Like Tree57Likes
Old 11-03-2017, 03:31 PM   #2521
dan_vector's Avatar
Trader Rating: 27 (100%+)
The car was always coming just they had other priorities for production of other new kits like the 988 and the SRX8 EVO.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 11-06-2017, 11:45 AM   #2522
MantisWorx's Avatar
Trader Rating: 28 (97%+)
Default Some new stuff!
NEW PRODUCTS FOR THE SERPENT COBRA 3.1!
Flex is your friend! We have come up with a perfect design that allows more flex to the front of the car. The will give you more front end grip and increase steering response mid turn. Machined from billet Delrin, not a molded plastic part.
New piston design specifically for the 3.1 shock geometry. We found that 6 hole pistons even with light oils were too lethargic. So we went with 8 holes but also incorporates our Venturi effect design thatís been proven in off-road racing. By laying the shocks down you lose transition response so our new design brings it back giving you the response of the 3.0 but corner speed of the new 3.1!
RCShox
Serpent Cobra GT-16mmflocontrol-v4.png   Serpent Cobra GT-cobraflexdeck.jpg   Serpent Cobra GT-cobraflexdeckone.jpg
desotoracing and dan_vector like this.
MantisWorx is offline   Reply With Quote
Old 11-10-2017, 07:22 PM   #2523
Hey guys just putting some new servos to my cobra GT. just wondering- anybody got some photos of how they've looped/secured/wired their wiring from servos and transponder through the radio tray from servos to the receiver box? Just wondering if there's any general consensus on best methods.
Cilal is offline   Reply With Quote
Old 11-10-2017, 07:30 PM   #2524
Also- what methods are you all using for the power switch on receiver box? An actual switch like the original? Or something else? Want some ideas for faster charging methods and simpler, instead of needing to remove the entire top tray of the receiver & battery box. But don't want to upset battery or wiring by leaving it exposed. Ps it's a Lipo HV receiver battery.
Old 11-11-2017, 01:29 AM   #2525
dan_vector's Avatar
I double tape the throttle servo wire to the back of the case and then run it to the transponder which is mounted in the standard position. Pick up the transponder wire and steering servo wires and run them to the Rx box. I use a standard mechanical switch mounted in the standard position. I've never had an issue with a mechanical switch in 3 seasons!
Regarding the battery. I use a 2400mah LIPO and can run a full race day (so 20 minutes practice, 4x 7 min quali runs and a 30 minute final without charging). Even a 2 hour practice session/engine run in day I have no issues without charging so I don't worry about having to take off the Rx box top to charge.
Old 11-14-2017, 07:10 PM   #2526
Hi guys I was going to upgrade my throttle / brake servo horn to the aluminium. Apparently the longer aluminium horn is now discontinued? Is there a reason for this? Does everybody just run plastic for throttle / brake? Let me know what's best to run as I've just upgraded servos and keen to set it up right away.
Old 11-14-2017, 08:12 PM   #2527
dan_vector's Avatar
It isn't discontinued and remains an option on the v3.1 car. Who told you that it is discontinued? By the way I used the stock plastic arm for quite a while and never had an issue with it but upgraded to the alu when I built a new 3.0 at the start of last season.
Desoto have them in stock:
https://www.serpentamerica.com/shop/...2&cat=0&page=1
Old 11-15-2017, 08:09 AM   #2528
Serpent Australia, was there in person. They even showed me on their computer screen that it's discontinued. PN 600295 for 25tooth. They said it's cos the stiffness of the Alu horn would kill servos but the flex in plastic wouldn't, hence why it's discontinued. Dunno if that's correct or not. But he definitely couldn't order it in.
Old 11-15-2017, 09:24 AM   #2529
dan_vector's Avatar
Hmmmm I'm not sure it's true. It's certainly not true about the stiffness vs plastic as a reason why they are saying discontinued. Goto the Serpent main Facebook page and send them a PM they do respond well usually. My information is that it isn't discontinued and available.
Old 11-15-2017, 11:03 PM   #2530
What's your take Dan- is it harder on servos the alu or will I be fine. Many other shops have the part but will email serpent anyway.
Old 11-15-2017, 11:05 PM   #2531
Here on the serpent page it says discontinued:
Serpent Model Racing Cars - Product - Servo lever throttle 25T alu
Old 11-16-2017, 01:51 AM   #2532
wkloppen's Avatar
I've used the a hudy alu horn for a year and I doubt the reason for discontinuing the Serpent alu horn has to do with stiffness reasons. Sometimes items get discontinued as there are multiple options to fullfill your needs. This is the case with many items and with many manufacturers. It's a trade off for them to offer a complete assortiment of items to run your car on one hand and on the other hand minimize operational costs. Keeping every item available is an indirect cost component just for the purpose of having it. Very understandable they discontinue items in order to keep the prices of other items low engough and stay in business.
w.
* A man has got to know him limitations!
* Tuning your needles like you would prefer your women. Big up top and skinny on the bottom
* IGT8 Red with XRD 5 ports, Novarossi GT manifold (41032), 4 chamber Hypex low noise exhaust, GRP (S5, S4) tyres
wkloppen is offline   Reply With Quote
Old 11-16-2017, 05:26 AM   #2533
dan_vector's Avatar
That’s interesting because the 23T and 24T aren’t discontinued! Perhaps serpent think everyone uses Sanwa servos lol.
Old 11-16-2017, 05:29 AM   #2534
dan_vector's Avatar
Nope. Alu is fine. That claim is unfounded. Granted there is nothing wrong with the plastic throttle/brake horn but the Alu one isnít any harder on the servo.
MantisWorx likes this.
Old 11-16-2017, 01:07 PM   #2535
Thatís interesting because the 23T and 24T arenít discontinued! Perhaps serpent think everyone uses Sanwa servos lol.
Contacted serpent directly- lack of demand. I would assume eventually the 23 and 24 tooth versions will disappear too. I'll just buy online from a shop with stocks. Found a few.
dan_vector likes this.
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11733 09-23-2017 05:13 AM
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 06:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 06:05 PM
Tags
serpent 977, serpent cobra
