or side to side. The car will transition much quicker because the inside of the car will rise quicker than the outside will fall which puts more pressure on the outside tire thus giving you faster corner speed. Testing has gone very well, over the next few weeks more of the "top dogs " will have them for testing! Watch the orange car closely especially on the slow motion section ( may have to watch it a few times!) but you can see the difference between the two cars! Tony now runs them on his Serpent Cobra as well.
http://www.youtube.com/user/Mantisworx?feature=mhee
MantisWorx is offline   Reply With Quote
Old 03-04-2013, 01:00 PM   #431
Do you mean the buggy v2.0 parts? Although most parts to come straight from the buggy some where designed just for the GT.
Serpent buggy upgrades I use and recommend:
V2 inner diff gears
Buggy 0* aluminum steering arms
10* buggy caster blocks
Hard steering spring
Option 2 steering rack
I have a couple other upgrades, not available because they didn't make it to final production. But they are not needed makes car super under weight for racing minimum of 3500 grams.
Old 03-04-2013, 01:34 PM   #432
Thanks gents, makes sense. will be interesting to see how successful it is.
Old 03-05-2013, 11:04 AM   #433
mcsquish's Avatar
Since I may be switching to a Cobra, what is the body of choice? Is it the R3 that Desoto Racing has, or is there something better out there? Thanks!
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 03-05-2013, 01:15 PM   #434
Thunderbunny's Avatar
Trader Rating: 24 (100%+)
Alph R3
http://www.serpentamerica.com/shop/p...cat=115&page=1
Chris Jones a.k.a. "Black Jesus"
O.S. l Airtronics l RSD l
Team ARC l Gulf Coast Raceway Porter,Tx
Thunderbunny is offline   Reply With Quote
Old 03-06-2013, 04:35 PM   #435
Does this car come with the 150cc tank yet?
Brett Adams
Mugen MGT7
o.s. savox futaba
66 Box Nova all motor LSX
1966ss is offline   Reply With Quote
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 788 04-18-2017 05:02 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
