Like Tree39Likes
Old 01-21-2013, 01:04 PM   #406
Originally Posted by tha Beast View Post
not worth the money it will cost ( I tried it ) your better off buying the kit
Correct! the cost of the chassis alone makes it hard to be worth it. The motor mounts in a different position from GT to Buggy. The buggy has more front weight bias than the GT. The shocks are expensive as well, they are unique for the GT. The buggy tank is 125 and GT is 150cc.
jneg is offline   Reply With Quote
Old 01-24-2013, 05:03 AM   #407
Hello Guys, someone use the new anti-roll bar system in the cobra gt ??
This one
Any comments about this system??
Daniel Mazzara
Serpent Cobra GT
Venezuela
Maxy tell me joaquin de soto sr used in cobra gt, any comments ???
See you
Daniel Mazzara
Serpent Cobra GT
Venezuela
daninter is offline   Reply With Quote
Old 01-24-2013, 06:13 AM   #408
See you
Daniel Mazzara
Serpent Cobra GT
Venezuela
Yes, we use it on the GT. It makes it faster and easier to change the anti-roll bar thickness. We like it.
desotoracing is offline   Reply With Quote
Old 01-24-2013, 10:05 AM   #409
Thanks desotoracing, you know the most common setup for the wire in that system that you use in cobra gt cars??
Daniel Mazzara
Serpent Cobra GT
Venezuela
Old 01-24-2013, 11:27 AM   #410
Daniel Mazzara
Serpent Cobra GT
Venezuela
We use the 2.3 or 2.5 in the front and 2.5 or 2.7 in the back.
Old 01-31-2013, 02:44 PM   #411
Tandum4056's Avatar
Trader Rating: 108 (100%+)
I picked one of these up and I am excited to start the build. Are there any areas of concern that i need to address or upgrades that I should buy?
Also, what is a good starting set-up for this car.
Tandum4056 is offline   Reply With Quote
Old 02-18-2013, 03:53 PM   #412
team mugen's Avatar
Can anyone suggest a good diff and shock setup for the Nitro serpent GT. I tried the box setup but its so much understeer. Pushing on and off power. The track we are playing is a fast asphalt track with couple of Uturns and long straight. Thanks guys . I tried different sweep tires depends on the temp of the track but i am still not satisfied with the way the car turns.
SERPENT COBRA GT/ SERPENT 747/ Hongnor X3 Sabre/ COBRA BUGGY/COBRA TRUGGY/ NOVAROSSI BTTS/BONITO/SANWA
team mugen is offline   Reply With Quote
Old 02-18-2013, 07:16 PM   #413
Team STPN's Avatar
Try Alpha tires they are the way to go and use Paolo's set up on the serpent web site, great starting point. You can get the tires at Serpent America Desoto racing. If you don't want to buy the Alpha tires try saucing them up to soften them up.
Team STPN is offline   Reply With Quote
Old 02-19-2013, 02:34 AM   #414
team mugen's Avatar
Thanks for the info. Only sweep tires are available here n i have tried paolos set up on our track but its so much understeer pushing on n off power. Have you guys tried other diff n shock set ups that give you more steering? Thanks.
Old 02-19-2013, 05:16 AM   #415
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Where are you from ?, i work with Alpha RC Factory, maybe we can look for a dealer/distributor on your location so you can get better tires (OURS !) ...
regards,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 02-19-2013, 05:52 AM   #416
Try White springs in the front and Black springs in the back. Also, try the 0 deg alum steering blocks with the -1 or -2 hexes.
Old 02-19-2013, 06:12 AM   #417
team mugen's Avatar
regards,
Tabushi- we are here in the philippines and 1/8 nitro GT is just starting with about 20 drivers . I just finished our onroad track with about 80meters straight x 30 meters. Will post a picture of the track. .
Desotoracing- will try that spring set up but what diff oil should i use in front n rear. . Thanks for the help.
Old 02-19-2013, 06:46 AM   #418
We normally run 200k in the front and around 60k in the rear
Old 02-25-2013, 07:09 AM   #419
D.a.v.e's Avatar
Just started building my kit and was wondering what extra parts folks keep in their boxes for these? Its been a while since I've raced on-road so I'm sure I'll be bouncing around a bit on the track.
D.a.v.e is offline   Reply With Quote
Old 02-25-2013, 09:18 AM   #420
i haven't broken anything on my car. The only thing I broke and had to change was the Steering servo horn to aluminum.
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 05:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
