Like Tree56Likes
Old 10-13-2017, 03:10 AM   #2506
Originally Posted by race_line View Post
A question
The new Cluth Bell Its better than the stock one?
It's a little lighter, slightly better acceleration
desotoracing is offline   Reply With Quote
Old 10-20-2017, 08:24 AM   #2507
Hello from France,
no problem with the screws. Just don't hesitate to screw strong!!!
romuald31 is offline   Reply With Quote
Old 10-21-2017, 01:33 AM   #2508
wkloppen's Avatar
Default Linkages play
Hello Gents,
A question about linkages play. I know it's a much debated topic in RC in general but I tend to believe the linkages play, especially on the steering servo linkage to the servo saver post is huge. Also the steering rods and the camber linkages do have quite a bit of play. Do I just need to replace them or are there better aftermarket linkages I can use. Did a lot of searching already but thought I'd ask here for some good advice....
thx in advance
w.
* A man has got to know him limitations!
* Tuning your needles like you would prefer your women. Big up top and skinny on the bottom
* IGT8 Red with XRD 5 ports, Novarossi GT manifold (41032), 4 chamber Hypex low noise exhaust, GRP (S5, S4) tyres
wkloppen is offline   Reply With Quote
Old 10-21-2017, 02:43 AM   #2509
dan_vector's Avatar
Trader Rating: 27 (100%+)
Originally Posted by wkloppen View Post
Hello Gents,
thx in advance
w.
It depends where the play is coming from. I usually replace the plastic ball joints when wear starts to develop in the plastic but to be honest it isn't very often. If I remember correctly you run the RTR car? If so then the steering assembly has a lot of play in it from the outset. I don't mind a bit of play in the linkages and I actually think it leads to a freer feeling car on the track.
Another thing which is overlooked is the actual play in the steering servo itself. I used to run SAVOX but found the gears very soon developed a lot of play in them which actually made the rest of the steering system seem to have lots of play. I now run SANWA SRG-BX servos in GT (I was already using them in Buggy and 1/8 circuit) and most of the play went away as the servo them had no neutral play whatsoever.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 10-21-2017, 01:14 PM   #2510
wkloppen's Avatar
I think the steering rod linkages and the servo linkage are the same as the 3.0. The standard RTR ackerman bar sucks as Serpent puts 3 mm threaded bolts into the metal 3.5 mm bushings instead of using the kingpins. I replaced it by the ball bearing one. The savox 2290 has 1 hour of work under the belt as I burnt up 2 savox 1268's already. It's not the servo, it's not the ackerman. It's only the steering rods and the servo link. I was just wandering whether this is normal after let say about 10 liters of fuel. Replacing is easy but maybe there something better?...
w.
Old 10-21-2017, 07:59 PM   #2511
dan_vector's Avatar
w.
I get more life than 10 liters but as you say cheap to replace. I don't think there is an alternative actually.
Old 10-29-2017, 04:19 PM   #2512
Trader Rating: 37 (100%+)
Default droop
Dan how & what do you set the droop at
DKB243 is offline   Reply With Quote
Old 10-30-2017, 10:34 AM   #2513
dan_vector's Avatar
Chassis on a flat plate and with the wheel hex on a parallel with the flat plate measure the droop from the bottom of the hex to the board. In general I start with 25mm in the front and 26mm in the rear. I run the car very stiff with very little uplift on the GT.
Old 10-30-2017, 04:34 PM   #2514
rcfiend's Avatar
Trader Rating: 29 (100%+)
If anyone is looking for a Cobra GT, I have a brand new ready to run with motor, servos, pipe/header, 811 GT suspension upgrade, gears, springs, sweep tires. Everything is brand new. No time to play, to many hobbies.
Brand New Serpent Cobra GT 3.0 Roller
rcfiend is offline   Reply With Quote
Old 10-31-2017, 02:32 PM   #2515
Thanks Dan
Old 11-02-2017, 10:51 AM   #2516
Z
Anyone know when new kits might be in stock?
Z is offline   Reply With Quote
Old 11-02-2017, 11:16 AM   #2517
wkloppen's Avatar
Old 11-02-2017, 12:47 PM   #2518
I heard there won't be 3.1 kits.
Ren13B is offline   Reply With Quote
Old 11-02-2017, 12:49 PM   #2519
Rockin G's Avatar
http://www.redrc.net/2017/11/serpent-cobra-gt-3-1-team-edition-18th-nitro-gt-kit/
Rockin G is offline   Reply With Quote
Old 11-03-2017, 05:29 AM   #2520
Yeah they must have changed their mind. It's on the serpent site now too. Serpent Model Racing Cars - Product - Cobra GT 3.1 1/8 GP 4wd
Serpent 811 Cobra Buggy Preston777 Nitro Off-Road 11733 09-23-2017 05:13 AM
Sweep Racing Tires 1/8th GT thread SweepRacingUSA Nitro On-Road 790 05-04-2017 06:36 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
2010 Ipanema US GT Nationals September 3rd through 5th JLock Racing Forum 220 11-01-2010 06:05 PM
Tags
serpent 977, serpent cobra
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
