Like Tree23Likes
Old 10-01-2012, 05:01 PM   #331
is anyone having a problem with the two speed shifting? Mine studders like tow or three times before it shifts.. What could it be?
http://www.youtube.com/watch?v=Fn2k4NYBQH0
howard85may is offline   Reply With Quote
Old 10-01-2012, 08:08 PM   #332
When that used to happen to me with my DM1 it was that the one way was slipping on the shaft or that it was going bad. With my Cobra I haven't had any issues other than the tank filter.
jneg is offline   Reply With Quote
Old 10-01-2012, 08:56 PM   #333
thanks i will clean the one way bearing.
Old 10-01-2012, 09:11 PM   #334
Come to think of it, I put some lubricant on the one way.. that may be my problem.
Old 10-02-2012, 02:39 PM   #335
Speyederjedi's Avatar
Anybody having issues with the dogbones/driveshaft on the Cobra GT? I haven't raced mine yet and I noticed from just testing and tuning one of the dogbone/pins has chipped away on one side???? Not good if they are falling apart just from testing and tuning. I guess better here than in a 30 or 45 minute main but still...
Regards,
Speyederjedi
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
Old 10-02-2012, 11:12 PM   #336
Toughbeard's Avatar
Regards,
Speyederjedi
we ran our car at the Bursa Track for a whole day for testing, demo and show purposes. Nothing happened. you might have came across a faulty pin which is very rare for that kind of item. if it ever popped out of the cup it may have damaged it.
get a new pin and replace it if you cant do it you LHS or distributor can fix it for you. just make sure you replace pin after you heat up the shaft...
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 10-03-2012, 09:52 AM   #337
Toughbeard,
Yup, hoping it is just a one time incident. I'm ordering a new set of shafts and will replace the pin on this one and keep it as a spare. Already have my bench vice setup for replacing those. I have a hole drilled into one side of the vice so the pin can be pushed flush on the opposite side . Once it gets flush on the one side I push the new pin in and then get it centered
Regards,
Speyederjedi
SWEEP Tires
Old 10-03-2012, 12:45 PM   #338
Toughbeard's Avatar
Toughbeard,
Regards,
Speyederjedi
nice setup... like I said heat up the shaft and cool the pin so its a better fit. if you pull the pin out when the shaft is cool and insert the new one in, it will just fall off as this will damage the shaft.
Serdar Aytemiz
Old 10-03-2012, 10:02 PM   #339
bassman2's Avatar
Default Serpent GT took top 3 spots in Southwest Championship Series
The Southwest Championship Series came to an end. The Serpent Cobra GTs took home the top 3 spots this year:
1st Place: Andy Liu "Flyin Hawaiian"
2nd Place: Tony Luna
3rd Place: Dee Ross
http://teamserpent.com/2012/10/usa-m...in-by-any-liu/
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 10-03-2012, 10:06 PM   #340
Joseph16's Avatar
3rd Place: Dee Ross
Hey congratulations andy!!!
Serpent cobra is the best gt car in the market thumbs up for serpent!!!
Serpent America & Desoto Racing.
Picco - Arrowmax.
PT RC Racing Oils.
Neal Smith Mods.
Alpha Tires and Body.
Joseph16 is offline   Reply With Quote
Old 10-03-2012, 11:39 PM   #341
Toughbeard's Avatar
check oneway. sometimes the manufacturers insist on packing the oneway bearings with grease. you must have a clean bearing without grease. but if this is the case the car will not shift and rev up
your shift point sounds a little early as well. its as if the car is always at second gear and the engine shutters. also check the contact of the 2 speed shoes with the 2nd gear bell. if they are engaging at different times it will cause the shift to take longer time and feels erratic. usually happens when using set screws to adjust the gap.
if you are using set screws on the pads make sure they are not hitting the aluminium bell or you have flash around the hole the screw goes in....
Serdar Aytemiz
Old 10-05-2012, 01:01 PM   #342
Congrats on the series win , Andy. You're hard to beat. Kudos to Serpent and Sweep.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 10-05-2012, 03:04 PM   #343
flyboi33's Avatar
Thumbs up
3rd Place: Dee Ross
What a good looking group of GT8 racers.. Good job Andy and all the other guys who raced this season..
DEE ROSS
SPONSORS: Serpent America/ Desoto Racing/ Novarossi Engines
Dialed-RC Hobbies / Futaba/ USN
flyboi33 is offline   Reply With Quote
Old 10-05-2012, 04:04 PM   #344
Doug M's Avatar
3rd Place: Dee Ross
Congrats to Andy, Tony and Dee!
Doug M is offline   Reply With Quote
Old 10-05-2012, 08:42 PM   #345
Ok, I removed the clutch assembly, cleaned it all up, scuffed the hub and pads, degreased the oneway, adjusted the clutch tension screws, added set screws and now it will not shift at all?? Is there a certain way that the shoes should be oriented, with the long side trailing or leading?
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 05:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11732 04-22-2016 10:59 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 05:05 PM
Tags
serpent 977, serpent cobra
