Like Tree57Likes
Old 08-19-2012, 10:27 AM   #286
VexVegaz's Avatar
quick question guys...after building the cobra i was left with these parts, but not sure exactly what they are....
Thanks!
Serpent Cobra GT > Serpent 748TQ Serpent S411 Serpent SRX2 Sanwa MT-4 Novarossi Hobbywing Epic D3 Savox > Sweep Tires > BrooklynHobbies.Com
For RC TShirts and Custom Sponsor Shirts & Hoodies, Please Visit www.veytrex.com
VexVegaz is offline   Reply With Quote
Old 08-19-2012, 11:30 AM   #287
Victor Vector's Avatar
Thanks!
Them cute paddle things are the niftiest odditys ever and used to plug your fuel lines when swapping out motors and save yer trousers when you turn the car upsidedown or what ever it is that causes fuel to trickle into body parts that don't need dousing in fuel.
The other bits are for adjusting the brake bias. Takes a little finesse to get them fully tuned.............
Don't forget the Aluminium 2 speed bulk heads unless you like running without brakes !!
Jacko
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline   Reply With Quote
Old 08-19-2012, 11:36 AM   #288
VexVegaz's Avatar
ahhh got it! Thanks jack!
Yes the alu bulk heads are on their way and should be available for pick-up from my LHS tomorrow(Monday)!
Old 08-19-2012, 11:58 AM   #289
Don't know why people keep mentioning having problems with the brakes. I've been running my car and never had the slightest problem with the brakes and I run the stock plastic middle diff bulkhead. Our track has a couple of high speed sections with hairpins at the end, and never had fade.
What type of problems are people experiencing? The plastic bulkhead melting?
Jacko
Wachsmann64 is offline   Reply With Quote
Old 08-19-2012, 12:24 PM   #290
VexVegaz's Avatar
I dont believe it is something as drastic as the bulkhead melting. I think the heat produced by constant breaking can result in a much less consistent breaking.
Old 08-19-2012, 04:06 PM   #291
Ive seen other kits have this issue as well. Some people use the brakes so much they literaly melt the plastic down. I find this alot on some of our newer drivers here in Utah and show them little tricks like putting springs between your pads so they dont always rub. Rub is friction, friction is heat! Im running my Serpent with the stock pads and brakes as well as the plastic mount. If I melt them Ill get the alums. At home I run a tight short track so there realy isnt too much hard braking.
TerribleTy is offline   Reply With Quote
Old 08-19-2012, 04:47 PM   #292
I've been reading old posts and only one person has complained about it happening on the Serpent. I'll check mine often to make sure they are not melting.
BTW there is no use in trying to adjust brake bias on the Serpent. The center assembly is a solid unit... you only adjust the workload placed on the discs but does not affect bias. It will be 50:50 always.
Old 08-19-2012, 04:56 PM   #293
All I know about the brakes and bulkheads is that my brakes were fine until I was really racing hard and then they wern't !! Believe me, they melt really well............
Jacko
PS Hullo Ty..............happy trails kiddo
Jack Balchin.
Timezone Hooligan
Old 08-19-2012, 05:48 PM   #294
Are you using the metal discs?
Jacko
Old 08-19-2012, 06:04 PM   #295
That was stock fibre discs. TimeZone is a brutal track for brakes for sure, but Mike Lyday had the same problem at a different track. I ain't the only one with this little headache...........!!
Jacko
Jack Balchin.
Timezone Hooligan
Old 08-19-2012, 08:40 PM   #296
Default GT8 Invitation
If you run gt8 this is a race you dont want to miss some of the bes gt drivers will be there also lots of prices and a whole bunch of nice people to meet.
Team Los Magnificos Rc
Desoto Racing
TONY-Q is offline   Reply With Quote
Old 08-20-2012, 11:57 AM   #297
Jacko
Good info! I had some brake fade issues on my Team C at Timezone. I never have had issues at my home town track with either cars. Guess the Alums couldnt hurt, better safe than sorry!
Old 08-20-2012, 05:13 PM   #298
Pix of how it goes when the brakes go..... and it goes and goes and goes....
Update: I got to TZ yesterday to get a new motor on track. It had been heat cycled 10 tanks, so this wasn't pussy footing too much and at the end of the day, it was 90% WOT.......NOT A HINT OF BRAKE FADE YIPPEE...Ally bulkheads and Associated discs.
Jacko
Jack Balchin.
Timezone Hooligan
Old 08-20-2012, 06:38 PM   #299
VexVegaz's Avatar
Wow , seems like i was wrong, they do literally melt.
bad news, my alu bulk head didn't make it with the rest of my spares.
Old 08-20-2012, 09:26 PM   #300
And melt they do! I'll order the alu parts to be on the safe side.
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11733 09-23-2017 05:13 AM
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 06:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 06:05 PM
Tags
serpent 977, serpent cobra
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DKB243
